6c headlights onto 6r ?
Re: 6c headlights onto 6r ?
can it be any junior power timer? and must it be 0.5mm or above
i think it's best to respect the minimum wire thickness
update, i bought this wire http://dataton.net/vw/electrical/VW-000 ... 1-scan.jpg
but it doesn’t seem to want to go into my headlight switch, any idea why?
Try harder
forgot to update, finally got them working after a painful session of lying on my back snipping wires. but it worked. thanks for all the help
Hello guys!
I read the the whole thread but I'm not absolutely sure in a question so I ask you to help me pls.
If I read it correctly in this thread, the changing from a 6R H7/H7 headlight to a 6C H7/H7 is plug and play?!
For example: 6R1941007E -> 6C1941005B
Thanks in advance!
limparka
Thanks in advance!
limparka
- mirceaculita
- Drives: 6R 1.2TDI 75hp
Thank you!
This wire set also fit on skoda with max bcm and bixenon drl?https://nbcarperformance.nl/shop/polo-6 ... pterkabel/
Appendicite
- Drives: 1.2 TSI 90 Trendline (6R)
I bought my Polo V 1.2 TSI 90 Trendline (6R) with retrofitted 6C headlights. However, when I activate the high beams using the stalk, the low beams turn off.
I therefore wanted to try Ciclo’s method, but when I removed the left-hand side panel to access the relays, this is what I found:
I only have three relays: a green 644, a black 645, and another black one marked 646. I searched for a matching relay diagram on the following website (https://polo.blue/fuses-and-relays-in-polo-6r/), and it seems that J331 is the small 646 relay on the left.
Can one of you confirm it before I do anything stupid?
Thanks in advance for your help.
Your 6R is a 2013-2014 MY.
J331 = 646 (small relay)
Please share your small DIY project here, along with a couple of photos.
Thanks.
Thanks.
Appendicite
Thanks for your help ! I tried to unpin the connector with a paperclip but it didn't work so I ordered the extraction tool and I'm waiting for it. I'll send here everything I did following your tutorial once done.ciclo wrote: Thu Sep 17, 2026 12:54 pm Your 6R is a 2013-2014 MY.
Please share your small DIY project here, along with a couple of photos.![]()
Thanks.
You need to use the right VW terminal removal tools.
I always recommend this one for enthusiasts:
http://www.ebay.co.uk/sch/i.html?_from= ... ol&_sop=15
It is excellent quality and affordable for most budgets, although there are many other models that are more professional—and more expensive.
For smaller terminals, this set is damn effective:
There are also sets of precision tweezers that work quite well...
Be patient and try to approach the task like a watchmaker. With experience in these tasks, one knows exactly how to maneuver the extraction tool so that the two metal tabs do not dig into the plastic and extract the terminal gently.
Important: you must first release the pink/violet plastic locking mechanism—located on the connector or relay base—which provides a secondary hold for the terminal. Yes, this can be considered an unexpected ambush for many.
If the terminal gets stuck and seems impossible to remove
, you have the option of cutting the original wire as long as possible and splicing -in a perfect way- the new wire onto the section containing the terminal that is stuck in place.
Appendicite
I received the tool (Laser Terminal Tool 3932). I've unlocked the blue clip from the relay connector (see image below) and I tried during 1 hour to pull this f*****g wire but it doesn't want to come. Can I cut it and use a Wago 221 to connect it to the cable going to pin 7 of the light switch connector ?
EDIT : I may have found the issue. The Laser Terminal Tool 3932 should have a 2.8 mm inner diameter and a 4 mm outer diameter. I measured mine with a caliper and it has a 3.6 mm inner diameter and a 5 mm outer diameter. They put the wrong tool in the packaging. I don't want to order a new tool, so my previous question still stands.
There is another locking mechanism—pink/violet in color—located on the side where the wires and relay are found. You simply need to remove the brown relay connector from the relay carrier, pull the locking mechanism out by about 1.5 mm, and extract the gray wire terminal, and the rest of the process is relatively easy. Good luck!
