Franciswat's Polo 6R 1.6 Bifuel
Re: Franciswat's Polo 6R 1.6 Bifuel
🐒 hmm
so... powertrain (old IC CAN lines)😁
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
Thank you very much Fermando.
I previously used can wires from stalk and I had same result. Do you will be any differences using old can wires of IC connector (ex t32/28 & ex t32/29) instead of can wires from stalk? They should be connected so I do not know if it may help.
Hi Francesco, it all depends on how the emulator software for your 6R is designed. Something strange is happening with the speed signal, some parameter, or perhaps several, must be modified.
Those who designed the emulator should be able to help you ... I'm sure they will be able to fix it.
Give them all the information, everything you've done so far, including the video. :wink:
Franciswat
Hi Fernando, Roman told me the emulator worked fine on an other Polo with same engine and BCM max installed so we really don't understand what the issue is. Further investigation is needed. I've to get a can hack from somewhere and report to Roman CAN's data.
Now, as I anticipated here are some pictures of my retroit of photocromatic mirror with RLS.
Start by removing old mirror from windshield (easy part). :lol:
Next step is removing the metal bracket which is glued to a ceramic disk on the windshield (difficoult part). :)
Let's first protect the car for the next work.
Mask the windshield to delimit the area where to work on.
Now with sandpaper disks we have to remove the ceramic disk on the windshield (eternal work). :lol: :lol: :lol:
The light at the end of the tunnel..
Using glass polish the windshield back to being perfectly clear.
I used a plastified adhesive to mask the area before painting with black glass primer from VW.
Within 1 hour from painting the new braket has to be glued to the windshield using epoxy glue from VW.
The following days we can remove the tape and add the wirings.
Here's the 6C photocromatic mirror with RLS.
Let's fit the RLS first.
And then mount the mirror. Job is done!
Rain sensor works fine.
https://www.youtube.com/watch?v=5QiEQHxVw4U
Photocromatic mirror works fine.
Light sensor? Tomorrow I will add automatic light wiring harness and will see. :lol:
Looks great! 8)
Thanks for all the images, an excellent post!
Franciswat
Thank you Fernando! :D
Today I've added automatic light wiring harness (thank you very much Fernando for your wiring diagram).
Everything works fine except for Coming Home; when I close the car the lowbeams don't light up.
VCDS settings seem OK. Leaving Home works correctly.
Have I always to manually flash before to get out of the car or it should work even without?
Thanks in advance.
Tuesday,04,August,2020,23:00:39:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210228E3217100B5842514E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BB808E1240093380E916CEB0FD9DAC0672F608D30D0200000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 080515 03  37  0059
   Coding: 028877
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 5 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20231629400567
   Coding: 108001
   Shop #: WSC 12345 123 12345
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B72ECAEB2FEE099FC-806E
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E00
   ASAM Dataset: EV_Komb_iUDS_VDD_RM09 A04113
   ROD: N/A
   VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_Komb_iUDS_VDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 002200
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 108097 km
                    Time Indication: 0
                    Date: 2014.12.26
                    Time: 22:57:23
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADC19EA8DE4A91157-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   ASAM Dataset: EV_HeadlReuglVWLWRPt 001004
   ROD: N/A
   VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlReuglVWLWRPt" (VW25)
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:20)--------------------------
Franciswat wrote: Tue Aug 04, 2020 10:11 pm
Thanks in advance.
Yes, CH is semi-automatic. It is mandatory, and it has great logic, but it is not what most people want.
Keep in mind that there are people who do not want to be the center of attention when they arrive at a place with their car at night and close the car. :lol:
Things of PQ25 platform (IC SW, BCM Dataset, RLS SW, Battery).
BCM
New coding:
Enable Byte23 Bit 0.
RLS
New coding:
0228DD
Franciswat
Thanks for the explanation Fernando!
Yes, it has much sense. :wink:
BCM
New coding:
RLS
New coding:
0228DD
Thank you for the coding, Fernando.
What do these change? :D
Can I just say I'm very impressed?
RLS coding 028877 -> 0228DD --> 77 to DD is the correction index for your windshield.
BCM byte 23 bit 0 will activate the output of T73b/4 for terminal 58 (wire to your dimmer) IIRC for your BCM 7E0
Franciswat
iichel wrote: Wed Aug 05, 2020 11:02 am Can I just say I'm very impressed?
Because of what mate? :wink:
Thank you for explanation Michael. :D
In simpler words for a inexperienced what does T73b/4 output activation lead? Thanks.
Franciswat wrote: Wed Aug 05, 2020 12:13 pm
In this case the very nice conversion of your windshield to RLS/dimming mirror mount.
The wire that feeds 12V to your dimmer (T6aa/3) needs to receive its power from the BCM. That's what T73b/4 does (or T73a/4, can't remember 100%).
Additionally, T73b/1 will now operate the relay that comes with your auto lights. This relay will feed the high-beam stalk, a function previously done by T17/4 (thick white/black wire).
It's the click you hear when the low beam engages.
Franciswat
Thank you very much Michael! That was possible only thanks to many informations you and ciclo provided on this forum. :D
The wire that feeds 12V to your dimmer (T6aa/3) needs to receive its power from the BCM. (...) It's the click you hear when the low beam engages.
Thanks now it's more clear for me! :D
Franciswat
Installing VW radio microphone
Great, these days it is almost an essential element for a safe driving.👍
Franciswat
Absolutely right Fernando :)
Today I changed roof aerial.
It was a nightmare. I followed Elsawin instructions but even If I was very carefull the roof had been a little damaged maybe because it's old and no more elastic as one time.. see last picture. Any idea how to fix it? :(
