Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
patil
Re: Patil's T-roc 2020 1.5Tsi evo+Dsg7 RHD
Post by patil »
Factory fitted front brake pads worn out @ 66300km with indelible warning
It makes me think that either the brake pad lifespan has decreased considerably compared to those used years ago, or that the driver assistance systems -combined with the automatic transmission- are over using the brakes.
I don't want to think badly, and that since it's a "NEW" vehicle with a few Kms on it at the time of purchase, someone decided to reduce them?... 😟
What do you mean by an indelible warning? Isn't it possible to clear the DTC 'as usual' once the brake pads have been replaced?😬
VW's insanity —and future decline— would be absolute if it required paying for an online connection to clear this DTC.
I guess since my good friends already have a Toyota (with all the wiring from the factory :lol:) and the philosophy is to go for good quality, I'll have to buy a Toyota (neither American nor European cars, only Asian or UK cars :mrgreen:).
patil
Post by patil »
ciclo wrote: Thu Apr 03, 2025 2:48 am It makes me think that either the brake pad lifespan has decreased considerably compared to those used years ago, or that the driver assistance systems -combined with the automatic transmission- are over using the brakes.
Apologies for very late reply. 🙏
I have been away for some good and some not so good reasons.
I got changed all 4 rotors and pads at dealership. Front pads were totally wornout and rear pads were nearing end. Rotors had some mm thickness left, but decided to change them also. The front brake pad warning went off only after replacing them with new one's.
I would like to share the pictures and also some updates but I am stuck. Need help!
For past several months, I no longer have access to imgur.com, image hosting site we all commonly use. After repeated failed attemps, I contacted their support team. I got a blunt reply saying, imgur service is no longer available in your geographical location.🙄
I have thousands of pictures uploaded in imgur, and I no longer have access to them😢
Kindly anyone suggest me a alternative image hosting sites, even if it's paid service, I don't mind. 🙂
Doctors don't need to apologize, their work is always commendable. 🤗
It's my wish, and we all hope everything goes well for you there.🙏
Thanks for the update.
It's a real shame and a big setback for you about Imgur. It's still working well for me, but I suppose, like you, and not being among the chosen ones, they will soon kick my ass...
Youtube has already caught my trick to avoid ads... and they block my videos in 'certain places' on our planet. Which matters to me NOTHING or less NOTHING, I do not monetize my 'educational' videos.😂
Now I don't know which hosting to recommend. Have you looked at Russia, etc...? I think Yandex has a file and image hosting that seems like a good place... I'm not sure.
patil
Post by patil »
Thank you for your kind words dear Master 🙏
I am considering few image hosting websites. Imgbb is one, but not as versatile as imgur. Russian sites is a interesting recommendation. Considering my geographical location and geopolitical situation, it's unlikely that Russians will ban me :mrgreen:
patil
Post by patil »
Testing new image hosting site imgbb. :!:
The below image is just a random picture showing Teleporting issue I faced after installing MIB2.5 Discover media.I tried to feed gps data to DM via CAN ( this is only possible if address 75, telematics is present). More about it later and the solution to it.
The red arrow with circle should have been on thick yellow line, but it's wandering 🤭
Yes, it seems like the whole world (humanity) is suffering from bullying from the same old bully and capricious kids. 🤷‍♂️ :lol:
edit:
The image looks good.👍
Later, when possible, tell us about that experience and solution.
patil
Post by patil »
Log#31
New AGM battery replacement for factory fitted EFB.
Factory fitted Varta EFB 59Ah battery lasted for around 5years and eventually died some months ago.
Replacement I choose is New AGM 70Ah Varta aftermarket, slightly bigger than OE and that's the Max size my T-roc battery tray can hold.
Just pictures:
All been good so far and no issues faced.
My few observations:
1. New Battery serial number to be registered in GW can be any numbers/alphabets we like, DOB, Anniversary date.. anything, just it shouldn't be same as previous one. Even one digit/alphabet change in previous battery serial number is also ok. The moment battery serial number is changed in GW, the charge/discharge count of battery is reset. VW provides it's own battery serial number on sticker when oe battery is purchased.
2. Over a period of time I have observed that, my new AGM battery doesn't charge to full 100%. Max I have seen is around 80-85%, I wondered why. May be to extend the battery life? I am not sure.
3. My stock 59Ah EFB battery fleece protective cover won't fit new 70Ah battery. I just pulled the old cover around new battery and zip tied it. Edit: got new bigger battery fleece cover and new plastic top battery cover from AliExpress, but too lazy to replace. 😁
4. In ODIS-E, when selecting battery technology, for AGM battery there are 2 options. One is Fleece and other is AGM spiral. I was in confusion which one to select for new AGM battery? A little search on Rosstech forum, got me clear answer. Fleece is the correct selection for flat plate AGM battery and AGM spiral for AGM spiral gel plate batteries (AGM batteries in most PHEV.)
patil
Post by patil »
Log# 32
Illuminated Keyless door handles- all 4 doors.☺️
From factory, front 2 doors keyless entry without illumination.
Later I retrofitted rear 2 doors keyless entry door handles without illumination.
viewtopic.php?p=600633#p600633
Now I successfully completed all 4 door keyless entry with illumination. ✌️😎
Parts:
I purchased all 4 door handles with wiring kit for T-roc from AliExpress.
https://a.aliexpress.com/_c3wEi7ub
I received the handles painted in dark grey, got them repainted at VW dealer to my T-roc colour, ie Indium grey.
Handle part numbers:
Front right and rear right 55A837205B 2pc
Front left and rear left 55A837206B 2pc
These illuminated kessy handles are installed in T-roc/ Tayron/CC in Chinese models. The new MK2 2026 T-roc R-line also comes with same illuminated exterior door handles. The latest Tayron R-line launched here in my country also come fitted with these illuminated exterior door handles.
Picture taken from seat forum, credits to the author. I will post the reference links at the end of the this post.
Handle caps RHD T-roc ( optional)
Left front and rear 5G0839167D 2pc
Rear right 5G0839168D 1pc
Front right 5G2837880D 1pc
Painting technician at dealership suggested me to provide stock handle caps also along with new handles for uniformity in paint colour. So I asked dealer to order 4 new caps and repaint them along with handles, to avoid unnecessary hassle.
8pin handle connector blue 4pcs -  3G0973708.
Funny thing is, even though it's a 8 pin connector, slot 7 and 8 are dummy, with no holes for terminal.
There is another similar 8pin door handle connector black which VW uses for advanced kessy system handles ( Kessy+ light +NFC. PR 4K5, 4K6, UD1, UD2) to unlock car using phone key without need for physical key (eg; Golf8, Passat B9 etc.. additional optional equipment on subscription basis). So the 2 extra slots in 8 pins connector is for NFC wiring I guess.
https://youtube.com/shorts/BprFkirSq9Y? ... GvdSHJs5JW
Terminals:
4 pin connector for non kessy handles with light or kessy handles without light use 000979030E terminal, same terminal is also used in ECU I remember from ACC retrofit.
8 pin connector for handles with kessy and light use
000979053 E terminal.
Wiring connection for handle lights
There are 3( may be 4) ways to power handle lights. The working logic of handle lights is same as puddle lights under ORVM ( VW calls them with different names..Entry/ Field /Sorround lights)
1. T16/1 black connector of front door control modules. This pin feeds +12v to puddle lights if present. Door handle +12v can be connected to this pin and branch out to rear handle lights on that particular side, if rear doors don't have door control modules. Most Chinese sellers wiring scheme recommend to connect handle lights +12v to this pin.
2. T20/3 white connector of front door control modules. This pin exactly replicates function of  T16/1 pin of black connector ( tested).  This pin used in factory fitted door handles with lights in most VAG cars. Eg; Audi A4, T-roc/ Tayron/ Tiguan chinese versions. The new 2nd Gen T-roc launched in EU comes with door handles with light.
3. Unused BCM pin ( experimental) I think it is possible to connect door handle lights to any of one free BCM pin and code them in adaptations to work as puddle lights/ footwell lights. I thought of this idea, but I had doubts about achieving theatre dimming effect of these lights via BCM. Dimming effect is special feature of door control modules whether it is for door warning lights or exterior door handle lights. That being said, it is easy and simple to connect door handle lights to door control modules.
4. ? T32/3 blue connector( front door handle light + ) and T20/8 white connector( rear door handles +) PR 4K5 4K6/ UD1, UD2
If I understood the WD from Golf correctly, the advanced kessy handles with illumination use different connectors and pins for front as well as rear exterior door handles. WD posted below for anyone's interpretation.
Cars having rear door control modules- T20/1 +12v for rear handle lights
Repinnig: From kessy handles (2/4 doors) without light (4pin) to kessy handles with light( 8pin).
T4/1 to T8/1
T4/2 to T8/2
T4/3 to T8/3
T4/4 to T8/4
T8/5 GND
T8/6 +12v
GND connection for door handle lights:
For front door handles with kessy from factory has a GND wire in T4/2 kessy coupler in door. I connected door handle lights GND of both front doors to this wire. This type GND connection is readymade in AliExpress wiring kit. Also GND can be connected to window lifter nut in door metal frame using ring terminal. I used ring GND terminal for rear handle lights.
Note: There are 2 different type wiring kits available for handle lights with kessy on AliExpress.
1. https://a.aliexpress.com/_c3czj6Mf
2. https://a.aliexpress.com/_c3ovVMvp
The first one is provided with 6 pin blue connector with wires for handle lights prewired and additional terminals provided for kessy wires to be cut and recrimped.
The second one is complete kessy + handle lights wiring. It's simply plug and play with all wires including GND prewired. I will recommend this kit for upgrading kessy 2/4 door without light to with light.
Relevant WD, installation pictures, autoscan, video.
WD:
Connection to T16/1 door control module:
Connection to T20/3 door control module:
I connected driver side to T16/1 and passenger side to T20/3 to check if there is any difference in behaviour of door handle lights. There is no difference, they work exactly the same way.
Rear right door connection, similarly done in rear left door.
Coding:
Pictures:
At the same time, I took the opportunity to rewire so that the rear door exit lights are managed by BCM.👌
Rear door warning lights: control via BCM
Previously, I had connected rear door wiring lights with +30 from battery via fuse and GND connected to door lock open/close GND microswitch.
I felt connecting rear door warning lights GND to door lock microswitch is risky and might run into trouble of blowing door lock microswitch.
The previous wiring installation is totally undone.
viewtopic.php?p=600736#p600736
I used 2 free BCM AMBL pins( eg; T73a/36 &37, C-connector), one for rear right and one for rear left door warning light+12v signal. GND to window lifter frame nut using ring terminal in rear doors metal frame.
This is how I wired the rear door lights.
Example in my case.
Rear left door warning light:
BCM T73a/37 → T17/9( TUIL blue coupler free slot) → T19/19 (TTHL, free slot rear left door coupler) →T2/2 warning lamp connector.
Rear right door warning light:
BCM T73a/36 → T17/8( TUIL blue coupler free slot) → T19/19 (TTHR, free slot rear right door coupler) →T2/2 warning lamp connector.
These pins must be coded to work as rear door exit lights in BCM adaptations.
Security access09: 31347
Rear left:
Rear right:
They work as they should after coding. But 2 differences are noticeable compared to front door exit lamps which are controlled by door control modules.
No theatre dimming effect like front exit  lights. They simply go off immediately after door is closed. May be it is possible to enable this feature in BCM adaptations, I've tried without luck so far.
No bulb out error dtc :  Unlike front door exit lamps, there is no dtc registered in BCM if bulb is blown or wiring disconnected.  There are 2 adaptations within each Leuchete channel which determines the bulb protection and dtc registry. Fehlerort mittleres Byte DTC-DFCC  and Lampendefektbitposition.  I tried playing around the byte values of these 2 adaptations, but with no luck so far. Looks like it's a grey area need to be explored more. I am posting a screenshot from DV52's light control observation document below
Latest autoscan: I've decided to no longer conceal my vin for the larger benefit of retrofit community. :)
Wednesday,11,February,2026,19:48:17:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: WVGZZZA1ZLV077835   License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 6D
          75 A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLV077835   Mileage: 100140km-62224miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 AT    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9640
   Revision: 8AH20000    CVN: 5E8A0C2D
   Coding: 0125003223641D0830000000000000000000000000000000
   Shop #: WSC 00020 043 00000
   ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
   ROD: EV_ECM15TFS01105E906018AT_003.rod
   VCID: 77A8E2A6DF4F07E2BF9-8022
   VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 050 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1911
   Revision: 00005009    Serial number: CU501911185682 CVN: ABB5E1C0
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021.rod
   VCID: 3C223D8AA6E9E4BA92B-8068
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 63139000003538
   Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733822F00A52A24B0B00000523525212121035351919323200
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7DA4F08EFD732DB2E55-8028
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0534174099 Dataset Number: V03935301VA 0001
   Coding: 1F20200723
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 45D4586ED523A572FD5-8010
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3GD 962 243 D    HW: 3GD 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 05086671
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 17G 907 044 AN    HW: 17G 907 044 AN
   Component: AC Automat    H11 1501
   Revision: 20K07000    Serial number: 00000A00811480
   Coding: 061200242001100D1105004C12145836
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 76B6EFA2D8457EEAA4F-8022
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 0511
   Serial number: B2701012207200 Dataset Number: V03935394NB 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: S6Y19M10D15H05M19S28
   Coding: 0018DD
   Anti-theft alarm system sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY153350TTJ
   Alarm horn:
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000754028
   Roof electronics control module:
   Subsystem 4 - Part No SW: 3G0 947 105 D    HW: 3G0 947 105 D
   Component: J528 Dachelek  H08 0008
   Serial number: 16112500010020D
   Coding: F38380
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 KS    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 05000405202300100730
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0073
   Serial number: 000150057322125 Dataset Number: V03935342EN 0001
   Coding: 8379567851
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_010_VW37.rod
   VCID: 58EA811A3291289A963-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 AB    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0397
   Dataset Number: V03935376DS 0001
   Coding: 300C47C35CFF8748949C812483578780000000000000000034
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 74B2D5AACE396CFA9AB-8020
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PPMRKF2 Dataset Number: V03935298UN 0001
   Coding: 88CCC0C0000000005C5400CF008840000065
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW27.rod
   VCID: 0B40AE56B3C71302EB1-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 002 910 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000004A1316142
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 19
   Component: SideSensor_Pf  008 0887
   Serial number: 35800000000C98B8424V
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 454 802 210 19
   Component: SideSensor_Dr  301 0148
   Serial number: 35100A0CB121A000000D
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 510 19
   Component: SideSensor_Pr  301 0148
   Serial number: 35200E4A8381A000000P
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 802 310 19
   Component: FrontSensor_D  304 0149
   Serial number: 35500964D2C1A000000R
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4310
   Coding: 65FC00986E88080C0180770F1801000000000906
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
   VCID: 2616FFE248654E6AD4F-8072
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 14022210802625 Dataset Number: SET_FPA_MOD 0001
   Coding: 030900046F085600DB1702DC1E0F00010001070000000000000000000000
   GVL: 014E3C000800060040CC80008000C80010000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 7F580A86F77F3FA2F79-802A
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H03 0219
   Serial number: 17038315111572401137
   Coding: AF2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000332474005
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 313C1CBE71AB19D231D-8064
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520011985865  Dataset Number: V03935308HF 0001
   Coding: 92A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   VCID: 392C249EA9DBD19289D-806C
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520011913860
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000397175085  Dataset Number: V03935313VT 0001
   Coding: 00151A20D001028000001000
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4DC4604E0D535D32355-8018
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000036110727
   Coding: 1D0000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935312TK 0001
   Coding: 971F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 17111910522941 Dataset Number: V03935304ZR 0001
   Coding: 000000070900204600000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372822A69FCFC7E27F9-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000396858048  Dataset Number: V03935313WJ 0001
   Coding: 00151020DC01028000001000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4CC26D4AF649543A22B-8018
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036011483
   Coding: 050000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     854 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02730601BE0000004111000100180A201F0500B601200000C6
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW27.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX1471458
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 FH    HW: -----------
   Component: MRM2 2024/25  --- 2210
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000255241 Dataset Number: rdkseditor  0204
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_005.rod
   VCID: 382A219A92D1C89A763-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 T    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0271
   Revision: --------    Serial number: PLG01908160021 Dataset Number: V03935301SX 0001
   Coding: 1C28
   ASAM Dataset: EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 49CC545EF93B411219D-801C
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935298KU 0001
   Coding: 02720601EA16380D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   VCID: 3D24308EBDF3EDB2A55-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
   Serial number: E79132511211900 Dataset Number: V03935410YR 0001
   Coding: 0000011811EEC028889F24800020002201430000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 36362FA298C53EEA64F-8062
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Dataset Number: V03935280ME 0001
   Coding: 508040727602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
   VCID: 75B4E8AEC54375F2AD5-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 025E8372848D524A987-8056
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
End----(Elapsed Time: 01:47, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
---------------------------No fault code found.----------------------------
Video:
Reference articles.With due respect to all authors for sharing the information.😊🙏
https://www.seatcupra.net/forums/thread ... es.476137/
viewtopic.php?p=606136#p606136
https://www.drive2.ru/l/661086589954314341/
I am very satisfied with the illuminated door handles. They look classy and premium😍
It was a laborious and time consuming retrofit. It took 4 sessions over 2 weekends for me to complete the work. But I feel it was worth the sweat.😁
Good job, Doctor.
I love those lights.
Anything that's fun is always worthwhile, it improves your skills and understanding, and having something that others don't have due to neglect or lack of ambition is a bonus. 😁
I'm waiting for good weather so that while I enjoy nature (birds, ants, etc.), I can install the same setup in our Golf that I had planned a while back (before or after my supposed heart attack -pandemic times-, I don't remember well... 😄).
...those damn usurious private health companies/doctors around here.
patil
Post by patil »
A new milestone! My T-roc crossed 100000 km mark.😎
It is a pleasure to own and drive T-roc. ❤️👌
T-roc being my daily drive, has brought me more happy driving experience. She has never let me down a single day since ownership.✌️
Looking at the way the new VW cars prices are heading crazily south, my T-roc feels most value for money driving experience. I have no intentions to part ways with my T-roc or 6R even though, now and then, I get a itch of upgrading.😁
So, what next for my T-roc? Well I have plans charted out. DCC, Highline RVC, multicolour ambient lights( footwell lights already done, will post details soon). New tyres with new alloys and bigger front brakes 312mm are also under consideration.
Squeezing free time out my busy schedules is becoming a nightmare for me.🙈
Nonetheless, slowly but surely I will do everything I have planned for my T-roc.👍
Thank you dear friends for all the help and support.🤝🙏
The new 312mm brake discs would be a perfect match for wheels of at least 18 inches. It's not just about aesthetics, but also about performance. The braking will be very satisfying, ... exceptionally satisfying. 😉
patil
Post by patil »
ciclo wrote: Thu Feb 19, 2026 6:13 pm The new 312mm brake discs would be a perfect match for wheels of at least 18 inches. It's not just about aesthetics, but also about performance. The braking will be very satisfying, ... exceptionally satisfying. 😉
Exactly! that's what I am planning 😁👍
I am trying to source 18" Sebring T-roc alloys. I have ordered 312mm+ 272mm blue brake it from E-bay Germany, the one you've already installed in your Golf.👌
Those brakes are great! 8) A very good choice for your T-Roc, you'll be surprised and pleased.
Use the one-way valve method (single person) for brake bleeding. Perform the initial bleeding with 6 to 12 full brake pedal strokes for each wheel. 12 strokes are best if you're replacing the brake fluid (recommended).
Take the T-Roc for a drive and activate the ABS/ESP system at least once while driving.
After a few days for the brake pads to bed in to the brake discs, you should clearly feel very powerful braking with just a light touch of the brake pedal, this feeling is noticeably different from the original brake setup, if not, repeat the bleeding process with the one-way valve.👌
patil
Post by patil »
Thank you for tips dear master. I will follow your instructions during installation.👍
I have received the blue brake kit from Germany.😎  It will take some time for me install. I am yet to buy front 312 discs, most likely I will go with OEM discs only because they are good easy to source.
Only thing I didn't expect was missing wear sensor in front pads. VW do sell wear sensor for brake pads seperately. Part no 8V0615437, I will try to source one.
