pettman
Drives: N/A
Post by pettman »
Oh the button needs to be in the off position? As in, pressed out and the light on the mirror off?
http://www.vwgolf.org/interior_mirror-159.html
The diode is factory installed in the electrical circuit of dome lights when the anti-dazzle interior mirror is of the new models (without button).
It will only be necessary to install the diode if the mirror of the new models (without button) is installed in conjunction with dome lights without diode.
In summary, in old anti-dazzle mirrors that have a button the non-dimming function is manual (stone age), and in the new anti-dazzle mirror models (without button) the non-dimming function when turning on the dome lights or reversing is automatic.
pettman
Drives: N/A
Post by pettman »
Ok thanks.
My next thing I now need you for is coding
I have installed my 2 CAN wires, plugged in my new BCM Max, applied my old coding, and coded my keys, good news is the bus starts, and locks and unlocks which is fantastic.
However, I have a lot more faults and red on an auto scan, also have a dash light on telling me a bulb is out, when I didnt before.
Here is the before scan
Tuesday,22,December,2020,19:53:30:56750
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH089217   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZCH089217   Mileage: 54270km-33721miles
18-Aux. Heat -- Status: OK 0000
Address 01: Engine (J623-CCHA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X43 9133
   Revision: 26X43---    Serial number: 00000000000000
   Coding: 0125401A230400080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74B1D8C79E36F54B67A-8021
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1712
   Revision: 00H05V01
   Coding: 0014
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_A01_VW36.rod
   VCID: 3FDB47EBE7F066134A8-806B
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108724AD09AC089E24A49072AA6510
   Shop #: WSC 02756 790 49152
   VCID: 392F29F3F954482374C-806D
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000002
   Shop #: WSC 02756 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 6FBBD7ABF710D6939A8-803B
1 Fault Found:
9480465 - Control Circuit for A/C Compressor
          B10A9 11 [009] - Short to Ground
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 117
                    Mileage: 53807 km
                    Date: 2020.12.04
                    Time: 11:01:01
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0256
   Revision: BO047001    Serial number: 0429 003120305
   Coding: B8B0793A0A612403932848106C2B8FDC0000412F60840000300000000000
   Shop #: WSC 29469 123 104857
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 161012 05  54  0403
   Coding: 0330AD
   Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Coding: 010000
   Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No: 7E1 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 50000000000000789372
   Coding: E20000
1 Fault Found:
03304 - Response Closing Status of Rear Right Door
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 165
                    Mileage: 54127 km
                    Time Indication: 0
                    Date: 2015.05.11
                    Time: 20:11:32
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H06 0013
   Revision: --------    Serial number: 003HM001WJ4C
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 363522CFC8CAA75B99E-8063
   Serial number: 3495ZRB40690IAMCA9H$
   Serial number: 3505ZRB405T0IAMCI07$
   Part No SW: 7E0 920 970 E    HW: 7E0 920 970 E
   Component: KOMBI         H04 0305
   Coding: 760F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2C0100A70686ED8BFFA-8079
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2411E88762D625CB37A-8071
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0256
   Revision: BO047001
   Coding: 042300
   VCID: 70B9D4D7EAAEC96B832-8025
   Component: IMMO          H04 0305
   Serial number:
   VCID: 6A8DC6BFCCF233BBCD6-803F
   Component: Radio         541 5814
   Revision: --------    Serial number: VWZZZ4H6290655
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46D5520FB8AA37DB09E-8013
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 11
                    Reset counter: 123
                    Mileage: 53807 km
                    Time Indication: 0
                    Date: 2015.04.27
                    Time: 10:55:12
End----(Elapsed Time: 01:54, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Here is the BCM Max scan before any coding:
Tuesday,22,December,2020,21:00:31:56750
www.Ross-Tech.com
Chassis Type: 7E0
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 5F 61
02-Auto Trans -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Sporadic communication error 1000
10-Park/Steer Assist -- Status: Cannot be reached 1100
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Not registered 0001
22-AWD -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Address 08: Auto HVAC
Cannot be reached
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 145180214
   Coding: A0AC393A0A61341193284F746CEB8EF40F84710F60CC6D60330400230840
   Shop #: WSC 02762 022 100767
   VCID: 2B0303BB0308EAB3F60-807F
   Coding: 0330AD
   Coding: 010000
17 Faults Found:
00886 - Turn Signal Switch (E2)
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 229
                    Time Indication: 0
01758 - Bulbs for Brake Lamps
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
03433 - Terminal 30 for Backup Lights and Adaptive Lights
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
00975 - Heated Rear Window (Z1)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
01134 - Alarm Horn (H12)
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
01332 - Door Control Module; Passenger Side (J387)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2028.14.10
                    Time: 00:00:01
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 189
                    Time Indication: 0
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 189
                    Time Indication: 0
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 229
                    Time Indication: 0
04194 - Vehicle Status with Under-Voltage
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
Address 10: Park/Steer Assist
Cannot be reached
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 17: Instruments
Cannot be reached
Cannot be reached
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042305
   VCID: 6889BCB7D27E01ABDB2-803D
10 Faults Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2028.14.10
                    Time: 00:00:01
01315 - Transmission Control Module
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
01321 - Control Module for Airbags (J234)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
01324 - Control Module for All Wheel Drive (J492)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
01320 - Control Module for Climatronic (J255)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
01319 - Control Module for Distance Control (J428)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
03075 - Parallel Parking Assistance Control Module (J791)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
00381 - Databus Instrument Cluster
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 229
                    Time Indication: 0
03406 - Control Module for Battery Monitoring
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 229
                    Time Indication: 0
03158 - Control Module for Information Electronics 1 (J794)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
Address 22: AWD
Cannot be reached
Address 25: Immobilizer
Cannot be reached
Address 5F: Information Electr.
Cannot be reached
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B1A73
   Shop #: WSC 02762 790 00000
3 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
02252 - Generator
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Time Indication: 0
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 78
                    Reset counter: 225
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2004.14.21
                    Time: 04:41:42
End----(Elapsed Time: 01:15, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
And here is the final scan after my original coding has been applied.
Tuesday,22,December,2020,21:33:09:56750
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 5F 61 0B
Readiness: 0 0 0 0 1
   Revision: 00H05V01
   Coding: 0014
   Revision: 00H43001
   Revision: 00001009
   Coding: 0000000002
   Coding: 0330AD
   Coding: 010000
   Coding: E20000
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:27:46
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:27:46
Cannot be reached
Cannot be reached
   Coding: 760F00
2 Faults Found:
12727552 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Abstandsdistanzregelung: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Date: 2020.12.22
                    Time: 00:28:29
12653568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Allrad: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Date: 2020.12.22
                    Time: 00:28:29
   Coding: 0000031
   Revision: B9082001
   Coding: 042300
6 Faults Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:34
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:35
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:35
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:35
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:25:51
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:39
Address 22: AWD
Cannot be reached
   Serial number:
Cannot be reached
   Coding: 030B1A73
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:16:34
02252 - Generator
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:16:34
End----(Elapsed Time: 01:53, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Please may you help me with getting the correct coding setup correctly?
EDIT
I disabled the modules I didnt have previously and then did another scan, seems happier, still some faults, some old, some new.
Tuesday,22,December,2020,23:27:06:56750
www.Ross-Tech.com
   Revision: 00H05V01
   Coding: 0014
   Revision: 00H43001
   Revision: 00001009
   Coding: 0000000002
   Coding: 0330AD
   Coding: 010000
   Coding: E20000
2 Faults Found:
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 02:22:21
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 02:22:21
   Coding: 760F00
   Coding: 0000031
   Revision: B9082001
   Coding: 042300
   Serial number:
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 54271 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 00:15:34
End----(Elapsed Time: 01:45, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
What I dont get is I disabled the battery regulator installation and its still appearing in the list, I cycled the ignition a couple of times but seems to be there still.
Not sure how or why the open terminal ones are there?
How to remove Address 61 from the GW installation list:
1- Address 61 must be enabled in the GW installation list. Check it in address 19 - GW inst list.
2- Go to address 61 and code all Bytes to 00 Hex.
3- Return to 19 GW and disable address 61.
4- Go to autoscan and click on Gw installation list.
5- Click on clear all DTCs.
6- Click on Gw installation list again. Address 61 must have disappeared.
7- Click on Start to run a new Autoscan.
Everything else is correct, the open circuit BCM faults for Terminals 30 are normal, at the moment no additional coding is necessary.
To remove the two BCM faults you must do the point/step 1 indicated here :arrow: viewtopic.php?p=528735#p528735
... and the rest of the steps if one day in the future you want the lights to be under BCM control.
pettman
Drives: N/A
Post by pettman »
Thank you.
I plan to run the 2 cables next for my auto lights.
Unsure about the bulb out warning light on the dash though? Wasn’t there before...
The warning light on the IC is due to several possible causes due to improper electrical installation for BCM Max.
I suppose that in these cases the diagnostic tools endorse the saying of:
"It is better to be quiet and seem silly than to speak and clear doubts definitively" -GM-
pettman
Drives: N/A
Post by pettman »
Please may you elaborate on this?
I fitted the twisted CAN wire from the IC to the BCM as per instructions on page 4 of this thread, so I am not sure what "improper" electrical installation I may of done wrong?
Can you help/advise as to fault finding this? What is it you need?
EDIT
I have no reversing lights at all, so one will assume this is the cause, but since this BCM upgrade I have not touched that, I did previously for the old BCM to connect to the reverse light wire for the anti dazzle mirror. Ive checked all fuses and none are blown, so what would/could case them to be not working? I dont think there is any power going to them as my reverse camera which gets its power from the green/black wire in the rear is working.
pettman
Drives: N/A
Post by pettman »
T73b/12 is the reverse green/black I used before. Is this still correct for this new bcm?
Checked both bulbs and they are fine
I havent done this....
Reversing Light. Only with manual gearbox.
New 1.0mm2 wire from T73b/12 to T10o/3, beneath the driver's seat.
Remove & isolate original T10o/3.
Note: T10o is Blue color, the original wire is green/black. Use the multiemeter to be sure.
If you don't install this wire you'll have a fault in BCM diagnosis, which can be avoided by coding...
As it states for manual gearbox and I have DSG, or does this wire need to be done also? Reading earlier on in this thread other people seem to have the same suggestion, and that to activate the F4 switch now there needs to be a wire from T73b/12 to T10o/3, isolating the green/black original in T73b/12. Please do correct me if Im wrong, I fear that my 3 year old son could do this... :oops:
It is very simple, you must feed the pins T73a/63 and T73b/68 with the +30 signal........... as per instructions on page 4 of this thread.
Rückfahrlicht.
As long as you do not make this adaptation, it is an incorrect electrical installation for BCM Max.
pettman
Drives: N/A
Post by pettman »
Oh no it is that simple. I didn’t think from earlier that was necessary just yet and only for auto lights.
Running these 2 wires in will correct and fix the reverse light issue then?
This is where my future self looks back in dismay.
I will do this and report back.
pettman
Drives: N/A
Post by pettman »
Well you know what?
It worked.
Merry Christmas!
Merry Christmas :)
pettman
Drives: N/A
Post by pettman »
So with ignition on there are no bulb warning lights.
When I turn the headlights to sidelights I get an immediate bulb warning error.
Now these bulbs are LED can bus bulbs. But I am wondering if they are not happy with the new BCM? My dipped beams are normal halogen.
Any coding options for this? I didn’t have the issue on the old BCM
bropasiek
Drives: Caravelle T5.1
Post by bropasiek »
Hi Ciclo,
Thank you for a link with slip ring mod for heated steering wheel
I did one myself, maybe not as good as one from the link, but it does a job
It seems like an excellent job! 8) 👍
PS: I have the same summer flip flops, I think they are adidas.😂 (please forget this comment)
