Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
Post by VASILEIOS1972 »
ciclo wrote: Wed Feb 19, 2020 11:12 am No. PQ25 BCM cannot manage both functions at the same time in the footwell lights.
The only OEM solution is different lamps for each function.
Hello Fernando , I am trying to find information for front foot lights installation but I can't , where is this thread ?
Regards
VV
VASILEIOS1972
Good evening my friend, tell me please , today we have very rainy day here in Greece , so I found out that lights(on) washer system do not function.
In vag com no errors or faults , I made out put tests in address 09 in washer pump relay and everything looks ok .
Is it possible washers pump became out of service ? What else to look ?
Regards
Vasilis
It's possible.
Check the windshield washer fluid level. :)
If I understood you correctly, the windshield washer system only works with the lights off, is that correct?
Were the new stalks you installed brand new?
VASILEIOS1972
ciclo wrote: Fri Feb 21, 2020 3:04 am It's possible.
Good morning my friend , the fluid level was max . Yes windshield washer system works perfect with lights on and of as always .
Stalks brand new. The problem is in headlights wisher system . They used to work only with lights on . Now with lights on works only windshield washer system .
Tell me is it possible to have differences between bcm high and bcm max in pin positions for headlight wisher system?
The matter that head light wisher system did not work, is something that I have not noticed until now .
Best regards
Vasilis
With the lights on, the headlight washer system is activated every five sprays of the windshield washer system.
VASILEIOS1972
ciclo wrote: Fri Feb 21, 2020 6:00 am With the lights on, the headlight washer system is activated every five sprays of the windshield washer system.
Yes my friend i know that
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
I have a suggestion. It is could be possible BCM has been reparametrised for headlights washer works not of each five windscreen washing but of each "long" windscreen" washing. I did that for mine.
VASILEIOS1972
firegrafik wrote: Fri Feb 21, 2020 8:28 am I have a suggestion. It is could be possible BCM has been reparametrised for headlights washer works not of each five windscreen washing but of each "long" windscreen" washing. I did that for mine.
So what must do to make it work
Regards
Vasilis
firegrafik
VASILEIOS1972 wrote: Fri Feb 21, 2020 9:09 am
Regards
Vasilis
Set the 42 adaptation channel of the 09 centr.electric to the value 1
Turn on the engine, switch on the headlights, pull the windscreen washer for at least 4 seconds.
It could be :lol: , but the value is 5 (as factory).
I made a log of the adaptation channels when I code it and loaded MKE in the Gateway. :wink:
VASILEIOS1972
firegrafik wrote: Fri Feb 21, 2020 9:20 am
Regards
Vasilis
Hello my friend, I did exactly what you told me, but nothing changes .
I put again the first value 5
What else must do to solve this problem.
Regards
Vasilis
It is not a matter related to adaptations or codifications, forget that.
Make memory and remember if you touched any electrical part related to the headlight wash pump when you made the headlight electrical installations or anything you did ...
Also check the condition of the pump and ducts.
VASILEIOS1972
ciclo wrote: Fri Feb 21, 2020 7:53 pm It is not a matter related to adaptations or codifications, forget that.
Ok , I will do those checks , but tell me why I do not have false or errors in vag com ?
Because the relay works and the pump cannot be diagnosed.
