help replacing standard 6N2 door speakers...
- Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
ok my speakers have finally arrived so i'm going to have a bash at fitting them. do you have to remove the door panel to fit them or can you do it just through the speaker cut out? Also, how do you remove the standard speaker grilles? i just tried pulling one to see if they just popped off but it cracked lol...
im assuming the 6n2 is the same fittings for the door cards as the 6n.
wind down the window and pop off the triange plastic thing by the wing mirror inside the car. wind window up again.
on the door handle bit pop off the top cover with a flat bladed screwdriver or priser bar. then undo 2 screws.
pull on the door release catch ( the handle to open from inside and pop out the electric mirror thing.
the window winder theres a ring that slides up ( its fiddely the first time) unscrew the door pin
then pull to door card off starting at the bottom and then in a upwards and out mothin give it a yank all is good and well it will just pop off.
