I park the car and switch off the A/C button while tunning of the engine.
When I pick up the car ten minutes later, switch on the engine>switch
on A/C,then there's only warm air even after a minute or so.
So I kept switch the A/C button on/off few times, still nothing.
Then I give the car a little higher rev for few seconds,then switch
on the A/C again, engaged...cool air is back!
I'm sure the radiator fan is working fine, but after that, the A/C seems working
fine for another ride. Just don't wanna ignore the problem before it's too late.
You know the compressor unit is quite costy item.
Any input for what to look for?
