Posted: Sun Oct 04, 2020 1:16 pm
Hi Lucas, you can speak to Madwarlock here:
viewtopic.php?f=56&t=74496&p=567175#p567133
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Cool, I have more pictures to put up later.ciclo wrote: Sat Oct 03, 2020 3:53 am Hi reido80,
According to ETKA it is 4H0973712A
...although it seems identical to 4B0 ... ... A
Thank you very much for the explanation and images.![]()
bropasiek wrote: Wed Oct 07, 2020 12:00 pm Hi Ciclo,
Sorry to bother you again
I am about to finish off my van, however I still dont have HBA mirror, so I want to leave all wires ready
For instalation without HBA autolights relay is triggered by T73a/1, should that wire stay there and be connected with wire that comes from fuse box for HBA or what to do to get autolights working ?
What is the best place to take feed for footwell lighting?
Thanks for help with getting cruise control emulator
reido80 wrote: Wed Oct 07, 2020 2:32 pm I dont suppose you know the VW part number for the flexible rubber boot that will fit the 4B0 plug? I cant access the parts diagrams at the moment.
yes, it is mandatory and safe for driving. Anything else doesn't make sense.
Thursday,22,October,2020,11:47:12:03258
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZDH0 License Plate: POST CLUTCH 1ST DRIVE
Mileage: 130870km-81318mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 56 69 0B
VIN: WV2ZZZ7HZDH0 Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GK HW: 03L 907 309 L
Component: R4 2,0L EDC H37 3566
Revision: 22H37--- Serial number: 00000000000000
Coding: 0119401A233600080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7AADF0A04C5F927B1C7-802E
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD19A6089626A99878BA6610
Shop #: WSC 02756 790 49152
VCID: 392F2FAC0959596355D-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 75B7E39C6541FD03715-8020
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0725
Revision: B9074001 Serial number: 0671 186141457
Coding: B8B07DB84E61241193284EF16CAB9751F28066FF40857841320000020000
Shop #: WSC 02739 790 12345
VCID: 2F3B11F4C71D87D3FB9-807A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 201114 05 54 0403
Coding: 0630AD
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3313
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3313
Coding: 050000
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0390005
Coding: 820000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261217200384
Coding: 118001
VCID: 392F2FAC09D9596355D-806C
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00CRH9K
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3537239C25C1BD03B15-8060
Part No SW: 7E0 920 970 G HW: 7E0 920 970 G
Component: KOMBI H06 0605
Coding: 160E01
VCID: 2E050CF0C0978EDBF0F-807A
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2411EED892DB348B16B-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0725
Revision: B9074001
Coding: 042300
VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 22
Mileage: 130877 km
Time Indication: 0
Date: 2015.02.25
Time: 01:08:43
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 B HW: 09N 907 554 B
Component: Haldex 4Motion 6008
Coding: 0000007
Shop #: WSC 02756 790 00000
VCID: 372B2994334D4F13A39-8062
Component: IMMO H06 0605
Serial number:
Shop #: WSC 12345 123 12345
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC0E03CFF22FBEC7-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0222000001000000
Shop #: WSC 02757 790 50316
VCID: 77ABE9947F4D8F13639-8022
2 Faults Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 238
Mileage: 130877 km
Date: 2020.10.21
Time: 04:32:50
13705473 - Databus
U1121 00 [137] - Missing Message
[Timeout mNiveau_2]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 130877 km
Date: 2020.10.21
Time: 04:32:49
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00008030224120
Coding: 410D000101000000
VCID: 313F178CD1299123EDD-8064
End----(Elapsed Time: 02:18, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
