Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
more scans is always better
don't forget the headlight washer reservoir level sensor, it's one wire to the instrument cluster. it's a nice addition and you'll have it anyway if you buy the SRA reservoir + pump
i think the step-by-step approach makes sense to some extend, but maybe it's good to transfer all the cables from the cabin to the engine bay in one go.
in your case:
6 wires for LED headlight: 2x (T14/10, /12 and /14)
8 wires for ALWR: 2x (T14/1 /2 /3 and /4)
1 wire for SRA
1 wire for level sensor
16 wires
maybe make it a bit more if you ever plan to install heated windscreen, heated washer jets etc etc.
in your case:
1 wire for SRA
16 wires
- Turbodruk
- Drives: Polo 6R 1600 TDI Team
Thanks iichel,
The installment of the all the wiring looms in one go makes sense, yes.
We will talk soon ^^
Hmm. If I'm ever going to do a heated windscreen I'm going for HBA aswell.
This is not on my list currently, but when I have to replace the windshield, this becomes interesting.
A man can dream.
A man can dream.
- Turbodruk
Good afternoon ladies and gentlemen.
I've manged to put the cable from T6/3 to 10/10 into the auto light switch. The Polo is now error free.
A teaser for what's next:
6C Full headlights, with automatic height adjustment. With help from iichel ofcourse.
Also a OEM alarm will be fitted. If those two things are finished, I'll be looking into fitting R-Line bumpers and maybe headlight washer units, not sure about the latter.
Have a great (remaining) weekend!
Saturday,02,December,2017,12:46:13:51415
VCDS Version: 17.8.1.0 (x64) HEX-V2 CB: 0.4407.4
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008 License Plate: 7E0 0FAULTS
Mileage: 154520km-96014mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 61 77 0B
VIN: WVWZZZ6RZBY015008 Mileage: 154520km-96014miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 EP HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 9970
Revision: --H13--- Serial number:
Coding: 00114034002401080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023EP 003007
ROD: EV_ECM16TDI02103L906023EP_003.rod
VCID: 78A818B3A25FC6B7621-802C
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416E00B7842514E282D900521100
Shop #: WSC 02069 000 00000
VCID: 0654664BD86BA04760D-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 3536D187F54DFBDFB97-8060
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 116170197
Coding: 3CB029BF48A10000012807906CAB1ED15B80612F60842049200000030000
Shop #: WSC 54321 321 54321
VCID: 688848F3F27F5637F21-803C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180510 05 54 0403
Coding: 07302D
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0912
Serial number: KU0-KU020.05.1010960
Coding: 48BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0912
Serial number: KU0-KU018.05.1011444
Coding: 48BC30
Subsystem 4 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0033
Serial number: 0361915
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391012733298
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BA207BF9369EDAF0F3-802E
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00L H09 0018
Revision: -------- Serial number: 003DW00G103P
Coding: 00304C
VCID: 42DCBA5BB4035C670C5-8016
Serial number: 3572SRB40000B8408ACB
Serial number: 3582SRB40000B8185282
Serial number: 3516GRB401R9OICD64ET
Serial number: 3526GRB401T9OICCSB69
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 540800
Shop #: WSC 00788 648 00255
VCID: 3332EF9FFBB9E5EF973-8066
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Component: IMMO H04 0709
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8C32FBECF36427E45-803E
Address 2E: Media Player 3
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F3AE3EF1E51C10FF3B-807A
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3P0376022
Coding: 01000401020001
Shop #: WSC 00020 790 12345
VCID: 24101CC34ED772571E9-8070
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A5A
Shop #: WSC 12345 123 12345
Component: J367-BDM H07 0125
Serial number: 00000000002790237207
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665485869
Coding: 0810030080010110
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E04FEEB109BC807F8D-807A
End----(Elapsed Time: 01:30, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
- Turbodruk
Hello!
I managed to get a R-Line bumper for my beloved red Polo, which I fitted last week. Here are some pictures.
I installed the LED headlights and cabling with help from iichel, many thanks to him. I've run into some issues though. The DRL's are not working and high beams only work when pulling the stalk on the left side. Included is an autoscan. I've been told it has to do with the auto light switch iichel has fitted. I haven't had the time to retrofit the AFS module, I will be doing this, don't worry.
If someone has any idea what I did wrong I'd be forever greatfull to hear!
Thanks to all people here on the forum and have a very merry Christmas!
[Sunday,24,December,2017,17:15:32:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008 License Plate: TURBODRUK6CLED
Mileage: 156680km-97356mi Repair Order:
Gateway Installation List: 7E0 909 901
Sunday,24,December,2017,17:41:37:51415
www.Ross-Tech.com
VIN: WVWZZZ6RZBY015008 Mileage: 156680km-97356miles
Revision: --------
Revision: 00 11 25
Coding: 3CB02FF808090000012806E2FFEB1ED180A273EFE08958D0000000030000
Coding: 07302D
Coding: 48BC30
Coding: 48BC30
Coding: 020000
5 Faults Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 156682 km
Time Indication: 0
Date: 2017.12.24
Time: 17:37:50
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 52
Mileage: 156682 km
Time Indication: 0
Date: 2017.12.24
Time: 17:37:50
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 92
Mileage: 156682 km
Time Indication: 0
Date: 2017.12.24
Time: 17:20:18
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 92
Mileage: 156682 km
Time Indication: 0
Date: 2017.12.24
Time: 17:20:18
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 156682 km
Time Indication: 0
Date: 2017.12.24
Time: 17:13:38
Coding: 100001
Coding: 00304C
Coding: 540800
Revision: B9080001
Coding: 002200
Serial number:
Cannot be reached
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 12.5V/12.4V)-----------
if you try with....
3CB02DBF48A10000012807906CEB1ED15A80732F608D38F1200000030000
Good luck and merry Christmas too!
ah yes you probably copied my coding for a 4-door with high beam assist
I meant the coding that Turbodruk now has in his BCM. it's based on a 4-door model with high beam assist/return-to-center stalks.
Happy christmas Fernando, enjoy the holidays!
- Turbodruk
Guilty!
I've used the coding ciclo gave me, and the high beam and low beam work without hiccups! Truly amazing!
The DRL's are not working yet, not sure why, because there's zero faults in the autoscan.
Sunday,24,December,2017,21:50:24:51415
www.Ross-Tech.com
Revision: --------
Revision: 00 11 25
Coding: 3CB02DB848210000012807906CEB1ED15A80732F608D38F1200000030000
Coding: 07302D
Coding: 48BC30
Coding: 48BC30
Coding: 020000
Coding: 100001
Coding: 00304C
Coding: 540800
Revision: B9080001
Coding: 002000
Serial number:
Cannot be reached
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:30, VBatt start/end: 14.7V/14.9V)-----------
Are you sure your BCM 7E0 is for T6 with LED headlights?
However, you should check the DRLs with the hand brake DOWN... ...your BCM is coded so that the DRLs OFF when the handbrake is UP.
He bought a bcm with the same reference as mine, 090 Z4Y, should be ok
- Turbodruk
Hey Ciclo!
I was busy eating myself to death, and now I awakend from my slumber. Unfortunately the DRL’s are not working with handbrake off.
Thanks for your quick replies!
It may be necessary to add a 0.5mm2 wire from the auto lights wiring -made by iichel for you- to the BCM, from the coupling linking the new automatic light switch (T10/9) to the BCM T73b/29.
By the way iichel, please post here your diagram for auto lights wiring you sell.
I explain you:
This is your original connector, without wire (3) for the DRLs signal, this is because the Bluemotion with BCMs 6R0/7H0 use another signal due to the Start/Stop system.
(sorry... turbodruk ... without 'c')
Example diagram
The new BCMs 7E0 are parameterized in a different way, and this signal can be one of the parameters that were changed. Unknown to me and to most mortals.
I am convinced that adding this wire your DRLs will work, taking into account that the rest of the electrical installation for the DRLs is correct (from the BCM to the LED headlights) and that your BCM supports LED headlights.
I explain you:
Example diagram
Hi Fernando, I take the exact diagram as in your PDF for the auto light installation. I can confirm T17/3 is not wired in Turbodruks car.
I'm not sure whether the position lights are working in his car (DRL led in lower brightness).
In my Polo Bluemotion, the T17/3 wire is also not present but the LED DRL always worked well, both with bi-xenon and LED headlights.
