[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Removing lower center grill - Question! - UK-POLOS.NET - THE VW Polo Forum
Today I was trying to fit the gti grilles to my car. I was able to fit the upper center grill and the little ones on the sides of the bumper (not difficult ), but I couldn't get the lower center one off Is it necessary to remove the bumper to get it off, or is there any other way to do it?
It is clipped around the edges and is a real pain to remove.
You could try pry off the bottom edge with a plastic tool and pull it out like that or perhaps thread some strong string thru the holes and use it as leverage.
I used a combination of the two ideas to remove it - I ended up breaking one whole side of clips, but it does not matter if you are not keeping the old grille.
New honeycomb one will just click into the slots left in the bumper cutout for it.
