Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Just regular maintenance... 4 new tires (old Hankook V12 were 2mm, so they were finished with the autumn rain coming).
New pair of Bridgestone Potenza 215/40 R17 mounted :) The mechanic was surprised to see the Polo 6R with TPMS sensors. He was a bit confused and was looking for the reset button on the RNS510 :mrgreen: :mrgreen:
iichel wrote: Wed Sep 23, 2020 2:19 pm Just regular maintenance... 4 new tires (old Hankook V12 were 2mm, so they were finished with the autumn rain coming).
8)
iichel wrote: Wed Sep 23, 2020 2:19 pm The mechanic was surprised to see the Polo 6R with TPMS sensors. He was a bit confused and was looking for the reset button on the RNS510 :mrgreen: :mrgreen:
Michel, I'm a bit confused with your 6Rs, I thought you upgraded the front brake discs on your 1.2 TDI R-line ... :?:
edit... maybe I'm seeing the front discs too small in that image ... 🤪😆
CNK
Drives: 6R
Post by CNK »
ciclo wrote: Tue Sep 29, 2020 7:40 am Michel, I'm a bit confused with your 6Rs, I thought you upgraded the front brake discs on your 1.2 TDI R-line ... :?:
Yep, he uses the same sizes of brakes like in Polo WRC Street, if I remember correctly they comes from Audi TT 8N.
Michel installed better brakes before me, a long time ago :)
Thanks Szymon, ...I checked it on the first pg.
It's just that the front discs seemed a bit small to me in that image ...
I hope everything goes well with you.👍
8)
Szymon is completely right, perhaps the image doesn't do the size justice but it's 312mm at the front and 256mm at the rear. It's the WRC configuration.
It's a mix of several cars. Front calipers are 6R GTI, carriers are 6R WRC. Rear caliper carriers are Golf 4 GTI Jubileum edition and calipers are Audi 8N TT Quattro.
ciclo wrote: Tue Sep 29, 2020 8:09 am ---
All is good here. We have some stricter corona measures here since last night, still relatively easy compared to other countries in Europe.
We are still healthy and doing our best to stay out of trouble. I wish you and all the other forum members well in these interesting times.
We are also well and fortunately we have not caught the infection yet, we continue with our particular way of protecting ourselves from this second wave of infections, which was very predictable (perhaps acceptable) after the supposed summer holidays and back to school, work, etc.
The show must go on, no doubt, but this pandemic has made it quite clear that the concept of humanity is not at its best. It seems that schools no longer teach that one was born on planet earth with other human beings who must be actively respected regardless of any ideology or condition. :)
I refer to health issues ... now the main thing is everyone's health.
Everything is compatible if done correctly, which requires a certain order and cheerful individual collaboration. :lol:
patil
Post by patil »
iichel wrote: Sat Sep 19, 2020 10:15 am I'm curious to hear, thanks for checking. Very interesting info!
Perhaps you can already active the light sensor function in VCDS without the auto light? Byte 13 bit 7.
Hi iichel..
I finished installing autolight wiring I received from Master Ciclo successfully. After activating light sensor, the side assist(5Q0 radars) led brightness is indeed regulated by light sensor.!!
I could appreciate the difference in led brightness before and after activating the light sensor. In advanced measuring values of 3C address, I can see the values.
CNK
Drives: 6R
Post by CNK »
good news :)
one day maybe I will also install 5Q0 radars (if will still alive)
this is very interesting information, thank you very much
iichel wrote: Tue Oct 06, 2020 2:48 pm this is very interesting information, thank you very much
yes, ...at least we confirmed what we already suspected. :)
On the other hand, we confirm that Patil, our beloved Doctor, is notably improving in these matters ... :lol:
patil
Post by patil »
ciclo wrote: Thu Oct 08, 2020 5:15 am
I couldn't agree more Master🙏
I still remember when it all started with dimmer switch installation few years ago, I have come a long way since then.😄
I take this opportunity to thank this beautiful forum, admins, members and especially Master Ciclo, iichel and others for immensely contributing the knowledge I and other have gained here.🙏
We shall keep reviving dying PQ25 😎😄
Just a regular maintenance autoscan :) Nothing too strange going on lately.
Just some small repairs:
- Replaced ventilator resistor
- Replaced wiring loom in roof due to a small melt-down but all the fuses did their work nicely
- Passed the yearly mandatory official inspection with compliments of the inspector
- Updated VCDS to the most recent version (very big advantage of original interface)
- Replaced a few broken LEDs
Done some small coding changes to suit my preferences
- Disabled rain closing since this doesn't work
- Disabled autobahn light (lights on if you drive faster than 140 kph)
Thursday,12,November,2020,15:57:51:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
Workshop Code: 123 31889 005683
VIN: WVWZZZ6RZBYiichel   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56 57 61 65 69 6C 77
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021B.rod
   VCID: 270B06DDAF6FF1F3339-8073
Readiness: 0 0 0 0 X
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front 0002
   Serial number: --------------
   Coding: 21DD2885432500C5841A146EC25500521505
   Shop #: WSC 31889 123 05683
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89B3DB9-805B
Address 05: Acc/Start Auth.        Labels:. 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Revision: 00092000
   Coding: 56574B45535359505133354750
   VCID: 372BD69D7FCF6173A39-8063
No ASAM data for: "" (VW25)
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0BAA3-806D
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030800
   VCID: 2B03FAEDB307D593D71-807F
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E74513471-806F
Address 15: Airbags        Labels:| 5K0-959-655.clb
   Revision: --------
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9BCC7-801F
   Serial number: 3575HRB40650BI7U48C8
   Coding: 00
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         0709
   Coding: 140F01
   VCID: 3333E28D6BB78D539F1-8067
No ASAM data for: "" (VW36 *)
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 688945E162713E8BFA3-803D
   Revision: AA001001
   Coding: 0404000000000000010000
   VCID: 2E05F3F98095A0BBF0F-807B
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9BEC7-803F
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: N/A
   VCID: 2F3BEEFD879FA9B3FB9-807B
No ASAM data for: "EV_ELVMarquMPVW36X" (VW25)
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987BB8F-8063
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3FB9-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB70315D-802D
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: N/A
   VCID: 280905E1A271FE8B3A3-807D
No ASAM data for: "EV_AudioVerst10KanalSTT4" (VW25)
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1B5C7-806F
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8B3A3-807D
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3FB9-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E3C15-8031
Address 77: Telephone (J412)       Labels:. 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       0983
   Revision: --------    Serial number: 35502105254406
   Coding: 00
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3E3015-8071
End----------(Elapsed Time: 02:36, VBatt start/end: 11.9V/14.1V)-----------
Mocro
Drives: Polo 6C 1.4TDI 105HP
Post by Mocro »
iichel wrote: Sat May 02, 2015 9:18 am
This way, the fog will be assessed to the empty place in the connector.
The reason for this is, the loose wire needs to go to fog in order to emit red light.
So now you have the passenger side tail light out, open it (it is a clicking system).
Take out the halogen fog light and put in the LED double color LED.
Solder the wire to the plate that ends in a dead end.
This is the pin that corresponds with the place where you moved the fog light wire to.
Now it is important to test first.
Put the car in reverse and you will see both sides have reverse light.
Put the car out of reverse and turn on rear fog. Now rear fog should light up in red.
If everything works, it can be necessary to turn of canbus error check of both rear fog and reverse.
What do you mean with this:
Do you have pictures or something?
So i have to solder the fog light pin to 1 or 2 see my picture?
Im also interested in this mode. One bulb doesnt do it for visibility.
Solder it to pin 5, place number two in your picture.
