Pauls Polo 6R Trendline conversion road to OEM++
Paulpelz
Drives: Polo 6R 2012 Style 1.2 -> 1.4 TSI OEM++
Re: Pauls Polo 6R Trendline conversion road to OEM++
Post by Paulpelz »
Is the control module you use a 6R0907357 or is it a 6R0907357C?
I have the one without the index. Is it possible to flash the parameter file TinyQ developed for the ...C variant onto the non-indexed variant? I would probably rent or even buy a VCP for that undertaking
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D42000001000000
   Shop #: WSC 30389 123 56831
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1BE97-806E
Paulpelz
Post by Paulpelz »
Alrighty, back again. :D
A little update about the state of my car. First of all: I finally got my bumper covers back from painting. Now I ask myself why the frick I didn't convert to R Line sooner.
And yes, I am very aware that it really needs the highline 6C grill. I have one. Somewhere. Can't find it. I apparently have too much stuff in too many places. XD
Secondly, I now had my new engine for around 5.000 km. And I LOVE it. You can drive it somewhat economical, but you don't want to. The power delivery is awesome! It has some small problems, to which I'll get separately, but overall, it has been a blast so far.
Thirdly, I finally found a reasonably priced ALWR control unit with index C. I haven't really had the time to play around with it, but as far as I can tell other than the need for a fresh set of parameters (which it will get this Thursday) it's fineish.
Also, a little outlook for the future: GT spoiler, widened sill panels and water deflectors are in the making for a completed BlueGT look. In the planning are also side assist (where I might need ciclo's help), TPMS and this exhaustion detection system thingy. Or maybe some light tuning? I don't know, but I sure will find a way to waste my money :D
So long
Paulpelz
Post by Paulpelz »
Okay, now back to the good old problems. First: the engine.
Problem #1: Fault code P164C00
I still get the P164C00 fault from time to time. It reports a Implausible Signal from the Oil Pressure Switch for reduced Oil Pressure. And I still don't really get why. The only consistency I noticed is the appearence of this fault after an engine start (both with the key and the start-stop-System).
I changed the actual reduced oil pressure switch. No difference.
I changed the high oil pressure switch (since it is a reference value to the reduced oil pressure switch). No difference.
I changed the oil pressure regulator valve (since I read somewhere that it can cause this fault). No difference.
Then I fiddled around on the connectors of all three parts. After that, the fault went away for some time but now shows up again irreguarly.
Another noticeable detail: Sometimes (not always) my car would throw an EPC warning at about 180 km/h under accelleration. Afterwards it would report a malfunction of the high oil pressure switch.
Also a noticeable detail: I recently checked the oil level. It was about 1 liter short of the maximum mark, aka just underneath the minimum mark. This seems odd to me since I did an oil change about 100 km after the engine swap and filled it to the correct level. Now I have spent my entire 5l jug of oil.
My guess (which is ignoring the mysterious loss of oil) is an improper electrical connection of the connector of the high oil pressure switch, so that sometimes it doesn't deliver the expected value to the ECU for really short periods of time. Short enough to not be noticeable when live montioring the values of the switches with VCDS. Does that make sense?
Problem #2: steam/smoke (?) out of the exhaust
Now that it gets colder I noticed excessive steam out of my exhaust. Sure, when the car is cold thats completely expected. But I also noticed it after about 10 km of driving. It doesn't smell like smoke or gasoline (the latter only after cold start), rather a little bit like a cow pat. Don't laugh, please! XD
I don't seem to loose coolant, so I would rule that option out. Might it have something to do with my mystery loss of oil I mentioned above? Or might it be faulty injectors (I only cleaned them in a warm ultrasonic bath with injector cleaning solvent so they might still be bad or clogged up)? Or is it completely normal?
Problem #3: ALWR control unit
As I mentioned before I installed a used 6R0907357C out of a passat CC with xenon. I did reset all adaption values and did the basic settings for the head lamps. There are no ALWR related fault codes anywhere. Either way, I cannot change the coding to Iichel's example. Whatever I try, the first byte is always "out of range". Also I am not sure if the adjustment of the headlights actually works. Is there a value in the adv. measurement list that helps me out? Do I maybe have an incorrect sensor at the back axle (Right now it is 6R0941273B)? Or will everything be rectified by the new parameters by TinyQ?
Thanks in advance and sorry for that enormous amount of text!
Here is my newest autoscan (with fault code P164C00 missing)
Tuesday,22,October,2024,23:20:41:44001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64)
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ6RZCY154963   License Plate:
Mileage: 136220km-84643mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 47 55 5F 61
VIN: WVWZZZ6RZCY154963   Mileage: 136220km-84643miles
47-Sound System -- Status: OK 0000
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 Q    HW: 04E 907 309 D
   Component: 1.4l R4 TSI   H08 7599
   Revision: WCH08---    Serial number:                CVN: CFB85C3E
   Coding: 00190032242411000000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM14TFS01104E906016Q 002011
   ROD: EV_ECM14TFS01104E906016Q_002.rod
   VCID: 306898F86B88B2167B-8064
   VINID: 9E69EAAAA1A2A93A411442460C9D751C47
Readiness: 1110 0001
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Coding: 21DD4885232800C4841D126FC45400550904
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 0F2A3B04D6F68DEE42-805A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3878A0D88BF86A5633-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 259171299
   Coding: 3CB02BBF4821000021380FE06EEB9FD1C6C067CF608D7850210000030800
   Shop #: WSC 12345 123 61029
   VCID: 2B528F944AAED1CE4E-807E
   Component: RLHS 200618 0  50  0107
   Coding: 008F77
   Subsystem 2 - Part No SW: 6R0 959 801 DJ    HW: 6R0 959 801 DJ  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 0610
   Serial number: KU0KU021031770802804
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 DN    HW: 6R0 959 802 DN  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU005081662186418
   Coding: 1000AB
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU011111100010576
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU014111100016138
   Coding: 08BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231921103426
   Coding: 308009
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71EE5DFCA002FB1E34-8024
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX0108L3% Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 00788 648 00255
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9CEA10ED14E8C655-801E
   Serial number: 3575HRB405R0UJCIB1I5
   Serial number: 3585HRB405F0UJCI4H6Y
   Serial number: 3515RRB40650TGJKB0CT
   Serial number: 3525RRB40610UT98K0GV
   Part No SW: 6R0 920 870 D    HW: 6R0 920 870 D
   Component: KOMBI         H04 0709
   Coding: 140E00
   VCID: 3664AEE089EC9C2621-8062
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002201
   VCID: 68D830989BD83AD663-803C
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 0404000000000000010000
   Shop #: WSC 02739 790 50316
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: 2D56818C7CBADFFE50-8078
   Component: IMMO          H04 0709
   Serial number:
   Shop #: WSC 09402 015 1048576
   VCID: 6ADC4A908DD408C675-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AJ    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3132
   Serial number: CF8D0787 Dataset Number: 8XA909852D  0019
   Coding: 000300
   Shop #: WSC 00046 412 54321
   ASAM Dataset: EV_SteerAssisUDSTRW 016029
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 7F0A8BC4E6569D6EB2-802A
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000022 Dataset Number: 0001
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4_VW36.rod
   VCID: 285870985358FAD6A3-807C
   Coding: 078A000001000000
   Shop #: WSC 05311 115 08193
   VCID: 3A7CBAD0BDF47846C5-806E
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U0997762 Dataset Number: V03935266VJ 0001
   Coding: 02620001AA00000011111103C00D0A201F0110D400200100CE
   Shop #: WSC 00012 790 50316
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 254679AC244AE7BE98-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 BK    HW: -----------
   Component: ECE AS 2022  --- 1720
4 Faults Found:
1555 - Check Software Version Management
          B201A 00 [00001001] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 134952 km
                    Date: 2024.09.23.
                    Time: 15:34:34
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 134955 km
                    Date: 2024.09.23.
                    Time: 16:01:56
                    Voltage terminal 30: 13.2 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
15360256 - Component Protection
          U1101 00 [00001001] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 222
                    Mileage: 134952 km
                    Date: 2024.09.23.
                    Time: 15:34:34
                    Voltage terminal 30: 12.1 V
0003 - Antenna 2 for radio
          B111A 13 [00001001] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 21
                    Mileage: 134952 km
                    Date: 2024.09.23.
                    Time: 15:34:34
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dB V
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 032B7A64
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 50231J15312031943146
End-------------------------(Elapsed Time: 03:39)--------------------------
Good luck with loading the proper parameters (Tiny-Q) for the ALWR unit, the headlights do a down/up check every time you turn on the ignition (+15).
About Lane Change, in the last pages of my thread, post your concerns here.👍
Paulpelz
Post by Paulpelz »
ciclo wrote: Wed Oct 23, 2024 8:43 pm Good luck with loading the proper parameters (Tiny-Q) for the ALWR unit, the headlights do a down/up check every time you turn on the ignition (+15).
I really hope it works... it has bothered me way too long now.
But how does the check work actually? Because on my car, the check only happens after I start the engine. Not as soon as I turn the ignition on. Also, the check on my car works by adjusting the headlights upwards and then back down to the original position. It hast been the case with the old non-C-indexed control unit as well as with the unparameterized new one. I have never been able to confirm if this is typical behaviour.
ciclo wrote: Wed Oct 23, 2024 8:43 pm About Lane Change, in the last pages of my thread, post your concerns here.👍
Yeah, I saw your solution and got jealous :D
Just how were you able to get the mirror glasses with the Lane Change symbols? I was looking for hours and couldn't really find them, let alone a shop that would deliver them to Germany. Might you maybe able to help me there? :D
The right way:
- YES, Ignition switch ON + Engine ON, sorry, I didn't write it properly.
- Down/Up Bixenon.
:arrow: https://www.youtube.com/watch?v=SzCaaps5P2c
Same for LED headlights.
Up/Down is not correct, something is wrong (parameters/data set or wiring). I have not installed LED headlights, but I seem to remember that the connections for automatic headlight level adjustment are not the same for LED headlights as for Bixenon headlights... check/compare wiring diagrams :?:.
The checking movement must be fluid and synchronized... nothing special, it's something simple, as show in the above YT video.
The item. Remember 2014/2018!!! for 6R Europe.
https://www.aliexpress.com/item/1005002 ... pt=glo2fra
It seems that they don't ship to Germany, hmm... in the country/language settings, set a nearby country where you have a friend who can receive them for you...or some similar trick.🤷‍♂️
However, you will have to contact the store/seller, they usually do not have these mirrors available, but they order them to be manufactured in order to send them to you.
They send them with 5v Amber LED lights. I have bought them twice, that is, I have two sets, one of which I asked the seller to send me with the RED LEDs... there is no problem with this.
On Ali there are several stores that sell these red or amber LEDs at reasonable prices, also in this store. They do their job perfectly.
I find it strange that they don't ship to Germany, ask the seller...
Driver Alert/Fatigue Detection. Activation.
Here :arrow: viewtopic.php?p=556790#p556790
Paulpelz
Post by Paulpelz »
Automatic headlight range control now working!
I am happy to announce that my headlight range control is now working flawlessly.
As a recap: some time ago I swapped my H4 headlights for OEM 6C LED headlights. For the automatic range control I used the control module 6R0907357 like in a xenon Polo. Unfortunately the range control wasn't working properly. Whenever the headlights should have adjusted downwards, they turned upwards, blinding the oncoming traffic.
To mitigate this, I purchased a 6R0907357C control module out of a xenon Passat CC. Even after I flashed it with the preset Polo parameters from VCP, my problem remained. So I flashed the TinyQ parameters using VCP. To be precise: I flashed all three of the TinyQ parameters (both Bixenon and the LED one). After coding 0D8A000001000000 and doing the basic settings the system is now working.
Immediate sign for the working system: When I start the engine my headlights are now doing the self-check by turning down and back up to the proper level. Until I flashed the TinyQ parameters this was the other way round.
Thanks to iichel for the inspiration and the instructions as well as ciclo for the recent help!
Just one question: when I activate the travel mode in my instrument cluster, I get a yellow flashing light warning for a few seconds. There are no faults generated by this. I can't really tell if the travel mode is actually doing anything, but I think there is an absolute miniscule movement downwards. Is this normal behaviour?
Great, thanks for the report!👍
The truth is that without the parameters made by TinyQ🧙‍♂️and the excellent work posted by firegrafic🧙‍♂️ on Drive2.RU💎 the installation of LED headlights on 6R (europe, etc.) would not be so charming.
Paulpelz
Post by Paulpelz »
Hey you all! My little Blue-GT-swapped Polo recently survived a small 2500 km road trip through the southern parts of Germany. A nice opportunity to take some pretty pictures. Please ignore the absolute humongous amount of dirt on it! :D
Polo on the hill.jpg (7.99 MiB) Viewed 1430 times
Also, it was a good way to test it out some more. And of course, I found two mediocre problems:
ESC being boring
When I turn through sharper turns with a little bit more... gusto :D , the ESC thinks I am slipping away, cuts power and breaks me to almost a standstill, if I don't straighten the wheels. I think it is a bit (way) too overprotective, since if I turn it off, I can take the same turns with quite a bit more speed without slipping a bit. My ABS coding seems to be correct (I guess?). I am using stock Blue GT springs with stock 6C GTI dampers and the strongest possible stock stabilizer with 6C GTI Parabolica wheels and the correct size of tires for them. I am running out of ideas. What could be causing this? Let me guess: good opportunity to justify putting in some coil overs?
High beams occasionally not working
Sometimes, completely randomly, my high beams will not turn on. Sometimes it is only one, sometimes it’s both. Sometimes it is only one, sometimes it’s both. When they are on, they stay on. My low beams work absolutely flawlessly. It acts as if sometimes, the signal to turn the high beam on doesn't reach the bulb. What would be your guess? Wiring or the drivers on the headlights itself (broken or some stupid software nonsense)?
Newest Autoscan
Sunday,14,September,2025,12:53:36:44001
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
www.Ross-Tech.com
Mileage: 150160km-93305mi   Repair Order:
VIN: WVWZZZ6RZCY154963   Mileage: 150160km-93305miles
61-Battery Regul. -- Status: Malfunction 0010
   VCID: 306898F86B88B21B7A-8064
1 Fault Found:
5583 - Oil Pressure Switch for reduced Oil Pressure
          P164C 00 [00101000] - Implausible Signal
                    Fault Priority: 2
                    Fault Frequency: 254
                    Mileage: 142451 km
                    Date: 2025.04.12.
                    Time: 17:38:46
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 80  C
                    Intake air temperature: 28  C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 12.368 V
                    Mass flow through throttle valve: 2.4 kg/h
                    Mean injection time: 0.987 ms
                    Engine operating condition: Idle
                    Engine operating condition-Test_Program_Channel 87: 5
                    A/C compressor: load current: act. value: -71.50 A
Readiness: 0000 0000
   Coding: 21DD4885232800C4841D126FC45400551505
   VCID: 0F2A3B04D6F68DE343-805A
   Revision: V0000000
   VCID: 3878A0D88BF86A5B32-806C
   VCID: 2B528F944AAED1C34F-807E
   Coding: 008F77
   Coding: 0200A3
   Coding: 1000AB
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
            007 - Short to Ground - Intermittent
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 132
                    Mileage: 148381 km
                    Time Indication: 0
                    Date: 2025.09.10.
                    Time: 20:11:50
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 132
                    Mileage: 148399 km
                    Time Indication: 0
                    Date: 2025.09.10.
                    Time: 20:39:22
   Coding: 308009
   VCID: 71EE5DFCA002FB1335-8024
   Coding: 00314D
   VCID: 4A9CEA10ED14E8CB54-801E
   Crash sensor for side airbag: passenger side:
   Coding: 140E01
   VCID: 3664AEE089EC9C2B20-8062
   Revision: B9082001
   Coding: 002201
   VCID: 68D830989BD83ADB62-803C
   Revision: AA001001
   VCID: 2D56818C7CBADFF351-8078
   Serial number:
   VCID: 6ADC4A908DD408CB74-803E
Cannot be reached
   Coding: 000300
   VCID: 7F0A8BC4E6569D63B3-802A
   VCID: 285870985358FADBA2-807C
   Coding: 0D8A000001000000
   ROD: EV_HeadlRegulVWLWRCC_VW25.rod
   VCID: 3A7CBAD0BDF4784BC4-806E
   Coding: 026200010000000011111103C00D0A201F0110D400200100C6
   VCID: 254679AC244AE7B399-8070
   Data carrier:
5 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 142348 km
                    Date: 2025.04.08.
                    Time: 11:14:45
                    Voltage terminal 30: 12.5 V
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 142360 km
                    Date: 2025.04.08.
                    Time: 11:58:30
                    Voltage terminal 30: 13.0 V
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 142348 km
                    Date: 2025.04.08.
                    Time: 11:14:45
6720 - Rear View Camera
          B1102 31 [00001000] - No Signal
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 133
                    Mileage: 146946 km
                    Date: 2025.07.25.
                    Time: 14:01:56
                    Voltage terminal 30: 11.5 V
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 175
                    Mileage: 142348 km
                    Date: 2025.04.08.
                    Time: 11:14:45
   Coding: 032B7A64
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 145
                    Reset counter: 138
                    Mileage: 142402 km
                    Time Indication: 0
                    Date: 2025.04.12.
                    Time: 07:15:13
End-------------------------(Elapsed Time: 03:32)--------------------------
------------------------------9 Faults Found-------------------------------
(I decided to ignore the oil pressure switch fault for now)
what is the problem with your abs coding?
you can change byte 16 from 15 to 77 to have two-stage ESP.
short press for traction control off, long press for ESP off
