MaDwArLoCk
Posts: 165 Joined: Sun Jul 02, 2017 10:57 am
Drives: Cross Polo 2010 TSI
Post
by MaDwArLoCk » Mon Aug 21, 2017 9:53 pm
Hey Ciclo!
It's a MIRACLE!!!
When i open my car after work, was nice to see that LH working and when i start moving after few seconds BOOM and high beam emblem appears on IC
And everything is working now! Fog lights, high beam and dimmer!
Happy as never!
This BCM was from T5
Posts: 8913 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Tue Aug 22, 2017 5:05 am
Excellent!
At last!... your BCM and your
F * VCDS agreed on something.
Magic (or miracles) are jokes that others do not understand
, post a full autoscan
to share with others ...in the name of love.
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 8:43 am
Again not working! I suppose now High beam and Rear fog light works only at night!
Auto scan with new fault: 03789 - Terminal 75 Limp Mode Active - Limp mode?
Tuesday,22,August,2017,09:34:58:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZAU000000 License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56 77 0B
VIN: WVWZZZ6RZAU000000 Mileage: 157000km-97555miles
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 D HW: 03F 906 070 D
Component: SIMOS10.20H02 9851
Revision: -------- Serial number:
Coding: 001900D6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS02103F906070D 003015
ROD: EV_ECM12TFS_003_VW25.rod
VCID: 234234CE2A4EB859D4-8076
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 210228E3227300BA842C14E844D600401300
Shop #: WSC 31414 790 31414
VCID: 020C514A99945151FF-8056
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3878F3A28BC8CB8111-806C
2 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 14
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 52
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 017140713
Coding: 24B02BBF48E3240093300FB02CEB1ED011C0610E60042001200000010000
Shop #: WSC 02756 790 00000
VCID: 2D56D2F6748A7E2972-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 210310 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU028.04.1013935
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU030.04.1010613
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Subsystem 7 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU026.04.1016866
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU020.04.1013618
Coding: 08BC32
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 13
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 16:03:35
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 A HW: 7E0 919 475
Component: PARKHILFE 4K H10 0011
Revision: -------- Serial number: 64531012301615
Coding: 100003
ASAM Dataset: EV_VW250ParikAssis2 S01008
ROD: N/A
VCID: 3C70EFB2B7F0E7A1F5-8068
No ASAM data for: "EV_VW250ParikAssis2" (VW25)
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag00K H08 0020
Revision: -------- Serial number: 003GX002F4VI
Coding: 00304B
ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3572SRB40000B53459C7
Subsystem 2 - Serial number: 3582SRB40000B520C0C1
Subsystem 3 - Serial number: 3515RRB405D6QGG0HO90
Subsystem 4 - Serial number: 3525RRB405B6SD5OFPMN
No ASAM data for: "EV_AirbaVW10BPAWV250" (VW25)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 D HW: 6R0 920 860 D
Component: KOMBI H03 0207
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 3566FA9694DA36E90A-8060
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002200
VCID: 70E80B82A33853C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0207
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoU_DS_VDD_RM09 A03006
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_ImmoU_DS_VDD_RM09" (VW36 *)
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H21 6270
Revision: AB001001 Serial number: VWZ6Z7N8319084
Coding: 040104020100002C0001
Shop #: WSC 01357 011 00200
VCID: 3D76E2B6A4EAEEA9C2-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 D HW: 7P6 035 730 D
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668399469
Coding: 0A00000000010110
Shop #: WSC 05314 115 12345
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3362C48E9AAE28D924-8066
1 Fault Found:
0022 - Radio
U1066 00 [000] - No Communication
Intermittent - Not Confirmed - Tested Since Memory Clear
End-------------------------(Elapsed Time: 03:45)--------------------------
MaDwArLoCk on Sun Feb 04, 2018 8:38 am, edited 1 time in total.
Post
by ciclo » Tue Aug 22, 2017 10:27 am
Hmm...
Verify that
370 relay (J59 - X-contact relief relay) is properly installed. Push it.
All faults makes me think that this could be the problem.
If it is not the problem check the ignition switch connector T6. (T6/6)
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 11:15 am
ciclo wrote: Tue Aug 22, 2017 10:27 am
Verify that
Took it out and put it back! Not Helps
Just received my Xenon headlights:
MaDwArLoCk on Sun Feb 04, 2018 8:39 am, edited 1 time in total.
Posts: 6689 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Tue Aug 22, 2017 11:25 am
Sometimes terminal 75 is directly activated with terminal 15, or the other way around. But the wiring diagram is clear, T6/6 operates the x-relief relay.
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 11:25 am
Ignition switch connector?
i have checked Ignition switch connector - looks ok.
i tried to move/shake it - does no t help!
probably it's necessary to remove steering wheel to unplug this connector...
Post
by ciclo » Tue Aug 22, 2017 12:23 pm
Yesterday it worked, not today ... some connection / splicing / connector might not be OK ...
Post
by ciclo » Tue Aug 22, 2017 12:34 pm
Do not install the bixenon headlights until this problem is solved.
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 12:46 pm
ciclo wrote: Tue Aug 22, 2017 12:34 pm
OK.
Tomorrow I will take out steering wheel and check this connector!
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 2:25 pm
ciclo wrote: Tue Aug 22, 2017 12:23 pm
Does this diagram means that I have to use new cable from SB40 to J126?
I used existing connections from Climatic!
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 2:49 pm
MaDwArLoCk on Sun Feb 04, 2018 8:40 am, edited 1 time in total.
Post
by iichel » Tue Aug 22, 2017 2:55 pm
No, it's definitely wrong to isolate. It's connected to the N280 air conditioning pressure regulating valve.
N280 connects to T16i/4 (see diagram 26/5)!
Re-connect it..
MaDwArLoCk
Post
by MaDwArLoCk » Tue Aug 22, 2017 4:28 pm
iichel wrote: Tue Aug 22, 2017 2:55 pm
Re-connect it..
Thanks iichel! I will!
When you retrofit Climatronic, how did you realize power for ventilator motor?
Have you used an existing connection or made a new cable from SB40?
Post
by iichel » Tue Aug 22, 2017 4:28 pm
New wire to SB40. Isolate old wire.
