AIRBAG LIGHT
mil32525
AIRBAG LIGHT
Post by mil32525 »
I disconnected the passenger airbag from my Polo so that I could have my little son's child seat at the front (obviously the airbag light was on all the time). I am now selling the car, and I have reconnected the air bag, but the light does not go off.
Does anyone have any idea how I can sort this out?
Thank you.
forbezGti
Post by forbezGti »
you will have to use vag com to turn of the light.
vw garage do it but i think they charge a lot for
what is done.
try any garage to see if they have the vag com.
I think this how you switch it off
suby786
Post by suby786 »
yes any vw specialist should have this, VW charge £35+vat i think for this if not more, i paid £15 from a specialist and he cleared my light, but i actually have a fault, AIRBAG IGNITOR CONTACT RESISTANCE TOO LARGE... what does that mean though, on haynes it shows this contact being behind the steering wheeel but is very unclear, if resistance too large then means the contact is crap or dirty, might not be a faulty ignitor...
just search for vw specialists in ur area.. i went to LIONS GARAGE.. think they hav 2 or 3 branches in UK
wils0n86
Post by wils0n86 »
@' suby786', the same thing happened to me a few months ago, the resistance was too high and so the light stayed on after ignition. my problem was due to a small crack in the ignitor ring behind the steering wheel, luckily a mate of mine worked for seat at the time and so he was able to order one with a big discount, iirc it still cost over £100 though.
the airbag system in it self will work the same as normal and wont go off unexpectedly, but i had to change mine as it happened just before my mot was due.
M1 TCH
Post by M1 TCH »
you could just dissconnect the bulb from behind???
mitch
suby786
Post by suby786 »
hey mate... its not a bulb on mine, post 98 cars have a different dash and there on by LED's and its actually in the cluster, whereas in pre-98 models the airbag light is on the side panel and can be cut/large resistor...
