BCM Max Transporter 2013
Re: BCM Max Transporter 2013
When the TPMS unit is new or flashed, this is what usually happens... it happened to me... :)
You must load the file with the wheel pressures.
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Finally
My TPMS unit was already in the middle, I did move it, but that didn’t help, so I started to play with the adaptation menu and make tests, until I found the secret 🤫
I changed the value to 1, and immediately the TP numbers had showed up
patil
Post by patil »
Oh good that you found the missing link and rectified it👍
This adaptation channel should have been set to 1 by default. I remember not changing any values in adaptation channels when I installed direct tpms on my Polo6R. May be due to firmware flash the value was reset to 0. Anyways good to know, thank you😊
Shadow109
Post by Shadow109 »
patil wrote: Sat Apr 17, 2021 4:17 pm Oh good that you found the missing link and rectified it👍
Its good to have so many issues, I have learned alot, I hope this helps everyone willing to retrofit TPMS
Shadow109
Post by Shadow109 »
Hello Fernando, how are you ?
I have got A new BCM
https://pasteboard.co/K1HxnXf.jpg
I have some issues when adapting keys, dose the “E” letter requires A 315 MHZ key ?
Hi, how's it going?
7E0 ... 'E' is only for 434 Mhz.
Is BCM new? in this case Channel 99 = 0 (Factory mode), ... or maybe you bought a BCM for Kessy ...
We need a Russian friend to tell us what this means...
Shadow109
Post by Shadow109 »
Its used, A Russian guy was selling in a decent price on drive2, the Russian words means “made in Germany”
tomorrow I well check factory mode, and I will post a scan
Shadow109
Post by Shadow109 »
ciclo wrote: Thu May 13, 2021 5:26 pm Hi, how's it going?
Indeed factory mode was on :roll:
New Scan :-
Friday,14,May,2021,12:25:14:00009
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 3C 5F 65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 223950km-139156miles
3C-Lane Change -- Status: Malfunction 0010
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F23E0-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175796210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905BCD-806E
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7BB1-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695396-802E
   Revision: B9084001    Serial number: 2502 306190145
   Coding: A8A0393E4E21201201280ED06EAB9ED4F08063FF608C2040320400030800
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB3741137E358-8078
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 108001
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A913033C-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 356194D394417F2320-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   Revision: B9084001
   Coding: 042204
   VCID: 68DF0DA79B73D2CB6B-803C
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: 2D51BCB37C1137E358-8078
   Component: IMMO          H04 0805
   Serial number:
   VCID: 6ADB77AF8D7FE0DB7D-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:. 5Q0-907-686.clb
   Component: HRE_Master    H12 0080
   Serial number: 0466413079
   Coding: 02032102
   Shop #: WSC 09003 957 00200
   ROD: N/A
   VCID: 3D718CF3AC71A763E8-8068
No ASAM data for: "EV_HREntryHella" (VN75)
2 Faults Found:
336901 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 223953 km
                    Date: 2021.05.14
                    Time: 10:55:04
337328 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 223953 km
                    Date: 2021.05.14
                    Time: 10:55:04
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001000D08001F0303C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VN35.rod
   VCID: 2541449324E10FA390-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
3 Faults Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 223953 km
                    Date: 2021.05.14
                    Time: 10:55:04
                    Voltage terminal 30: 11.6 V
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 223953 km
                    Date: 2021.05.14
                    Time: 10:55:05
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0003 - Antenna 2 for radio
          B111A 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 223953 km
                    Date: 2021.05.14
                    Time: 10:55:05
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
   VCID: 377D9EDB8E4D8D3332-8062
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:09)--------------------------
Solved! 👍
TheKeymeister
Drives: Caravelle T5.1
Post by TheKeymeister »
Apologies for jumping on the back of this thread once again, I've finally got around to uploading my parameters, still no wheel sensors fitted, but I'm getting an error from the instrument cluster due to missing messages, and no TPMS display appearing or mention of pressures in the units section. I tried disabling the indirect TPMS from the ABS unit but it made no difference.
I gave it a quick google and it came back to a thread on here where it turned out the instrument cluster was not suitable, I'm guessing it'll probably be the same for me. I've tried searching for any updated flash files for my cluster and can't find anything forthcoming....so this may be the end of the road for me with TPMS :cry:
Latest autoscan here for info https://pastebin.com/HuSfrXC5
Shadow109
Post by Shadow109 »
TheKeymeister wrote: Fri May 28, 2021 1:23 pm Apologies for jumping on the back of this thread once again, I've finally got around to uploading my parameters, still no wheel sensors fitted, but I'm getting an error from the instrument cluster due to missing messages, and no TPMS display appearing or mention of pressures in the units section. I tried disabling the indirect TPMS from the ABS unit but it made no difference.
This error is not caused from your cluster
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Your BCM hardware version is H81, your BCM have to be minimum H82 to enable address 65 (tire pressure) in can getaway
TheKeymeister
Hi, I thought it was H81 that was required! Hope I don't need to do another BCM swap :cry: Address 65 appears in the installation list anyway
Someone on T6 forum has asked me to check with ODIS for better fault information so I'll do that over the weekend and report back
Shadow109
Post by Shadow109 »
If address 65 appears in your can getaway then you don’t need to change you bcm
TheKeymeister wrote: Fri May 28, 2021 1:23 pm Latest autoscan here for info https://pastebin.com/HuSfrXC5
TheKeymeister wrote: Fri May 28, 2021 5:17 pm Hi, I thought it was H81 that was required! Hope I don't need to do another BCM swap :cry: Address 65 appears in the installation list anyway
BCM 090B is Ok for TPMS.
Supposedly and based on the SW update I did on my 6R IC, you need an instrument cluster with SW greater than 0405, but as I say it is supposedly.
The only thing that is available for Transporter, Diesel and MPH is
FL_7E0920970J__0720_S.frf but it is for 9Q5 and your IC 7E0920980G is 9Q4, ... you would need to get / find a flash file similar to this FL_7E0920980J__0720_S.frf ... or FL_7E0920980N__0805_S.frf
I searched but did not find.
