Heated mirrors and heated rear screen
stevo8375
Drives: Polo Gti
Re: Heated mirrors and heated rear screen
Post by stevo8375 »
amer6R wrote: Tue Feb 28, 2023 8:59 am Mine had cloth tape but the wires were broken. Why dont you try taking some measurments on the defroster grid
You dont have any errors stored in bcm?
What happens when you turn the knob on the mirrors to defrost position?
Maybe it’s worth me opening the cloth tape then and seeing the condition of the loom
No errors in central electronics
If you turn the heating in for mirrors nothing happens, no voltage at mirror glass and I’ve tried the fuse and a new switch
Id give it a go
But in 99% it would return a fault dear defroster open circuit
Sorry maybe you mentioned it, but did you buy the car like this or it worked in past?
stevo8375
Drives: Polo Gti
Post by stevo8375 »
No it’s never worked since I got it
Check in Long coding if it's enabled. - Maybe there is an wire-ing connections and someone disabled the option so it doesnt pop a dtc fault.
I think under adaptations you can set the timer for how long the defrost function is going to be ON.
viewtopic.php?t=75392&start=45
check ciclos post
stevo8375
Drives: Polo Gti
Post by stevo8375 »
amer6R wrote: Tue Feb 28, 2023 12:57 pm Check in Long coding if it's enabled. - Maybe there is an wire-ing connections and someone disabled the option so it doesnt pop a dtc fault.
check ciclos post
Thanks for your help, I’ll have a look and see what I can find 👍🏻
stevo8375
Drives: Polo Gti
Post by stevo8375 »
On long coding it says
Rear window heater activation via can Active
Mirror heating on while rear window heating on Active
Rear window heater Installed
Heated mirrors Installed
The long coding part is good, no one disabled it.
Id give that loom a look.
so fuse 24 is new
and fuse 53 new
There is a earth connection point on left C pillar for the rear boot lid electronics
stevo8375
Drives: Polo Gti
Post by stevo8375 »
Your a legend, I’ll have a look at the loom..might weekend before I get chance
stevo8375
Drives: Polo Gti
Post by stevo8375 »
I’m at a loss, I’ve checked the loom to the tailgate and it’s fine, no broken wires. Changed the fuses again just in case and still nothing. It’s all very strange
All other tailgate electrics are working fine
Hmm,
I'm not sure. If there is a fuse for the BCM on the fuse holder that is on battery.
What do you think about disassembling the fuse box on battery 10 mm nuts an clean it very well ( sandpaper or wire wheel). Also clean the contact on the small fuse box ( its sits clipped) I had an issue no-communication to module because it was a bit dirty ( high resistance)
stevo8375
Drives: Polo Gti
Post by stevo8375 »
Mine is the gti version so the battery is located in the boot, there are some electronics in the engine bay and also some (I think) attached to the side of the battery. Not 100% sure.
stevo8375
Drives: Polo Gti
Post by stevo8375 »
I was just reading an old thread regarding the heating of the mirrors, could it be a combination of bit 2 and 3 in the long coding as to why mine arent working do you think?
viewtopic.php?t=78020
Do a full autoscan and save it.
Also save long coding from you BCM. ( So you have double backup).
Then edit those two bits. If it doesnt help you can always revert to old settings.
Yeah you will still have fuses under the bonnet as far as i know.
