Mocro
Drives: Polo 6C 1.4TDI 105HP
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by Mocro »
iichel wrote: Tue Jan 12, 2021 7:39 am Solder it to pin 5, place number two in your picture.
But is it also possible to plug the fog pin in to the connector of the tail light?
Why is it necessary to solder it on the plate it self?
I did it this way so you can retain the OEM connector for the tail light on both sides.
Mocro
Post by Mocro »
iichel wrote: Tue Jan 12, 2021 5:52 pm I did it this way so you can retain the OEM connector for the tail light on both sides.
I get it you mean the extra wire of the led light.
Is this one ok?
€ 14,15 44% Off | IJDM Auto T20 LED Wit/Rood Dual-Kleur Canbus W21W 7440 led-lampen Voor 16-up Chevy camaro Backup Reverse Lights en Mistachterlicht
https://a.aliexpress.com/_BOGtaP
I think i need some dupont to connect it on the tail light connector, but what is the size?
Mocro
Post by Mocro »
iichel wrote: Sat May 02, 2015 9:18 am New mods!
New BCM
In order to make the OEM xenon work perfectly, I swapped the BCM with a lot of help from ciclo.
It was easy job, but necessary to work very precise with coding.
I moved from a 088D bcm (Bluemotion with standard halogen headlights and start/stop system) to a 090 BCM and now all works perfect.
On the 088D bcm I experienced some flashing of the LEDs in the headlight, despite all wiring was OEM style installed.
Double reverse light
How to:
On the driver side, there is a double-colour LED. It has a normal fitting and an extra wire.
In the normal fitting, it will do white light. If the extra wire is 12V then the emitted light is red.
I bought it here:
http://www.ebay.com/itm/310796888643?_t ... EBIDX%3AIT
And then asked for red and white. It was no problem :)
So to do this, a wire from left to right headlight has to be made.
Here is a pin layout for LHD (non-UK). UK is I believe mirrored.
Top is 6R bottom is 6C tail lights.
translation:
stads = parking light
rem = braking
massa = ground
kn = knipperlicht = indicator
achteruit = reverse
mist = fog
To make a wire from left to right, you have to take out the reverse light pin and solder a wire to it.
Guide wire to the other side and insert it in the connector.
Do not put it in the empty pin but do this:
- Open connector
- Move fog to the empty pin
- Insert reverse light wire in the position of old fog light pin.
For 6R this is a junior power timer, for 6C this is a standard power timer.
Please note that if you have 6R with 6C lights with adapters, moving cables in the car connector housing is not necessary.
You can move in the adapter.
This way, the fog will be assessed to the empty place in the connector.
The reason for this is, the loose wire needs to go to fog in order to emit red light.
So now you have the passenger side tail light out, open it (it is a clicking system).
Take out the halogen fog light and put in the LED double color LED.
Solder the wire to the plate that ends in a dead end.
This is the pin that corresponds with the place where you moved the fog light wire to.
Now it is important to test first.
Put the car in reverse and you will see both sides have reverse light.
Put the car out of reverse and turn on rear fog. Now rear fog should light up in red.
If everything works, it can be necessary to turn of canbus error check of both rear fog and reverse.
For equal light color and intensity, I bought two lights and put the same LED in the driver side housing.
Demonstration on my Rosa Line.
Iichel do you use p21w or h21w led light?
Mocro wrote: Thu Jan 14, 2021 9:34 pm
Mocro, I apologise for answering you this late.
The P21W or H21W are the same Ba15s fitting. This doesn't matter.
I had a shipment of 10 LED lights custom made with a Ba15s fitting and an extra wiring for the other colour LED.
They have a lot of SMD LEDs with a series of red and a series of white light.
Mocro
Post by Mocro »
No problem, oke so if I order this i can make a custom fitting voor BA9S because the right tail light is BA15s?
''https://nl.aliexpress.com/item/33055233 ... AtCXG&mp=1''
I'm not sure that's going to fit in your tail light, space-wise.
Page 34. 34 is the VW type designation for the Karmann Ghia type 34, known as the Razor Edge Ghia or 'Der Grosse Karmann'. The Big Karmann.
Bought it yesterday, my project for the next few years.
CNK
Drives: 6R
Post by CNK »
iichel wrote: Fri Jan 22, 2021 7:34 pm Page 34. 34 is the VW type designation for the Karmann Ghia type 34, known as the Razor Edge Ghia or 'Der Grosse Karmann'. The Big Karmann.
You're crazy! Hope the next one will be blue! :mrgreen:
So today my little Polo visited someone with a white Golf 7.5 and it's not ciclo... but another Polo owner :)
He helped me read the immo block from my cluster, in preparation of the new engine.
And he sold me a 5Q0 PDC unit with 1K8 firmware, in anticipation of of retrofitting.
And he even activated OEM MKE on my gateway so I have an extra menu entry in my MFA+ :mrgreen:
All in all a great visit, I'm very happy!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
:roll: :?:
It's madwarlocks golf 7.5
ag69
Post by ag69 »
:D 8)
iichel wrote: Fri Feb 05, 2021 8:41 pm So today my little Polo visited someone with a white Golf 7.5 and it's not ciclo... but another Polo owner :)
https://i.imgur.com/SH3P6Ji.jpg
8)
Demon couple... 😁
dominis23
Drives: POLO 6R
Post by dominis23 »
Hi, I have a question if only the amplifier with the numbers 5C6035456C fits or you can put on another amplifier
