Antenna's Rubber seal
Has anybody had to replace their's. Mine needs changing but i have a feeling it's a tricky job?
Re: Antenna's Rubber seal
Had to do this on previous mk4, well I didnt my mechnic did, you have to remove the roof lining to get to the gromit.clees wrote:Has anybody had to replace their's. Mine needs changing but i have a feeling it's a tricky job?
did it on my G40 - you have to pull the rubber boot seal away, then warm up the edge of the roof lining with a hairdryer where it's glued down etc, you can then gently peel the lining away. Inside there will be a bar that is held in by a couple of clips, once you unclip it the lining drops down enough to access the nut on the bottom of the aerial.
Assuming the Gti is the same, then it's not too difficult, just need to take your time so as not to stretch the roof lining.
Redline
- Sponsor
- Drives: BMW 128ti
Think the repair kit is shown in this thread http://www.tigerstyle.co.uk/poloforum/v ... hp?t=13120
