hi,
I checked wiring
t73a/62 goes to sb28 and there is a flow - checked by multimeter
t73a/5 and t73b/3 - should they go directly or can they go through SC12 and SC14 ?
I checked voltage T14/12 connector there is always around 12v ( both connectors )
I aslo checked T14/10 and its act funny, when light switch on 0 or AUTO, when its not dark - lights not activated, there is also around 12v, but when I change position to side lights or main beam its drops to less than 2v, which I belive is not enough for them to lit
I did little test, disconnected t73b/5 and supplied with 9v, DRL did light up dimmed
I think there is some issue with t73b/5 and t73b/6
Still cant connect numer plate wire as everything stop working
I took complete headlights from the van where they were factory fitted and they worked before I removed them
Any chance they might be wrong ?
BCM scan
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 353141285
Coding: A0A03DBA4EE1241393284E716EEB8E554280662F60857841320000020000
Shop #: WSC 46629 001 104857
VCID: 2F3B1062F7137D23FB9-807A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 280311 05 54 0403
Coding: 03302E
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 171
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29170000324710067062
Coding: B0FFFF
9 Faults Found:
03435 - Terminal 30 for Interior Light and Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:14
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 162
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 23:25:28
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 232356 km
Time Indication: 0
Date: 2015.02.05
Time: 23:49:16
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 9
Reset counter: 122
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 20:12:24
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 9
Reset counter: 122
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 20:12:24
03396 - Supply voltage terminal 30 for central locking
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:14
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:16
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:17
01516 - Terminal 30; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:15
I checked wiring
BCM scan
Coding: 03302E
Coding: 050000
Coding: 040000
Coding: B0FFFF
9 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:14
Fault Priority: 2
Fault Frequency: 3
Reset counter: 162
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 23:25:28
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 232356 km
Time Indication: 0
Date: 2015.02.05
Time: 23:49:16
Fault Priority: 2
Fault Frequency: 9
Reset counter: 122
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 20:12:24
Fault Priority: 2
Fault Frequency: 9
Reset counter: 122
Mileage: 232333 km
Time Indication: 0
Date: 2015.02.05
Time: 20:12:24
Fault Priority: 2
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:14
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:16
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:17
Fault Priority: 3
Fault Frequency: 1
Reset counter: 163
Mileage: 232379 km
Time Indication: 0
Date: 2015.02.06
Time: 09:13:15
According to the BCM scan, the problem is in how the BCM receives the power and how it supplies it for the different functions as far as the lights are concerned.
Take a look at:
T73a / 62
T73a / 66
T73b / 68
... or the problem it is the BCM parameterization that I mentioned earlier.
I suppose the license plate light problem will be solved when you install the new Dimmer, etc... It all depends on how you have made and installed the BCM adaptation wiring (3
viewtopic.php?f=56&t=70736&start=45#p528735).
Take a look at:
T73a / 62
T73a / 66
T73b / 68
What is T73a/66? Did you mean 63 ?
All that errors came up after I disconnected plug from T73b to check wiring connections
They all clear now
Only dtc I am getting are from door contacts, I think micro switches are gone, all except passenger showing constantly closed
Dimmer should arrive on Friday then I will have a look
I might try buying a another BCM, any advice which one to look for? Any particular?
All connections are exactly as in your guide, so it looks like BCM causing it
They all clear now
All connectios are made exactly as in your guide, so if it worked for other people, should work for me as well
Looks like tham BCM causing some issues
I dont have any idea about BCM parametrization
I am quite new to VW diagnostic, used to have only Mercs, but fell in love with T5
I will buy VAG Can Pro and another BCM, if I will find one in decent price
Does it have to be 90D or 90B will do as well ?
Really sorry for bothering you, but you seen state of my interior, not very nice when all things flying aroun
Hi Ciclo,
One thing confuse me
Wires from T73a/5 and T73b/3 needs to go directly to T14 headlight connector or can they go through fuse holder C
SC12 and SC14 ?
I ran them through the fuses, can that be a case ?
I bought VCP and 3 more BCM for tests
090
090B
090D
I am complete novice to VCP, so we will see how it goes
SC12 and SC14 ?
090
090B
090D
cicloblue ...
bropasiek wrote: Tue Sep 15, 2020 5:23 pm What is T73a/66? Did you mean 63 ? No, I mean the T73a/66. It is the power supply for the interior lights and terminal 58. (see elsa or erwin diagrams)
All that errors came up after I disconnected plug from T73b to check wiring connections ......that's why I said 'according to BCM scan' ...![]()
They all clear now
I might try buying a another BCM, any advice which one to look for? Any particular? ...7E0937090D (2018)... contact firegrafic, he can help you get a new one for around 100 euros.
All connections are exactly as in your guide, so it looks like BCM causing it do thishttps://drive.google.com/drive/folders/ ... sp=sharing upload it to a server for file hosting and get the link to post it here ... I'll take a look.
bropasiek wrote: Tue Sep 15, 2020 5:47 pm All connectios are made exactly as in your guide, so if it worked for other people, should work for me as well ... sure.
I am quite new to VW diagnostic, used to have only Mercs, but fell in love with T5![]()
Does it have to be 90D or 90B will do as well ? 7H0937090B 7E0937090B ... any 7E0 OK! , 7H0 only D model.
Really sorry for bothering you, but you seen state of my interior, not very nice when all things flying arounno problem for that.
bropasiek wrote: Wed Sep 16, 2020 4:52 am Hi Ciclo,
SC12 and SC14 ?
Without fuses it is as indicated for original electrical installations (erWin), with fuses it is an adaptation, both methods are correct. No problem.
I bought VCP and 3 more BCM for tests ........ this is a BCMs party ...![]()
090
090B
090D
I am complete novice to VCP, so we will see how it goes ... to parameterize or edit a single value of the BCM PQ25 with VCP it is necessary to extract all the parameters to a text file (this is done by the VCP), edit the value of the parameter, and reload the text file.
I recommend doing an editing test with one of the worst BCMs you have, and if everything goes well you do it with the BCM that is finally installed.![]()
Hi Ciclo,
All stuff should be with me by the end of the week, I am off to Greece for a weekend, so when I am back with „charged batteries” I will start uneven battle with BCMs and VCP
Many thanks for your help
Can I donate you or something for your help,
really appreciated
Will keep you posted and hopefully post some photos with working headlights and T6 interior
Thanks again
Lucas
really appreciated
Thanks again
Lucas
Before I start my adventure with VCP, any idea which parameter I need to change to change voltage output on T73b/5 and 6 ?
I think this is a main issue, when main beam is on it drops to 2v, in my opinion it should be around 8v
It is 12v for a full brightness, 2v is definitely not enough for LED to lit
The best contribution / donation you can make is to post / share in this thread the results of your retrofits with 'many images'.bropasiek wrote: Wed Sep 16, 2020 9:07 am Many thanks for your help
really appreciated
That extra effort to take pictures while you work is the best donation for me.
PWM Value with POS/TFL lights and activited Pos-lightsbropasiek wrote: Wed Sep 16, 2020 10:54 am Before I start my adventure with VCP, any idea which parameter I need to change to change voltage output on T73b/5 and 6 ?
viewtopic.php?f=56&t=70736&start=270#p575528
Hi Exoticdevil,Exoticdevil wrote: Tue Sep 15, 2020 9:02 am Hello everyone!
I have updated BCM til 090D max. Retrofited auto-headligts, cruise, MFSW and rain sensor. Biiig thanks to ciclo and Adam87 for sharing their knowlage.
And almost everything is working
I have learn a lot by doing this. Crazy feeling to think about T5 wiring everythere i go
My next step is refrofiting xenon lights. Originaly car came with H7 headlights. Selfleveling and headwasher kits is on its way from Kufatec.
By searching for new bumper for fitting headwasher nozzels i have found the guy parting out T6. AND now i just wonder, if it's dig difference T6 xenon/led headlights wiring from T5.1 xenons? Decided to go all in on this project![]()
There are several differences, both in the wiring of the headlights T14 connectors (xenon vs led) and in the management-coding / wiring of the high and low beams between the Stalk and the BCM.
The wiring of the headlamp leveling system is identical (similar).
Hmm ... for example, the T6 wiring / system can handle T5 xenon headlights, but the T5 wiring / system cannot manage LED headlights.
For the LED headlights you will need a BCM 7E0.
A very clear example is that Adam87 installed in his T5 the T6 system for the management of lights (due to the HBA).
The best thing is that you get the original diagrams (erWin) and take a look at it.
reido80
- Drives: VW t5.1 GP bitdi 4motion
Hi ciclo, hope you are well, Many thanks for all your help, The lights, rain sensors, Wipers etc all look to work well.
Here we have the latest scan, The van is still sat in the same place it has been for 2 months or so due to the Clutch slave cylinder giving in so I have not given anything a proper test run out in the real world. Clutch change is booked in for next month when It will be treated to a mild sachs upgrade
I have taken the opportunity while it is off the road and the seat/carpets are out to upgrade the "camping" electrics, adding power points to the rear, rear speakers, leisure power to the dash area for stereo and interior lighting.
I have still to install the level sensors as in all the chaos with bits everywhere I misplaced my wheel locking key!
I am on the lookout for some plastic conduit for the level sensor wires and I think the easiest place to get it all is a car breakers so this is on my to do list (which is thankfully getting smaller
The sensors will physically be installed when it is in having the clutch done.
Randomly I had a few error codes to do with CAN gateway and incorrect coding but stupidly I did not save them and I cant remember now what it is I changed to get them away.
Scan below......
Scan below......
Monday,21,September,2020,13:16:00:03258
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0 License Plate: FINAL (ISH) TEST
Mileage: 130870km-81318mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 56 69 0B
VIN: WV2ZZZ7HZDH0 Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GK HW: 03L 907 309 L
Component: R4 2,0L EDC H37 3566
Revision: 22H37--- Serial number: 00000000000000
Coding: 0119401A233600080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7AADF0A04C5F927B1C7-802E
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD19A6089626A99878BA6610
Shop #: WSC 02756 790 49152
VCID: 392F2FAC0959596355D-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 75B7E39C6541FD03715-8020
Component: BCM PQ25 Max4 H74 0725
Revision: B9074001 Serial number: 0671 186141457
Coding: B8B07DB84E61241193284EF16CAB9751F28066FF40857841320000020000
Shop #: WSC 02739 790 12345
VCID: 2F3B11F4C71D87D3FB9-807A
Component: RLS 201114 05 54 0403
Coding: 0630AD
Component: J386__TSG_FT 003 3313
Coding: 050000
Component: J387__TSG_BT 003 3313
Coding: 050000
Subsystem 4 - Part No: 7E1 951 172
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0390005
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261217200384
Coding: 118001
VCID: 392F2FAC09D9596355D-806C
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00CRH9K
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3537239C25C1BD03B15-8060
Part No SW: 7E0 920 970 G HW: 7E0 920 970 G
Component: KOMBI H06 0605
Coding: 160E01
VCID: 2E050CF0C0978EDBF0F-807A
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2411EED892DB348B16B-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0725
Revision: B9074001
Coding: 042300
VCID: 70B9D2881AA3D82BA23-8024
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 B HW: 09N 907 554 B
Component: Haldex 4Motion 6008
Coding: 0000007
Shop #: WSC 02756 790 00000
VCID: 372B2994334D4F13A39-8062
Component: IMMO H06 0605
Serial number:
Shop #: WSC 12345 123 12345
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC0E03CFF22FBEC7-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0222000001000000
Shop #: WSC 02757 790 50316
VCID: 77ABE9947F4D8F13639-8022
2 Faults Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 234
Mileage: 130877 km
Date: 2020.09.21
Time: 23:09:29
13705473 - Databus
U1121 00 [137] - Missing Message
[Timeout mNiveau_2]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 234
Mileage: 130877 km
Date: 2020.09.21
Time: 23:09:28
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00008030224120
Coding: 410D000101000000
VCID: 313F178CD1299123EDD-8064
End----(Elapsed Time: 02:19, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Hi Ciclo,
I manage to get DRLs working with main beam with PWM value 40 is about right, with value of 20 as you sugested they not going on
Still struggle with number plate lights, when they connected ilumination and position lights staying on even after locking a van ( at least number plates light coming up, shame it does not switch off
I think I know what is an issue with high beam, I have 7e0 stalks, so will have to remove wires from T41 and follow a guide for Adam
Any advice ?
Very slowly I getting use to VCP
Any advice ?
Hi reido80, thank you very much for the report.reido80 wrote: Mon Sep 21, 2020 1:35 pm Hi ciclo, hope you are well, Many thanks for all your help, The lights, rain sensors, Wipers etc all look to work well.
Here we have the latest scan, The van is still sat in the same place it has been for 2 months or so due to the Clutch slave cylinder giving in so I have not given anything a proper test run out in the real world. Clutch change is booked in for next month when It will be treated to a mild sachs upgrade![]()
I am on the lookout for some plastic conduit for the level sensor wires and I think the easiest place to get it all is a car breakers so this is on my to do list (which is thankfully getting smaller)
Scan below......Code: Select all
Monday,21,September,2020,13:16:00:03258 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4 Data version: 20200730 DS317.0 www.Ross-Tech.com VIN: WV2ZZZ7HZDH0 License Plate: FINAL (ISH) TEST Mileage: 130870km-81318mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 7H-VN75 (6N0) Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 56 69 0B VIN: WV2ZZZ7HZDH0 Mileage: 130870km-81318miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 69-Trailer -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb Part No SW: 03L 906 019 GK HW: 03L 907 309 L Component: R4 2,0L EDC H37 3566 Revision: 22H37--- Serial number: 00000000000000 Coding: 0119401A233600080000 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_ECM20BTD01103L906019GK 003003 ROD: EV_ECM20BTD01103L906019GK_003.rod VCID: 7AADF0A04C5F927B1C7-802E No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb Part No SW: 7E0 907 379 J HW: 7E0 907 379 E Component: ESP MK25A XT H43 0109 Revision: 00H43001 Coding: 108764AD19A6089626A99878BA6610 Shop #: WSC 02756 790 49152 VCID: 392F2FAC0959596355D-806C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG Component: Climatic-T5 H20 0505 Revision: 00001010 Coding: 0000000002 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_ClimaticT5 A01003 ROD: EV_ClimaT5Basis.rod VCID: 75B7E39C6541FD03715-8020 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb Part No SW: 7H0 937 090 D HW: 7H0 937 090 Component: BCM PQ25 Max4 H74 0725 Revision: B9074001 Serial number: 0671 186141457 Coding: B8B07DB84E61241193284EF16CAB9751F28066FF40857841320000020000 Shop #: WSC 02739 790 12345 VCID: 2F3B11F4C71D87D3FB9-807A Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 201114 05 54 0403 Coding: 0630AD Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB Component: J386__TSG_FT 003 3313 Serial number: -------------------- Coding: 050000 Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB Component: J387__TSG_BT 003 3313 Serial number: -------------------- Coding: 050000 Subsystem 4 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 5 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 Subsystem 6 - Part No: 7E1 951 172 Component: DWA-Sensor 00 001 0104 Coding: 000000 Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Component: E221__MFL-TAS H09 0013 Serial number: 0390005 Coding: 820000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb Part No SW: 7E0 919 475 J HW: 7N0 919 475 Component: PARKHILFE 8K H06 0105 Revision: -------- Serial number: 28261217200384 Coding: 118001 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_VW75XParkAssis8K 001003 ROD: EV_VW75XParkAssis8K_001_VN75.rod VCID: 392F2FAC09D9596355D-806C No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 7E0 959 655 B HW: 7E0 959 655 B Component: VW10Airbag009 H07 0013 Revision: -------- Serial number: 003HL00CRH9K Coding: 000000000000000000000000000000003039 Shop #: WSC 02754 790 50316 ASAM Dataset: EV_AirbaVW10BPAVN750 A01026 ROD: EV_AirbaVW10BPAVN750.rod VCID: 3537239C25C1BD03B15-8060 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 7E0 920 970 G HW: 7E0 920 970 G Component: KOMBI H06 0605 Serial number: 00000000000000 Coding: 160E01 Shop #: WSC 02756 790 50316 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716 ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod VCID: 2E050CF0C0978EDBF0F-807A No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No: 7E0 815 071 B Component: J737__Standheizung 0605 Revision: 00085000 Serial number: 09019275F00000 Coding: 0000031 Shop #: WSC 02757 790 00000 VCID: 2411EED892DB348B16B-8070 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 7H0 937 090 Component: GW-K-CAN TP20 H74 0725 Revision: B9074001 Coding: 042300 Shop #: WSC 02739 790 12345 VCID: 70B9D2881AA3D82BA23-8024 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 09N 907 554 B HW: 09N 907 554 B Component: Haldex 4Motion 6008 Coding: 0000007 Shop #: WSC 02756 790 00000 VCID: 372B2994334D4F13A39-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H06 0605 Serial number: Coding: 000000 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709 ROD: EV_Immo_UDS_VDD_RM09_VW31.rod VCID: 6A8DC0E03CFF22FBEC7-803E No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb Part No SW: 6R0 907 357 HW: 6R0 907 357 Component: LWR-ECU H02 0070 Revision: -------- Serial number: -------------- Coding: 0222000001000000 Shop #: WSC 02757 790 50316 ASAM Dataset: EV_HeadlRegulVWLWRPt 001004 ROD: EV_HeadlRegulVWLWRPt_VW25.rod VCID: 77ABE9947F4D8F13639-8022 2 Faults Found: 5275220 - Headlight C107E 54 [137] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 234 Mileage: 130877 km Date: 2020.09.21 Time: 23:09:29 13705473 - Databus U1121 00 [137] - Missing Message [Timeout mNiveau_2] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 234 Mileage: 130877 km Date: 2020.09.21 Time: 23:09:28 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 G HW: 1K0 907 383 G Component: Anhaenger H10 0110 Revision: 3B001001 Serial number: 00008030224120 Coding: 410D000101000000 Shop #: WSC 02756 790 00000 VCID: 313F178CD1299123EDD-8064 No fault code found. End----(Elapsed Time: 02:19, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Comparing the last two VCDS autoscan that you have posted in this thread, I see some changes you have made to the BCM coding to get rid of those error codes you mention.
I recommend the winmerge program for quick and easy file comparisons, it's very useful in these upgrade processes.
Hi bropasiek, good to know that the PWM value for parking/side lights is 40 for T5.1 bixenon headlights. Perfect!bropasiek wrote: Mon Sep 21, 2020 7:08 pm Hi Ciclo,
Still struggle with number plate lights, when they connected ilumination and position lights staying on even after locking a van ( at least number plates light coming up, shame it does not switch off)
Any advice ?
Please tell me exactly how you connected the license plate lights.
Look at the following picture and please tell me you weren't wrong, T17/16 vs T17/17.
https://servimg.com/view/18943939/1095
The original wires are identical, but it is not the same signal.
I don't think it's a problem with the Stalks, it's more likely a wiring fault.
As an example, stalks 7E0 (T6) and BCM Max should be wired as follows ...
https://drive.google.com/file/d/0B2nv91 ... luc3M/view ... (https://www.uk-polos.net/viewtopic.php?p=503577#p503577)
taking into account that this is a diagram for the 6R and its peculiarities (fuse box), for 6R Europe the fuses 34 and 36 are assigned to the High beams.
I recommend looking at the original diagrams for T6 (erwin, elsawin).
VCDS
Once wired, it is necessary to activate Byte28 Bit3 and deactivate Byte23 Bit0 in the BCM, and assign the value 1 to channel 54.
Hi Ciclo,
Old T17/17 wire is directly connected to T10/10
Old T17/16 wire goes to T10/3 connected with T73a/45 and T73b/7 ( number plate light output )
I might try to connect T73b/7 direct to number plate lights, for now it goes through relay switched on by main beam
My battery was going flat all the time, so its temporary solution
Originally I had different stalks, but with new BCM steering angle was playing up
Old ones were old type, that stayed on once pushed back to activate high beam
New ones activate it by pulse ( obviously you know that )
For some reason BCM don’t recognise that pulse
Should I find different stalks ?
For now I have wires ready for HBA, but still looking for mirror with camera from T6
I dont have any more ideas whats wrong
Hi bropasiek,bropasiek wrote: Sat Sep 26, 2020 8:25 pm Hi Ciclo,
Well, there are some secrets that I have never explained on the forum.
Listens
- Do not invent anything new other than what is explained in my instructions in this thread.
- The wire that goes from T10/3 to T73a/45 must be a totally new wire, and it must never be connected to any other wire/cable, .... isolate the original wire as indicated in my instructions ...
What if we imagine that the original T73a/45 wire has one or two diodes sandwiched in that line ... when non-MAX BCMs are factory installed...
The interior lights are powered by the T73b/4 through the dimmer (as explained).
Together with T73b/7 these are signals 58 electronically managed in different ways according to need.
It is what you should have done from the beginning, otherwise you bypass the license plate lights diagnostics.bropasiek wrote: Sat Sep 26, 2020 8:25 pm I might try to connect T73b/7 direct to number plate lights, for now it goes through relay switched on by main beam
The new 7E0 Stalks (1x -with return spring-) need to be wired to the BCM and coded as I explained to you in my previous post.bropasiek wrote: Sat Sep 26, 2020 8:25 pm Originally I had different stalks, but with new BCM steering angle was playing up
