Page 12 of 13
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Posted: Thu Jan 31, 2019 6:42 pm
by BlueEyesGT
ciclo wrote: Sun Jan 20, 2019 4:16 am BlueEyesGT
Direct TPMS ---> Address 65 must be present in the Gateway installation list.
VCDS: gateway, installation list, search for 65 address.
The BCM has to be changed if it is not present.
Recommendation: open a new personal thread in 6R section, post Autoscan, pics from your car, links, etc... that is, the information that you consider most appropriate to receive help.
Will open a new thread with relevant information for further help.
For the GTI steering wheel with paddles search on eBay o googled ...vagretrofit..., maybe they have what you are looking for. I do not know if they ship to India. (without airbag and with the appropriate buttons about € 300)
I am in touch with this seller after your post, looks like he has what I am looking for :D Your response is much appreciated!!
Posted: Sun Feb 03, 2019 3:24 pm
by hmthakur
Whats this fault code??
Sunday,03,February,2019,20:08:09:19846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: MEXC15608FT
License Plate: MH-15-3-2-19-5
Mileage: 14720km-9146mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 65
VIN: MEXC15608FT079060 Mileage: 14720km-9146miles
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D84C00F1D15260F45B-8038
Readiness: 0110 0101
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B203E571F6178BF8BF-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 055498AF25A5FE4FADB-8050
Serial number: 11121404651355
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F7434073AD97EC1-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA49BB7A871B67DED-8014
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 073170395
Coding: 3AB02BBF08A30000013806917CEB9E915AC0674F600D3051200000030000
Shop #: WSC 12345 123 12345
VCID: 2A0E0B13ECFBF137E09-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 061216 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576141210080401
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579141210182244
Coding: 010000
Subsystem 4 - Part No SW: 13 202 579 14 HW: 132 025 791 41
Component: RLS 061216 04 42 2101
Serial number: ÿ132025791412101822
Coding: 323234
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580141106012556
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581141125202458
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC549F493DDA2F093-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C00
Shop #: WSC 13202 938 12345
VCID: 47C852A75F292C5F1F7-8012
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Reifendrucküberwachung: keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 8
Reset counter: 200
Mileage: 14723 km
Date: 2019.02.03
Time: 01:00:13
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 688AB11B3277032736D-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECB132CFB3137209-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4CBF710D126FD13-8014
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000053044
ROD: EV_RDKBERU30_005.rod
VCID: 372822672FC95CDF6F7-8062
End----------(Elapsed Time: 01:10, VBatt start/end: 13.7V/13.8V)-----------
Posted: Sun Feb 03, 2019 4:23 pm
by ciclo
Steuergerät für Reifendrucküberwachung: keine Kommunikation = Control unit for tire pressure monitoring: no communication
It's a fault with a priority 6 which we don't know how to get rid of it. It's generated at the vehicle start, that is, if you clear the fault and you drive your car it will not be generated again while driving.
However, TPM direct system (PQ35) will work perfectly in your 6R, which is a luxury for our PQ25 platform.
Look for priority 6 in Ross-tech.
The only way to get rid of this fault is by removing the TPMS direct. :mrgreen:
Posted: Sun Feb 03, 2019 4:27 pm
by hmthakur
ciclo wrote:Steuergerät für Reifendrucküberwachung: keine Kommunikation = Control unit for tire pressure monitoring: no communication
Thanks polo master
So no need to worry ??
Posted: Sun Feb 03, 2019 4:37 pm
by ciclo
I'm delighted with its operation and not worried at all. 🤪
The diagnosis is only to warn of what happens ... intermittent fault? for many it is not obligatory or priority. Clear All DTCs ✅ and ready to fly. :lol:
Posted: Sun Feb 03, 2019 5:36 pm
by ciclo
For example, the weird reading (your last Autoscan, Address 09 - subsystem 4) of your MFSW buttons is more important to me.
But if they work ... are you worried? :)
Posted: Sun Feb 03, 2019 5:52 pm
by hmthakur
ciclo wrote:For example, the weird reading (your last Autoscan, Address 09 - subsystem 4) of your MFSW buttons is more important to me.
Sorry master didnt get what you are saying?? Is it coding mistake?? My car came with mfsw from factory
Posted: Sun Feb 03, 2019 6:05 pm
by ciclo
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 323234
Coding: 020000
Coding: 020000
Is this your MFSW from the factory? Really?
This promises to be interesting.
Posted: Sun Feb 03, 2019 6:13 pm
by ciclo
Posted: Sun Feb 03, 2019 6:19 pm
by hmthakur
ciclo wrote:-------------------------------------------------------------------------------
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 323234
Coding: 020000
Coding: 020000
Whats the problem?? Is it coding ??
Posted: Sun Feb 03, 2019 6:26 pm
by ciclo
It is not a coding problem, the problem is that those buttons are for another platform.
They seem to work correctly in the PQ25, right?
White backlight?
Posted: Sun Feb 03, 2019 6:28 pm
by hmthakur
ciclo wrote:It is not a coding problem, the problem is that those buttons are for another platform.
White backlight?
Yup. I had installed gti steering wheel with paddle shifters.
Posted: Sun Feb 03, 2019 6:35 pm
by ciclo
Then no problem.
Golf MK7 MFSW?
Posted: Sun Feb 03, 2019 6:37 pm
by hmthakur
ciclo wrote:Then no problem.
Golf MK7 MFSW?
Yup
Posted: Thu Feb 28, 2019 3:32 pm
by hmthakur
Which are the best PSY24W led bulbs for Indicator ?? Link for purchasing will be appreciated
