Retrofit golf mk7 steering wheel on polo mk5
Re: Retrofit golf mk7 steering wheel on polo mk5
how to post a VCDS autoscan
--> http://forums.ross-tech.com/showthread. ... -Auto-Scan
firebulletz
- Drives: Polo comfortline 1.6 tdi 90cv
I can't do it now. I have not the cable and the program [emoji21] these are not good?iichel wrote:how to post a VCDS autoscan--> http://forums.ross-tech.com/showthread. ... -Auto-Scan
Inviato dal mio SM-G935F utilizzando Tapatalk
Hahaha..... because I know that you're a very funny guy and not familiar with these Autoscan matters. The Autoscan you'd post is the best VCDS autoscan in the history, ... in all forums I know ...firebulletz wrote: Sat Feb 10, 2018 2:30 pm This is vcds autoscan
https://uploads.tapatalk-cdn.com/201802 ... 560ebe.jpg
https://uploads.tapatalk-cdn.com/201802 ... d021e1.jpg
https://uploads.tapatalk-cdn.com/201802 ... 1f6929.jpg
https://uploads.tapatalk-cdn.com/201802 ... 579666.jpg
Thanks for that (sincerely), these things always are the best.
Those Golf MFSW buttons are installed correctly, but we need to see the full autoscan.
For example, this is the last autoscan from my 6R:
Wednesday,07,February,2018,11:46:50:32438
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: W-Test
Mileage: 29360km-18243mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 29360km-18243miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6A8D3FD44CF80237D61-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA777E1-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E971A9-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460A7905-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
VCID: 2B03FAD08302DB3FED7-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361212601014
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E25C38460F05E975A9-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E237F61-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00000
VCID: 47CBA6603F2A1F5FE9F-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 688945DC52743027C05-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404001C00000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE17CA9-807A
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C237161-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 372BD6A04F4A6FDF99F-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71FC1F-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFDF59F-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FDF99F-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BBF7D7-806E
End----------(Elapsed Time: 01:59, VBatt start/end: 14.0V/14.0V)-----------
Tell your electrician to give you the autoscan in a TXT file and post it here.
To sum up:
- Those MFSW buttons (and none) are not compatible with your IC without MFA+.
- They are not compatible at all for the CCS.
- Neither are compatible with stalk buttons for DIS (display information system).
- Once you have the correct combination of IC, MFSW buttons, and stalks, you may have to configure the buttons functions on your big radio. (as seen in the videos that I post previously)
... end of story.
firebulletz
Tomorrow i will go on my electrician.
In future i will change the instrument cluster with mfa+, but for now I'll have to leave what I have for quite some time.
Two others questions:
1- there is a way to install these buttons without changing bcm or buttons with 1k8?
2- [I don't know if this is a verifiable thing]
My actual bcm is compatible with coming/leaving home, folding mirrors, instrument cluster mfa+, automatic lights, rain sensor (for the windshield wipers and to have the windows automatically closed in the event of rain) and anti-glare mirror? If not, with what is compatible my bcm with things written before?
I apologize if I ask too many questions and if I am heavy sometimes, but I would like to do many things and unfortunately I do not know anyone able to do them. I thank you for everything already now. I'm sorry [emoji23][emoji23]
The way they are installed ... some things will work and others will not.
My actual bcm is compatible with coming/leaving home (NO), folding mirrors (maybe), instrument cluster mfa+ (YES), automatic lights (NO), rain sensor (for the windshield wipers (YES) and to have the windows automatically closed in the event of rain (maybe)) and anti-glare mirror (YES)? If not, with what is compatible my bcm with things written before?
firebulletz
Ok, to have coming/leaving home and automatics lights i have to change bcm.ciclo wrote:1- there is a way to install these buttons without changing bcm or buttons with 1k8?
The way they are installed ... some things will work and others will not.![]()
My actual bcm is compatible with coming/leaving home (NO), folding mirrors (maybe), instrument cluster mfa+ (YES), automatic lights (NO), rain sensor (for the windshield wipers (YES) and to have the windows automatically closed in the event of rain (maybe)) and anti-glare mirror (YES)? If not, with what is compatible my bcm with things written before? [emoji38]
6r0937088f or 6r0937087t are good also for steering wheel buttons? Or is only 7e0937090 compatible?
Your current BCM is known as High (it's not Max), well, since middle 2015 all BCMs High installed in new 6Rs and PQ25 family (other markets) are compatible for the MFSW backlighting. (new models)
2017 or 2018 BCM High (6R0...) from Russia or India are perfect and cheap for your 6R (no needs extra wires) in case you decide to buy one of second hand.
Plug ... coding .... and Play.
Maybe firegrafik can help you in this matter.
firebulletz
Ok. I need to know only what bcm i have to buy.ciclo wrote:Your current BCM is known as High (it's not Max), well, since middle 2015 all BCMs High installed in new 6Rs and PQ25 family (other markets) are compatible for the MFSW backlighting. (new models)
And if I decide not to add ch/lh and automatic lights, if i will change the buttons with 1k8 it will work with my bcm 6r0937087k with the two additional cables or i could have other problems?
firebulletz
[/quote]
VCDS?
Autoscan?
radio pics?
[/quote]
this is the vcds autoscan... i think i have a big problem
VCDS?
Autoscan?
radio pics?
[/quote]
Tuesday,20,February,2018,18:53:57:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY080849 License Plate:
Mileage: 210660km-130898mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCY080849 Mileage: 210660km-130898miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MA HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 8849
Revision: --H33--- Serial number:
Coding: 00114016002400080000
ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 71E8ED58A0A91BCE75-8024
Readiness: 1100 0000
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417500B2842D14E682DA00421100
VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326A22546D2F60D64C-8066
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 237113707
Coding: 3CB02BBF08A10000003808006D2B0CD00080412F60860060200000000000
Shop #: WSC 124697 483 00190
VCID: 45806988CCA1E76EF9-8010
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU025081100010210
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001091100015461
Coding: 08BC30
Subsystem 3 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001436780076301
Coding: B0FFFF
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Serial number: KU0KU017081100014087
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Serial number: KU0KU030081100014426
Coding: 08BC32
4 Faults Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 127
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 109
Time Indication: 0
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 109
Mileage: 210095 km
Time Indication: 0
Date: 2012.07.05
Time: 00:00:21
00975 - Heated Rear Window (Z1)
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 210105 km
Time Indication: 0
Date: 2012.07.05
Time: 20:27:05
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00UZUX8
Coding: 003232
VCID: 4A9A5AB4EDBF081614-801E
Serial number: 3575HRB40690OCUIB06N
Serial number: 3585HRB40690OCUIDPHJ
Serial number: 3515RRB405B0M98E4981
Serial number: 3525RRB40650MFP6O92Q
1 Fault Found:
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 111
Reset counter: 95
Mileage: 209589 km
Date: 2018.02.03
Time: 10:57:17
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H04 0206
Serial number: 00000008663469
Coding: 140A00
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 3A7A0A74BD5F989684-806E
2 Faults Found:
13893888 - Function Restricted due to Exessive Voltage
U1401 00 [008] - -
Fault Priority: 6
Fault Frequency: 3
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 210095 km
Date: 2018.02.12
Time: 00:00:09
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002200
VCID: 70EEE85CA3A312C67A-8024
2 Faults Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 128
Reset counter: 255
Time Indication: 0
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 202439 km
Time Indication: 0
Date: 2012.02.17
Time: 11:35:30
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 0014
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
ROD: EV_ImmobUDSJCIPQ25.rod
Coding: 11230
Shop #: WSC 00788
VCID: 2F6C2B20EA1D4D3E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:52)--------------------------
You don't have a big problem, you have many small problems ...
Nevertheless some faults in that autoscan are intermittent or were not cleared.
It's clear that something in the electrical installation of your non-OEM radio was not or is not connected correctly, maybe the CAN Bus module. I thought I saw something related to its configuration through the menus in the previous videos.
As I told you, the MFSW buttons are connected correctly. Maybe you should try A4FFFF coding instead of B0FFFF coding, but it's just in trying to make something work, maybe it'll not even have any effect.
Buy the appropriate parts. (already explained)
firebulletz
There is tutorial for this a4ffff coding?ciclo wrote:You don't have a big problem, you have many small problems ... [emoji38]
What is the appropriate parts? I don't remember
firebulletz
I apologize if I repeat and if I am insistent, but I would like to be sure before buying.
What i have to buy, 7e0937090 (or 7h0937090?) or 1k8 steering wheel buttons?[emoji23]
You can buy a compatible 6R0 or 6RD BCM (2016 --->) to avoid having to make modifications to the wiring. This will make the steering wheel backlight work.
You can buy some Stalks without TRIP computer buttons. This will avoid incompatibilities with the buttons on the steering wheel.
You can buy the 1K8 buttons. They are the correct ones.
You can buy an IC with MFA +. This will make all buttons useful.
Read my previous replies.
spacewalker
- Drives: Just a VW
End of February I will update my module to be compatible with PQ25 platform.
After new update you can run any MQB MFSW and operate CCS too (with ccs or acc,) or basic just to MFA and radio
also you can run PQ35 MFSW
No need to replace BCM to highline , keep old one
all you need is a require wires for CCS and LIN to corresponding with MFSW over SlipRing
cars with external BT module like 3C8 or 7P6 require extra emulator (this is BT issue) but is already sorted
2 configurations available (all is tested in PQ35 platform durring last 2 years)
-cars w/o externall BT or with RNS 315 (built in BT) or MIB for PQ platform - no need HighLine BCM and not require Emulator
-cars with external Bt such as 5K0 , 5N0, 3C8, 7P6 , 1Z0 .... require HighLine BCM and extra emulator
With my module you can operate radio even if you not have MFA+ cluster
any questions, you can ask below or PW message
Hi spacewalkerspacewalker wrote: Fri Feb 23, 2018 6:10 am End of February I will update my module to be compatible with PQ25 platform.
This is great for the PQ25 platform. I want it (of course).
With MQB do you mean 6C MFSW too? Just to clarify doubts.
Now I send you some information by private message.
