Hi Lucas, you can speak to Madwarlock here:
viewtopic.php?f=56&t=74496&p=567175#p567133
Dazzyboy81
Drives: Transporter
Post by Dazzyboy81 »
Hi circlo
Well I’m still trying to sort my bi-xenon headlights no auto lights!
I wondered if I run though where I am you could possible help me I have spent hours reading post after including all the post with grayscott and I’m so confused??
Thanks again
I guess the best thing is to get help from someone who has already done this installation and who lives near you.
bropasiek
Drives: Caravelle T5.1
Post by bropasiek »
Hi Ciclo,
Sorry to bother you again
I am about to finish off my van, however I still dont have HBA mirror, so I want to leave all wires ready
For instalation without HBA autolights relay is triggered by T73a/1, should that wire stay there and be connected with wire that comes from fuse box for HBA or what to do to get autolights working ?
What is the best place to take feed for footwell lighting?
Thanks for help with getting cruise control emulator
bropasiek
Post by bropasiek »
Hi Dazzyboy,
If you not far away from Leicester I can help you out
reido80
Drives: VW t5.1 GP bitdi 4motion
Post by reido80 »
ciclo wrote: Sat Oct 03, 2020 3:53 am Hi reido80,
According to ETKA it is 4H0973712A
...although it seems identical to 4B0 ... ... A
Thank you very much for the explanation and images.👌
Cool, I have more pictures to put up later.
Received the 4B0 plug today and it looks good, I dont suppose you know the VW part number for the flexible rubber boot that will fit the 4B0 plug? I cant access the parts diagrams at the moment.
bropasiek wrote: Wed Oct 07, 2020 12:00 pm Hi Ciclo,
Hello bropasiek
T5 Diagrams https://drive.google.com/file/d/1z_-f0C ... sp=sharing
T6 Diagrams https://drive.google.com/file/d/0B2nv91 ... sp=sharing
The relay for automatic lights is not necessary with electrical installation T6, which is the correct one for HBA. The electrical installation T5 is not suitable for HBA.
The BCM coding takes care of activating the automatic lights once everything is wired as in the diagrams for T6, as I explain here: viewtopic.php?p=575865#p575865
Footwell lights:
+ve T73a/65
-ve T73a/4
Ambient lights: (LEDs recommended)
+ve T73b/4 (before or after dimmer)
-ve any Ground point.
reido80 wrote: Wed Oct 07, 2020 2:32 pm I dont suppose you know the VW part number for the flexible rubber boot that will fit the 4B0 plug? I cant access the parts diagrams at the moment.
:arrow: viewtopic.php?p=466570#p466570
You will have to investigate which one is correct for that connector. (hole diameter, etc)
bropasiek
Post by bropasiek »
Hi Ciclo,
For 7E0 stalk and HBA
Do I need 7E0...90 ?
Or 7H0...90 will do the job as well ?
Everything is pre wired and ready for HBA once mirror with camera arrive like on diagram you send me, just different fuses SB18 and SB22 for HBA feed, SB6 and SB28 for high beam
Footwell lights work great !!!
Not sure now if they connected before or after dimmer as I was keep swaping wire from one to another
One way they lights up only when doors open other way they lights up when is dark like ambient lights
Once again thanks for help, yours knowledge is priceless when retrofitting anything
I have quite a few pictures from my retrofit, but I think they will be more useful for someone who will be retrofiting T6 dash rather then xenons + auto lights
bropasiek wrote: Sat Oct 10, 2020 3:02 pm Hi Ciclo,
yes, it is mandatory and safe for driving. Anything else doesn't make sense.
The lever return spring is what makes the HBA function automatic once activated.
bropasiek
Post by bropasiek »
I meant if 7H0.. 90D BCM will work or it must be 7E ... BCM
Ah, sorry.
What is certain is that the HBA function was introduced with the 7E0937090 BCMs in T6.
Anyway, you can check it by modifying channel 53 to value 1. Either you will have errors indicating that the Light Assist is not available (or similar) or the icon will appear on the IC, otherwise the 7H0937090D does not support HBA.
We await your test results.
reido80
Post by reido80 »
Hi folks,
So, the new clutch has been fitted and the van has moved under its own steam for the first time since June :D
Level sensors are fitted but I cant seem to clear the fault codes for it.
I have attempted to run basic settings but have been unable to do so. VCDS shows an error message (which I will screenshot tomorrow).
scan from today below -
Thursday,22,October,2020,11:47:12:03258
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0   License Plate: POST CLUTCH 1ST DRIVE
Mileage: 130870km-81318mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 56 69 0B
VIN: WV2ZZZ7HZDH0   Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 GK    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H37 3566
   Revision: 22H37---    Serial number: 00000000000000
   Coding: 0119401A233600080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
   ROD: EV_ECM20BTD01103L906019GK_003.rod
   VCID: 7AADF0A04C5F927B1C7-802E
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD19A6089626A99878BA6610
   Shop #: WSC 02756 790 49152
   VCID: 392F2FAC0959596355D-806C
   Part No SW: 7E5 907 047 BG    HW: 7E5 907 047 BG
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 75B7E39C6541FD03715-8020
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0725
   Revision: B9074001    Serial number: 0671 186141457
   Coding: B8B07DB84E61241193284EF16CAB9751F28066FF40857841320000020000
   Shop #: WSC 02739 790 12345
   VCID: 2F3B11F4C71D87D3FB9-807A
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 201114 05  54  0403
   Coding: 0630AD
   Subsystem 2 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3313
   Coding: 050000
   Subsystem 3 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3313
   Coding: 050000
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0390005
   Coding: 820000
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261217200384
   Coding: 118001
   VCID: 392F2FAC09D9596355D-806C
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00CRH9K
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3537239C25C1BD03B15-8060
   Part No SW: 7E0 920 970 G    HW: 7E0 920 970 G
   Component: KOMBI         H06 0605
   Coding: 160E01
   VCID: 2E050CF0C0978EDBF0F-807A
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411EED892DB348B16B-8070
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0725
   Revision: B9074001
   Coding: 042300
   VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
01304 - Radio
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 22
                    Mileage: 130877 km
                    Time Indication: 0
                    Date: 2015.02.25
                    Time: 01:08:43
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000007
   Shop #: WSC 02756 790 00000
   VCID: 372B2994334D4F13A39-8062
   Component: IMMO          H06 0605
   Serial number:
   Shop #: WSC 12345 123 12345
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6A8DC0E03CFF22FBEC7-803E
   Revision: --------    Serial number: --------------
   Coding: 0222000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77ABE9947F4D8F13639-8022
2 Faults Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 238
                    Mileage: 130877 km
                    Date: 2020.10.21
                    Time: 04:32:50
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Timeout mNiveau_2]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 238
                    Mileage: 130877 km
                    Date: 2020.10.21
                    Time: 04:32:49
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00008030224120
   Coding: 410D000101000000
   VCID: 313F178CD1299123EDD-8064
End----(Elapsed Time: 02:18, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Hi reido80
New coding
55 Address
0226000001000000
(I guess the chassis type - in Byte1 - is well coded by you for your T5) :?:
Maybe you need to enter a SA first to run the basic setting.
reido80
Post by reido80 »
Hi Ciclo, Thanks for your reply..
I have put in that code and entered the security access, it has not enabled me to run basic settings and the fault code reappears right after after they are erased.
The chassis is correct as far as I can work out. It is the only choice for AWD (4wd). I changed this to a 2wd chassis and tried again but it was still the same. What difference it makes is anyone's guess as the rear sensor is in the same location regardless of if its a 2wd or 4wd?
The warning shows this-
ERROR: Conditions not correct or request sequence error.
There is another option is the drop down for basic settings-
IDE01475-Resetting of all adaptations
I am reluctant to do this as when it is selected it shows the following.....
WARNING
Resetting adaptations in this module is likely not reversible, and reparameterization may require the dealer tool with online connection.
