Yes, I think so. But for me it's ok like this
Sure, I'm with you (always), my good and dear friend.
I told you because you have the ASSISTANS menu activated.
You did a great job when installed the Side Assist system, Hmm ... I would have preferred that you had installed the original isolation relay for the CAN lines instead of the two relays. Do you remember our email conversations?
However, it was a good idea.
You even have a special label in my mailbox
- RekinPoznan
- Drives: 6R
When BCM controls the can relay ? when you push the Side assist button to activate it ? , or this is automaticaly sellected above 40km/h ? then BCM set + to the can relay ?
When Side Assist working witheout correct ABS unit is not possible to brake on specified situation.So must be ABS instaled from 6C or from T5 , or T6 ?
I planned mount this set nex week , I`am on the way to collect the parts .
Chriss
Chriss
My set is activated by push button, but maybe you can find a set that will activate via the MFA+?
- RekinPoznan
- Drives: 6R
I think it is not necessary to connect the CAN lines to work as an indicator of lane capacity,(Stand alone can work beacose is only led indicators) but if there was an ABS pump that works with it, it would be possible to brake the vehicle in a specific situation. I wonder because ESP is still waiting (retrofit) for me or not to install a pump that Would it work if any would fit?
IIchel your set working below 40km/h ? when is activated via button ?
I wonder about the laser burning of the Side Assist logo in the mirror so as to remove the reflective layer , or mayby is plug&Play mirror insert with this logo from another car with this function.
Hi Ciclo,
I'm from Singapore (we drive on the same side as the British) and after reading your posts I have embarked on the project to retrofit xenon headlamps to my Polo GTI 6R that came with halogen headlamps. I have the BCM High p/n: 6R0 937 087 H.
I have purchased from Kufentec:
1) xenon adaptors: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
2) Autoleveling kit: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
I have purchased separately the following:
3) Xenon headlamps with cornering lamps
4) BCM Max p/n:7E0937090B
5) Ballasts for xenon headlamps
I have already received the Kufentec merchandise and have started installing the xenon adaptor kit.
BCM Max has not arrived yet.
Together with the headlights, I will also replace my GTI bumper with the original Polo R bumper. So my final setup is without foglights and I'm looking to replace my switch as well.
My question is:
For the xenon headlights to work perfectly i.e. high beam works without low beam on, DRL dims with signal etc, do I need customized harness that you used to make?
I understand that you have stopped producing harnesses.
Thanks for your assistance!
Monday,02,October,2017,10:58:44:27502
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116 License Plate: 2OCT2017
Mileage: 99610km-61894mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY312116 Mileage: 99610km-61894miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E99E02A0C274CE75-8024
Readiness: 1110 0101
Part No SW: 0AM 300 050 K HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2669
Revision: 00043014 Serial number: CU501309027085
Coding: 0000020
Shop #: WSC 00046 000 00000
VCID: 31695E02AB4234CE35-5106
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230248E3416E02B4C42612E382D740811700
Shop #: WSC 00788 648 00255
VCID: 071DD0DAB2465A7ECB-8052
Part No SW: 6R0 907 044 E HW: 6R0 907 044 E
Component: Climatronic H09 0609
Revision: V0000000
VCID: 35616A129C2A18EE69-8060
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 106112048
Coding: 3CB02BBF08A10000083808403C290CD020C041CF60060000200000000000
VCID: 428B01CEDDE4BF56DC-8016
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1611
Serial number: KU0KU024031100012688
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 1611
Serial number: KU0KU016031100015781
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 591 A HW: 7P0 959 591
Component: J245 PS72.015 H05 0006
Serial number: WOO1165901/
Coding: 081001
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0050759
Coding: 830000
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Serial number: KU0KU011041100017315
Coding: 08BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Serial number: KU0KU011041100013053
Coding: 08BC32
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag01E H09 0020
Revision: -------- Serial number: 003GZ000HCNK
Coding: 003145
VCID: 4C972FF6E7A0792626-8018
Serial number: 3575HRB40550HJHG9ON%
Serial number: 3585HRB40590HJHG919A
Serial number: 3515RRB405B0I4AG6OGL
Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 72EB910EA5C44FD68C-8026
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002300
VCID: 70EF9B06A3C87DC67A-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 130
Mileage: 98655 km
Time Indication: 0
Date: 2012.02.11
Time: 12:43:42
Component: IMMO H21 0320
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB896E8D14871634-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6D587AEA76223E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------I have purchased from Kufentec:
My question is:
Hi numberior, welcome.numberior wrote: Tue Oct 03, 2017 2:57 pm
My question is:
Yes. Open a new topic in 6R/6C forum section with the information (images) we need to help you.
I think the Kufatec xenon adapter harness is already good for the headlights. You just need the wiring for BCM Max
Thanks Ciclo and iichel,
I will open a new topic as soon as I take the pics.
benzinkopf
- Drives: 1.2TSI 105HP DSG7
wow! long time no see. great success ciclo and everybody! i saw iichel already way successful with the keyless entry!!! congratulations!!!
Glad to see you here
. Have you installed the Bixenon? and Light Assist?
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Hi Ciclo,
First, Congratulations for you Polo, amazing car!
Well, see if you can help me.
I own a Beetle 2.0T TSI with 06R 937 088F BCM
I wanna to install footwell lights (front and rear, but mostly in front) but i don't know if it is supported by that BCM and where to Pin it.
Do you have that information ? I saw in you post about rear positions (positive 65A and negative 4A, right?), but how about front lights ?
Hope you can help me
(sorry about my english, i'm from Brazil)
Thank you
benzinkopf
Yeah. the wiring ready. Just got my hands on the original bixenon. its 2nd hand without the ballast and xenon which i need to buy soon. The china replica for my testing last time works fine except the quality of light distribution really bad.ciclo wrote:Glad to see you here. Have you installed the Bixenon? and Light Assist?
On the light assist, No way i can proceed with that coz im still searching for the highline cluster and learning proper tool to do the swap. worst case now, no more new cluster from aliexpress. i’m stuck there for now. [emoji27][emoji17]
Fabio_89 wrote: Fri Oct 06, 2017 6:23 amHi Ciclo,
Thank you
Hi Fabio_89, welcome.
I hope you understand the following diagram:
My recomendation.
- Uses LED lamps.
- Connect to any point on the indicated wires (never near of the BCM connectors). The challenge to overcome is that these two wires are the same color for the Beetles.
The reference to follow are the pins of the dome lights.
In this way, by connecting the power to the wire going to T73a/65 and ground to the wire going to T73a/4 your footwell lights will work when opening the door.
The diagram is from the Beetle. (except my horrible sketch)
