I removed my SDI badge from the back and the best way I found to do this is by using a hair dryer! Get your hair dryer and put it on full hot power and blast the air over the badge. This is to soften the sticky part! Do this until your hair dryer cuts out (which is ok). Then use a small screw drive or knife and slowly try and peel it off. Just watch the paint. A good tip is wrap you knife in a towel so that its not directly onto the paint. Your badge should come off nicely but try and not butcher it because you need to stick it back down!
Oh another good tip before you start get some masking tape and mark out where the badge is then peel it off because if you dont mark where is was then am sure you will put it on squint. There is a small curve on the back and if you look close the badge doesnt sit straight in the first place!
Good luck mate and DONT scratch it!
