Vento ~ Polo Sedan 1.5 Tdi RHD
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
sshakthi123 wrote: Mon Feb 18, 2019 6:30 am
3. Auto close windows on detecting rain in running or in park mode NOT working
5. Central electronics errors for DRL bulbs
6. Steering angle sensor calibration error
low priority
7. DRL's going off when parking/headlights on. If possible I prefer leaving it ON always so I will have better illumination on the road.
9. Dimmer - I thought it will dark off completely. Is there a way to control more darkness?
3. It is very likely (99%) that your current WRMs don't have the right software for this function.
5. What model of bulbs do you have installed? LED bulbs?
6. Make the basic setting (in the correct way). ABS unit (address 03).
- security access 40168
- basic setting
- steering wheel 0º (Meas.Blocks)
- G85 adjustment. ON/OFF/Next
The adjustment will not be confirmed in your car until you close the address 03.
7. It's not possible. It is not a function for the DRLs. They are Day lights.
9. ??? :lol: No. You must drive with a minimum of lighting.
4,8 wait for a new BCM coding.
4. Single side park stalk is not working
8. DRL is NOT going off upon indicator (pls provide coding for turning this on/off on enabling indicator. Based on my likes I will turn this on or off)
3B904BFF48A10000013806407CEB96904980610F608C21C1220000030000
sshakthi123 wrote: Mon Feb 18, 2019 6:30 am Also need a list of additional features that can be enabled from this BCM max
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
viewtopic.php?f=56&t=58703&start=4020#p529332
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
Ciclo, I have updated the latest coding you sent. And here are the observations,
ciclo wrote: Tue Feb 19, 2019 5:03 pm 1. Auto close windows
It's still not working, but the comfort feature is all set.
ciclo wrote: Tue Feb 19, 2019 5:03 pm 2. CH/LH
Verified as you said. CH - semi auto, LH - both works. thanks.
ciclo wrote: Tue Feb 19, 2019 5:03 pm 3. It is very likely (99%) that your current WRMs don't have the right software for this function.
How do we make it work? windows not closing on rain / on lock.
ciclo wrote: Tue Feb 19, 2019 5:03 pm 5. What model of bulbs do you have installed? LED bulbs?
Osram LED 1141 1.2w bulbs
ciclo wrote: Tue Feb 19, 2019 5:03 pm 6. Make the basic setting (in the correct way). ABS unit (address 03).
- basic setting
I'm able to go in but the option steering wheel 0º (Meas.Blocks) is not found in the list. So unable to make these changes.
ciclo wrote: Tue Feb 19, 2019 5:03 pm 7. It's not possible. It is not a function for the DRLs. They are Day lights.
Ok
ciclo wrote: Tue Feb 19, 2019 5:03 pm 9. ??? :lol: No. You must drive with a minimum of lighting.
Ok
ciclo wrote: Tue Feb 19, 2019 5:03 pm 4,8 wait for a new BCM coding.
4 - It worked. I checked again. thanks.
8 - works. DRL goes off when the indicator is enabled. But I need an option to enable/disable this particular one. So need 2 set of codes, one with enabling it, other with disabling it. Please help.
So here is the updated list that is to be focused,
1. Auto close windows not working (kept the windows down and locked the car. It left the windows as it is though I set the one touch up and down already)
2. Auto close windows on detecting rain in running or in park mode NOT working
3. Central electronics errors for DRL bulbs
4. Steering angle sensor calibration error
5. DRL is NOT going off upon indicator (pls provide coding for turning this on/off on enabling indicator. Based on my likes I will turn this on or off)
Find below the latest auto scan,
Wednesday,20,February,2019,08:02:58:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 8854
Mileage: 18080km-11234mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118   Mileage: 18080km-11234miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2F63212A04C50615F46A845920020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Serial number: 03111813470922
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Date: 2015.05.30
                    Time: 14:12:49
                    Voltage terminal 15: 12.20 V
                    Voltage terminal 30: 12.40 V
                    Terminal 15 status: On
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 222180856
   Coding: 3B904BFF48A10000013806407CEB96904980610F608C21C1220000030000
   Shop #: WSC 12345 123 12345
   VCID: 2C57B2B24F0B312494-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 290617 04  42  0106
   Coding: 066800
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2521
   Serial number: 13202848170704050535
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2521
   Serial number: 13102849170705002249
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1811713320101504AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1522
   Serial number: 13102728170704212031
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1522
   Serial number: 13102729170630002341
3 Faults Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:21:31
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
   Part No SW: 7E0 919 475 K    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231325304021
   Coding: 308002
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3A7B84EABD5F9F9416-806E
   Revision: --------    Serial number: 003GW01BGFS-
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D12EE2C5161CBD-801E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002300
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H01 0217
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R8103103
   Coding: 0E000440000010
   Shop #: WSC 12345 123 08192
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:30)--------------------------
In the BCM coding YOU enabled the Byte0 Bit0. Any particular reason?
This Bit0 is for the selective control of the doors.
Disable this byte and check the opening and closing of the windows with the remote control.
The steering wheel angle can also be found in the address 44 Meas. Blocks
sshakthi123
ciclo wrote: Wed Feb 20, 2019 3:36 am In the BCM coding YOU enabled the Byte0 Bit0. Any particular reason?
The car is been used for single occupancy, so I enabled it. But will disable this sometime this noon and get back to you the results.
One-side parking lights only work with the key outside the ignition switch.
Edit
OK.
Point 5 (and previous 8 ) is already solved. Read the links I gave you.
Update the list once you do your checkings.
sshakthi123
ciclo wrote: Wed Feb 20, 2019 5:08 am Update the list once you do your checkings.
Disabled Byte 0 ->Bit 0 but no luck, here is the latest
1. Auto close windows not working though remote closing operation and one touch up/down works fine.
2. Auto close windows on detecting rain in running or in park mode NOT working. Tested by pouring the water on the RLS, wiper activated but windows not closed.
3. Central electronics errors for DRL bulbs and backlit bulb
4. Steering angle sensor calibration error - tried through 44-steering assist block also. Security access allowed but meas. block is in disabled state.
latest scan,
Wednesday,20,February,2019,22:28:12:00006
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 8854NN
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Date: 2015.05.30
                    Time: 14:12:49
   Revision: V0000000
   Coding: 3A904BFF48A10000013806407CEB96904980610F608C2141220000030000
   Coding: 066800
   Coding: 240000
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:21:31
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
   Coding: 308002
   Coding: 003036
   Coding: 1208000000
   Revision: B9082001
   Coding: 002300
   Serial number:
End-------------------------(Elapsed Time: 02:33)--------------------------
Deficiencies (not faults, drls and Back-up lights work) due to having an incorrect Hardware installed.
- 1 and 2 As I mentioned some time ago, you must change your Window Regulator Motors (WRMs) by others with the appropriate software. Check the govindsharma thread the correct WRM reference numbers for 6R RHD.
viewtopic.php?f=56&t=69603&start=105#p529605
- 3 Very low consumption NO-OEM LED bulbs (DRLs and Back-up lights), my suggestion: buy LED bulbs "CANBUS error free" or install the original bulbs (first try the new and final BCM coding I provide you below).
- 4 Try to have someone with greater skills and knowledge about the VCDS diagnostic tool to calibrate your new steering ring, it's really easy and fast, it should work perfectly.
I can tell you how to do things, but I'm not there to do them.
The steering ring is well installed with the wiring that I gave you as a gift. :wink:
New and final BCM coding (based in the last VCDS autoscan)
3A904BFF48A10000013806507CEB96904D80610F608C2141220000030000
Report a new autoscan with the new BCM coding, it's very important to you.
Summarizing:
- BCM adaptation. Perfect!
- Automatic lights. Perfect!
sshakthi123
ciclo wrote: Thu Feb 21, 2019 3:28 am - 3 Very low consumption NO-OEM LED bulbs (DRLs and Back-up lights), my suggestion: buy LED bulbs "CANBUS error free" or install the original bulbs (first try the new and final BCM coding I provide you below).
I understand this is true for DRL bulbs I had installed non-OEM / non canbus error free. But I never touched the back-up lights. It is OEM and I just replaced with the BCM white pin 7.
ciclo wrote: Thu Feb 21, 2019 3:28 am - 4 Try to have someone with greater skills and knowledge about the VCDS diagnostic tool to calibrate your new steering ring, it's really easy and fast, it should work perfectly.
Tried all possibilities and the meas. block is inactive to go in. However I will try other options.
ciclo wrote: Thu Feb 21, 2019 3:28 am New and final BCM coding (based in the last VCDS autoscan)
Changed to this code. But it gives NO change functionally. But when I was doing adaptation changes I found the windows on locking through remote worked once. But unable to reproduce how it worked. If it required WRM changes how does it work ONCE? It would be great throwing some light here to find it out and fix it. Thanks in advance.
ciclo wrote: Thu Feb 21, 2019 3:28 am color=#0000FF]Summarizing:
- Automatic lights. Perfect![/color]
Agreed :D
Here is the latest scan,
Thursday,21,February,2019,10:11:00:00006
www.Ross-Tech.com
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Date: 2015.05.30
                    Time: 14:12:49
   Revision: V0000000
   Coding: 3A904BFF48A10000013806507CEB96904D80610F608C2141220000030000
   Coding: 066800
   Coding: 240000
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:21:31
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
   Coding: 308002
   Coding: 003036
   Coding: 1208000000
   Revision: B9082001
   Coding: 002300
   Serial number:
End-------------------------(Elapsed Time: 02:34)--------------------------
I knew that something weird was happening (the VCDS scans show the truth), and as always, I was forced to extract the information in an unorthodox way. :mrgreen:
Back-up light or a.k.a. reverse light
In the installation guide it never talks about that you have to install a wire from the T73b/7 bcm white connector to the reverse light, ... it is for license plate lights (blue/black wire).
In your case, the reverse light is adapted by coding. No additional wire is necessary.
Steering ring
Have you tried all the possibilities? NO. :lol:
Read
You can download the manual here, at the moment it's free. :lol:
WRMs
Electronics makes very funny jokes 😂, especially when new software is being adapted. There is no other explanation.
In the link to govindsharma thread you have all the info. As simple as that. Please, don't insist more with the WRMs ... LOL!
sshakthi123
ciclo wrote: Thu Feb 21, 2019 12:59 pm Back-up light or a.k.a. reverse light
Not really.. actually I had connected T73b/7 to license plate lights and NO MOD to reverse light. I untouched it. So this shows something else is wrong and we have to fix it.
ciclo wrote: Thu Feb 21, 2019 12:59 pm Steering ring
Thanks, I will try for this.
ciclo wrote: Thu Feb 21, 2019 12:59 pm WRMs
I believe updating WRMs is to enable auto folding mirrors but rain closing should work. However I will read the thread completely and revert back.
ciclo wrote: Thu Feb 21, 2019 12:59 pm New and final BCM coding (based in the last VCDS autoscan)
What is this for?
sshakthi123 wrote: Thu Feb 21, 2019 1:26 pm
What is this for?
I was trying to solve the problems for reverse light and the DRLs.
Since your new BCM Max 7E0937090D (last model 7E0) is manufactured for LED headlights (8IT), it is new for all of us.
It is not the first time that a BCM PQ25 is parameterized differently to the previous ones.
3A904BFF48A10000013806507CEB96904D80600F608C2141220000030000
