UK-POLOS.NET - THE VW Polo Forum • Polo 6R ABS CODING - Page 35
Page 35 of 35
Re: Polo 6R ABS CODING
Posted: Sat May 24, 2025 5:07 pm
by iichel
Any updates on this?
Posted: Wed Nov 12, 2025 5:05 am
by amrieazhari94
hi, i'm new here. can anyone help to calculate polo hatchback 1.6 mpi RHD abs90 long coding
[/Wednesday,12,November,2025,11:05:02:16365
VCDS Version: 24.7.0.0  HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: PPVZZZ60ZJL100070   License Plate:
Chassis Type: 60-VW25 (XXX)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: PPVZZZ60ZJL100070   Mileage: 77120km-47920miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLSA)       Labels: None
   Part No SW: 03C 906 014 BB    HW: 03C 906 014
   Component: CLSA-MM7GV    H02 8765
   Revision: --H02---    Serial number: XXXXXXXXXXXXXX
   Coding: 00000000000000000000
   Shop #: WSC 23440 003 1048576
   VCID: 5EE59E65E0246B2A0DF-5160
   VINID: 8209AAAAA180A9A7010000070054984C84
Readiness: 0110 0001
Address 02: Auto Trans        Labels: 09G-927-750.clb
   Part No SW: 09G 927 750 LK    HW: 09G 927 750 LK
   Component: AQ 250 6F           2238
   Revision: 00H98000    Serial number:
   Coding: 0000328
   Shop #: WSC 01234 785 00200
   VCID: 055791092932D8F26C5-5160
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 AQ    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D47A9297DD2A0B2245-8058
2 Faults Found:
0887 - Control Module
          C104A F0 [00011000] - Incorrect VIN
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 145
                    Mileage: 76869 km
                    Date: 2025.08.21.
                    Time: 00:00:24
0883 - Control module not coded
          U1013 00 [00011000] - -
          [VehicleConfigUncoded]
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 166
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41DF4519718A34D210D-8014
   Part No SW: 6RU 937 087 R    HW: 6RU 937 087 R
   Component: BCM IM H+4    H42 0452
   Revision: BZ042001    Serial number: 6800 248170030
   Coding: 38B02BBF08A10000003800002C2B049000C0400F60040000200000000000
   Shop #: WSC 83300 833 00003
   VCID: 71BFD5D901AAE452A0D-8024
   Subsystem 1 - Part No SW: 6R0 959 802 DF    HW: 6R0 959 802 DF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  022 1552
   Serial number: 13202722170612222342
   Subsystem 2 - Part No SW: 6R0 959 801 DD    HW: 6R0 959 801 DD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  022 1552
   Serial number: 12102723170613132231
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1581715074301391AB1B
   Coding: 240000
   Subsystem 4 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13202728170711091919
   Subsystem 5 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729170816071534
   Component: VW10AirbagU0F H10 0020
   Revision: --------    Serial number: 003GW01AMAS- Dataset Number: v00300666RU 0001
   Coding: 003046
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49CF5D39493AFC92C8D-801C
   Part No SW: 6RF 920 861 D    HW: 6RF 920 861 D
   Component: KOMBI         H02 5006
   Coding: 110A000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4CC1642D4648E9BAF3B-8018
   Part No SW: 6RU 909 901     HW: 6RU 937 087 R
   Component: GW-K-CAN TP20 H42 0452
   Revision: BZ042001
   Coding: 002300
   VCID: 196FCD79B99A4C12B8D-804C
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Component: IMMO          H02 5006
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC2B52CFC178AE17-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Dataset Number: 621074v____ 0124
   Coding: 0001010001010000
   Shop #: WSC 00078 790 12345
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 41DF4519710A34D210D-8014
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R7102107
   Coding: 0E00040000000F
   VCID: 49CF5D3949BAFC92C8D-801C
End----(Elapsed Time: 01:46, VBatt start/end: 11.7V/11.2V. VIgn 11.2V)-----]
Posted: Wed Nov 12, 2025 6:13 am
by ciclo
:arrow: https://www.drive2.com/l/622754316075163692/
Read carefully, then download the zip file and place it in your user folder. It will make your work easier.
Posted: Wed Dec 17, 2025 9:53 am
by robb1330
Hi Guys, Aditya here from India. New to the forum.
I own a VW Vento Highline Plus 1.2TSI (6R) Engine code- CBZB, Transmission - DQ200.
I have recently upgraded the front brakes from stock 256mm to 288mm. I need your help for the ABS Long coding. I have a VCDs cable handy which I bought from Ross-tech.
Also can you help me out with the fault codes? I've recently got the instrument cluster changed to the Maxidot cluster.
Here is the full scan:
Wednesday,17,December,2025,09:18:53:17288
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250822 DS365.0
www.Ross-Tech.com
VIN: MEXJ19608LT057764 License Plate: 8569
Mileage: 70030km-43514mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 5F 77
VIN: MEXJ19608LT057764 Mileage: 70030km-43514miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FD_004.rod
VCID: 6D87DAB3ED15C6E2555-8038
VINID: 755A1A04918021C9001471C6105DF8E5F7
Readiness: 0000 0000
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266887
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B0314AB1F0108D20B1-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Coding: 62DD2C63422807C7461B346F4255E0800908
ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
VCID: 00599307CA873B8A8E3-8054
Serial number: 07071913471021
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5EDFFB0734D7AFCF-802A
Revision: V0000000
VCID: 41DF5603818DF282C1D-8014
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 2602 180190288
Coding: 3A984BFF08A10000013806006ECB06900080634F60CE3140230000000820
Shop #: WSC 14325 142 18675
VCID: 34310FD7CE3F572A5AB-8060
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 180619 05 50 0106
Coding: 022800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2522
Serial number: 13202848190704144513
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2522
Serial number: 13202849190704115520
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1523
Serial number: 13102728190711181642
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1523
Serial number: 13102729190711055835
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZABQ504N Dataset Number: V03935303ZE 0001
Coding: 88C0C0000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 41DF5603810DF282C1D-8014
Serial number: 3490010013206422200$
Crash sensor for side airbag: passenger side:
Serial number: 35000100132091A2200$
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140A00
VCID: 47CB481BAF29CCB20F9-8012
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Revision: BB084001
Coding: 002300
VCID: 6889ABA7C277E3CA263-803C
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 69779 km
Time Indication: 0
Date: 2025.12.06.
Time: 11:44:03
Component: IMMO H05 0805
Serial number:
VCID: 6A8DD1AFDCFBD1DA307-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D0C000001000000
ROD: EV_HeadlRegulVWLWRCC_VW25.rod
VCID: 3A2D21EFECDBA15A807-806E
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5K7 035 200 M HW: 5K7 035 200 M
Component: MU-S--ROA H41 0480
Serial number: VWZAZ2U0578263 Dataset Number: 5K7CV1v____ 0001
Coding: 0284010EAA00000011150001001028001F0100D400200100CE
Shop #: WSC 69905 136 139810
ROD: N/A
VCID: 2E051DBF20937DFA2CF-807A
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
8 Faults Found:
1597 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
1598 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
1543 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
1555 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:11
1556 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:12:20
6720 - ROD - Unknown Error Code
- 00 [00001000]
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:24:23
0001 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
0003 - ROD - Unknown Error Code
- 00 [00001001]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 148
Mileage: 68875 km
Date: 2025.11.09.
Time: 13:02:12
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.0V)-----------
------------------------------9 Faults Found-------------------------------
Posted: Wed Dec 17, 2025 8:14 pm
by ciclo
Hi Aditya, welcome.
Please read the post before yours because it's highly likely you'll be able to do it yourself.
Regarding the other faults in the autoscan, you need to correctly code the Byte2 of GW and remove the phone module from the GW installation list.
If you get stuck at any point, ask again. I'm sure that, along with other respected users, we can solve it.
Posted: Fri Feb 13, 2026 2:35 pm
by kumarbr
Yeah, I actually think you’re spot on there. From what you described it doesn’t sound like something to ignore, and leaving it could just make things worse later. Better to deal with it properly now than regret it down the line.kolkata fatafat
Posted: Sat Mar 21, 2026 10:50 am
by William
kumarbr wrote: Fri Feb 13, 2026 2:35 pm Yeah, I actually think you’re spot on there. From what you described it doesn’t sound like something to ignore, and leaving it could just make things worse later. Better to deal with it properly now than regret it down the line.
Totally—better to handle it now than face bigger problems later.Kolkata Fatafat
Posted: Sun Mar 22, 2026 2:53 am
by ciclo
William wrote: Sat Mar 21, 2026 10:50 am
Welcome to both of you, your first post is certainly intriguing.❔
However, I completely agree... 😁
There are already too many psychopaths making EXTRAORDINARY MISTAKES, running rampant and ruining the lives of others with no respect for humanity.
Has anyone on this 'wonderful' planet with a standard IQ (I'm referring to 'standard' in the European/Asian sense 😄) calculated how many people -in both the rich and poor worlds- will die from a lack of medication (helium, urea, etc.) starting/within three months?
Even the water where I live, which is moderately suitable for human consumption (not drinkable), is already the property of those who own a little more than half of everything that exists. Damn ass-licking/'representatives' of the people.😜
