retrofitting kessy to the Polo 6R
Re: retrofitting kessy to the Polo 6R
ag69 wrote: Tue Jul 04, 2017 9:16 am
iichel wrote: Tue Jun 27, 2017 1:17 pm So, some kessy update..
sir,
you are amazing.
bow down to your dedication and finding way to achieve this.
Bow to spacewalker, the man posting above here. He did the difficult part of learning the keys.
oscar89
Drives: none
Post by oscar89 »
iichel wrote: Tue Feb 28, 2017 7:28 pm updated VCDS coding
Tuesday,28,February,2017,13:53:50:62066
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN:   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          61 69 6C 77 0B
VIN:   Mileage: 0km-0miles
05-Acc/Start Auth. -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001041
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 2757FDE35E1F667988-8073
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: None
   Part No HW: 6R0 907 379 AF
   Revision: --------
   Coding:
   Shop #: WSC 00788 648 00255
   VCID: 55AB872B38F324E9EA-8001
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 000F0F
   Shop #: WSC 01342 020 12345
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 37772DA38EBFF6F918-8063
1 Fault Found:
1057799 - Antenna for Keyless Entry System in Trunk
          B1173 11 [008] - Short to Ground
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:03
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 38752E9F8BA1F98111-806D
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A073EFE08D78D020E050032800
   VCID: 68D5BEDF9B81A90141-803D
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 140415 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140002547420014516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B7F3193B297D299FC-806F
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A916457ED4D7B1177-801F
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 336F19B39AC71AD924-8067
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042201
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E5908C771E537314B-807B
   Component: IMMO          H04 0709
   Coding: 000007
   Shop #: WSC 09402 015 1048576
   VCID: 6AD1C4D78D8D9B1157-803F
2 Faults Found:
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:06
10493440 - Function Limitation due to Missing Enable from OCU/VTS
          B201E 00 [009] -  -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:41:05
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F6715C376EF3E3940-807B
2 Faults Found:
1048838 - Terminal 15
          B1148 12 [137] - Short to Plus
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 113
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:37:56
                    ELV State: 04
                    Information Clamps: 67 20
                    CoCo State: B0 01
                    WFS State: 10 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
1048840 - Terminal 15 Redundancy
          B11D6 12 [137] - Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 113
                    Mileage: 0 km
                    Date: 2017.02.28
                    Time: 01:37:56
                    ELV State: 04
                    CoCo State: B0 01
                    WFS State: 10 1A
                    Voltage: 68
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B5F01D34AF742196C-807F
Address 37: Navigation        Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Coding: 00070002010000A10001
   VCID: 366920A781B50FF103-8063
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH14 0120
   Revision: 00H14000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02757 790 00000
   VCID: 2F6715C3BEEF3E3940-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
   Subsystem 4 - Serial number: H21982ÿ
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6715C3EAEF3E3940-807B
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 2855FEDF5301690181-807D
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   VCID: 77F7EDA3CE3F36F9D8-8023
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Component: EU West V14  8477
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 03071A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F6715C37EEF3E3940-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65CBB7EBAC93B4697A-8031
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 113
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: 254BF7EB24137469BA-8071
End-------------------------(Elapsed Time: 05:08)--------------------------
result with normal ignition lock:
if ignition is on, it says in the segment display 'no key'.
also, if there is something wrong with the kessy it says 'check keyless'. very neat.
Car now unlocks when ignition is switched off, instead of key removal.
Problem with the converter box/BCM wiring: http://www.uk-polos.net/viewtopic.php?f ... 80#p518773
hello, i saw your post with the following fault code:
B201E 00 [009] - -
Fault Priority: 1
Fault Frequency: 1
Mileage: 0 km
Date: 2017.02.28
Time: 01:41:05
last week i changed my cluster with kessy from white/black to 3d from new scirocco facelift. now in the new cluster i get this error message to, how did you fix this?
Adapt keys to immo, that should solve it. I'm not sure why it's fixed for me, to be honest
oscar89
Drives: none
Post by oscar89 »
iichel wrote: Tue Jul 18, 2017 12:00 am Adapt keys to immo, that should solve it. I'm not sure why it's fixed for me, to be honest
keys were adopted, tested on the bench, only in the car i get this error?
oscar89 wrote: Tue Jul 18, 2017 12:38 am
Error returns after you clear it? Then maybe adapt keys in the car and not on the bench?
spacewalker
Drives: Just a VW
Post by spacewalker »
when you swap cluster to currently working keesy car , no need to do anything with key learn.
but when you rebuilt kessy , then must learn all ,even sometime ELV must be re-adapt
already told you what to do , but seems you waste my time and try to find other way to fix
:cry:
I'm happy to report that the keyless starting is completely working. Kessy module (address) coded is 000F0F.
The keyless entry is not working currently. The coding for this must be 03C0C0. Then it gives an error for the door handle (implausible signal, short to ground, open circuit).
Remember I have four kessy door handles, parallel mounted (front to rear).
I'll have to measure and check the wiring in the coming days.
The final adaptation of the keyless start was possible due to the xhorse iscancar MM-007 and the knowledge of the PIN and CS bytes.
It was a difficult trip so far, but I'm happy it's coming to an end. My big thanks to spacewalker for the support (time, effort and use of equipment).
I'll update when the wiring of the handles is checked.
Congrats!! :D Waiting for the update.
Remove front to rear door connections and all is well
Pave
Drives: 1.2 Tsi Highline 2011
Post by Pave »
Very nice :D
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Fantastic!
Before I've even start on this project - what are the requirements to the instrument/immobilizer? I have the 'small' one from 1.6 TDI...
Electronic steering column lock
Kessy module
Cluster from donor car
Two door handles
New keys
A lot of wiring :mrgreen:
An expert to help you out
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Cluster - one of the expensive parts... how much did this project cost you? (Both time and money)
:lol:
diskoboy wrote: Mon Aug 14, 2017 6:41 am Cluster - one of the expensive parts... how much did this project cost you? (Both time and money)
Oh I really stopped counting the time.
Money wise a wild guess:
ELV €50
Cluster €200
Kessy module €50
Door handles €100
Connectors €100
Keys €180
External expertise so far €100
The smile on your face when it all works out: priceless
