Vento ~ Polo Sedan 1.5 Tdi RHD
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
I have added two Butt terminals in the steering column ring wiring to prevent you from having to remove the fuse box in case of other retrofits in the future. The fuses will remain the same (like in the pic).
I don't have the updated fuse assignment for Vento 2018 MY J (your case), but the following links will be very useful for you:
You must bear in mind that for the creation of your new wiring I must adapt it to the existing circumstances. (fuse slots available)
Recommendation: Save all the information in a folder, I also have it if you lose it (of all the electrical installations that I made for all those who requested my wiring).
Shortly I send you my email by private message so you can contact me.
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
Sure, I will wait for your PM. Thanks.
Check your inbox
I forgot to tell you that the wiring for the steering ring is a gift. :)
The price is as indicated here: :arrow: 135 € + shipping cost.
Shipping costs (SP-IND): 600gr approx = 25,20€ :shock: ( :arrow: pg 5, certificated)
Total = 160 €
sshakthi123
ciclo wrote: Thu Jan 10, 2019 7:27 pm Check your inbox
Total = 160 €
Thank you very much Ciclo. I had sent an email as well as PM.
sshakthi123
Ciclo,
One doubt rise up, this wiring supports single side park option right. Just wanted to know.
Also you will share other coding updates after the BCM adaptation I believe. Please confirm.
Thanks much,
Sakthi
Yes to both questions.
Read the first page of my thread (links) ...
But don't code anything posted there until you check that all the lights work correctly with the new BCM coding posted here in your thread.
Otherwise, I will ask you infinites Autoscans to be able to answer to your future questions... :lol:
sshakthi123
ciclo wrote: Fri Jan 11, 2019 7:15 am Yes to both questions.
Got it. I'll follow it and ask for queries. Thanks.
sshakthi123
Ciclo,
I tried mapping fuse terminals A/B ahead of actual installation. I felt difficult in finding a / b mapping in my fuse carrier. Can you assist circling the terminals?
Thanks,
Sakthi
https://drive.google.com/file/d/0B2nv91 ... 9WUzA/view
A or B is indicated on the back of the fusebox, near to slots. You must separate / move the wires to see the correspondence (it is not easy to see, help yourself with a flashlight).
Do not assume that it is the same position A or B in the same row of fuses. You should check these positions in each fuse slot on the back.
Click on the link of installation guide where it says180º. It will help you.
sshakthi123
Hello Ciclo,
Successfully installed the BCM and other parts as planned. Checked all the lights and electronics and it works fine.
However getting below mentioned errors. Also attached the latest auto scan report. Please help me fixing it.
Issues facing
1. Auto close windows not working (kept the windows down and locked the car. It left the windows as it is though I set the one touch up and down already)
2. CH/LH - light switch in auto, wiper setting in auto, masked the rain sensor to check in daytime. Got down the car and locking the remote is not lighting up. However unlocking the car glows up the light. Tried by keeping the headlight stalk to both high beam and low beam.
3. Auto close windows on detecting rain in running or in park mode NOT working
4. Single side park stalk is not working
5. Central electronics errors for DRL bulbs
6. Steering angle sensor calibration error
low priority
7. DRL's going off when parking/headlights on. If possible I prefer leaving it ON always so I will have better illumination on the road.
8. DRL is NOT going off upon indicator (pls provide coding for turning this on/off on enabling indicator. Based on my likes I will turn this on or off)
9. Dimmer - I thought it will dark off completely. Is there a way to control more darkness?
Also need a list of additional features that can be enabled from this BCM max
Scan report,
Tuesday,19,February,2019,08:05:36:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 8854-NEW
Mileage: 18060km-11221mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118   Mileage: 18060km-11221miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2F63212A04C50615F46A845920020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Serial number: 03111813470922
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Date: 2015.05.30
                    Time: 14:12:49
                    Voltage terminal 15: 12.20 V
                    Voltage terminal 30: 12.40 V
                    Terminal 15 status: On
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 222180856
   Coding: 3B904BFF48A10000013806407EEB96904980600F608C2141220000030000
   Shop #: WSC 12345 123 12345
   VCID: 2C57B2B24F0B312494-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 290617 04  42  0106
   Coding: 066800
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2521
   Serial number: 13202848170704050535
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2521
   Serial number: 13102849170705002249
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1811713320101504AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1522
   Serial number: 13102728170704212031
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1522
   Serial number: 13102729170630002341
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
   Part No SW: 7E0 919 475 K    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231325304021
   Coding: 308002
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3A7B84EABD5F9F9416-806E
   Revision: --------    Serial number: 003GW01BGFS-
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D12EE2C5161CBD-801E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002300
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H01 0217
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R8103103
   Coding: 0E000440000010
   Shop #: WSC 12345 123 08192
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:27)--------------------------
Few pictures below taken during installation. I will add up the output pictures once done with the coding.
ImageImage ImageImage
I would like to thank everyone who had helped me to come this long way. Especially Ciclo who helped making wires though he discontinued it. Thanks again.
Best Regards,
Sakthi
Hi, once I've read everything you've written (wtf?😂), it's clear that you don't know how some lights or systems work.
Why have you modified the BCM Max coding that I proposed? It is not necessary to answer this question.
-this coding: (my proposal)
3A904BFF48A10000013806406FEB96904980600F608C2141220000030000
-It's not like this: (your current coding)
I'll provide you a minimal assistance in those parts that are not related to BCM adaptation or automatic lights. You were warned about this several times.
Step by step to avoid confusion:
sshakthi123 wrote: Mon Feb 18, 2019 6:30 am 1. Auto close windows not working (kept the windows down and locked the car. It left the windows as it is though I set the one touch up and down already)
Make sure again that the window comfort feature (one touch) is set for all doors. (user's manual, owner's manual)
You must keep the remote control lock button pressed. Report the result.
2. CH/LH - light switch in auto, wiper setting in auto (It is not necessary), masked the rain sensor to check in daytime. Got down the car and locking the remote is not lighting up. However unlocking the car glows up the light. Tried by keeping the headlight stalk to both high beam and low beam.
It's how it should work.
Remember the Coming Home function is semi-automatic.
- Take out the key from the ignition switch.
- pull from the High Beam lever/flash once.
- open the driver's door and the lights should turn on.
sshakthi123
Hi Ciclo,
ciclo wrote: Tue Feb 19, 2019 1:33 pm Hi, once I've read everything you've written (wtf?😂), it's clear that you don't know how some lights or systems work.
The intention behind changing the coding is to enable emergency flashers and switch off parking lights when DRL is active. If at all require I can revert to your coding. Rest of the options I didn't change.
ciclo wrote: Tue Feb 19, 2019 1:33 pm I'll provide you a minimal assistance in those parts that are not related to BCM adaptation or automatic lights. You were warned about this several times.
I'm pleased. Thanks.
ciclo wrote: Tue Feb 19, 2019 1:33 pm Step by step to avoid confusion:
Verified once, the comfort feature is all set. One touch up/down works fine from driver door switches, also the remote operation works fine.
Thanks,
Sakthi
Please, keep calm for the rest of supposed issues, at this moment my internet service provider is giving me a low quality signal instead of the one I have contracted.
We all know how difficult it is to do something in these conditions.
sshakthi123
sure :|
