G60 Brake Upgrade
- Sponsor
- Drives: Skoda Octavia vRS
G60 Brake Upgrade
Planning on doing the G60 280mm front disc upgrade in the near future.
Basically interested as to whether anyone has any recommendations on disc and pad combinations, or alternatively whether the OEM parts are good enough.
I personally don't think it is neccesary to go with any fancy disks, unless you want the visual impact of seeing something that looks good through your wheels. Just plain vented from any good manufacturer will do.
Pads, i'd go with greenstuff to try and reduce brake dust, unless you really brake hard often, in which case you will want some pads with a more aggresive compound e.g redstuff or pagid fast road (from gsf).
I'd definitely look to get some aftermarket brake pads too, IMO the standard brake discs will provide plenty of extra stopping power.
I replaced my OEM brake pads with Black Diamond pads which I bought from John at 2modified.com. Cost ~£90 for front and rear pads, with which I have seen a huge reduction in the amount of dirty black brake dust being kicked out! Either those or some Greenstuff will see you laughing
- Sponsor
Cheers guys.
I live out in the country, with some amazing driving roads which does include obviously heavy braking. So performance pads are a must I think. Not personally a fan of Greenstuff pads, but Black Diamond Predator were on my list of ones to consider.
In terms of discs, I quite like the cross-drilled look but not too keen on the price of Tarox or Black Diamond ones. However I have come across cross-drilled discs from Zimmerman and FK which are quite affordable.
The stock brakes can reign in the standard engine, yes. But the G60 280mm upgrade means you can brake later and over shorter distances, thereby making point-to-point driving faster. Plus, a shorter stopping distance is a good thing in emergency situations, no? Oh and they look much better filling up the space behind the rims too, don't theykefirvr6 wrote:my opimnion is if u have stock motor theres no need for u to change it. stock brakes are good for it. i have vr6 motor in my polo and put g60 brakes all kit 280 mm ddrilled disc. now brakes amazing but i wouldt do it with stock motor. waste of money. invest it in enginel)
- Sponsor
Cheers Si, my sentiments exactlySi_GTi wrote: But the G60 280mm upgrade means you can brake later and over shorter distances, thereby making point-to-point driving faster.
I do a lot of "fast road" driving out here in the country, so bigger and better brakes means more time spent on the go pedal.
Plus to be honest I can't really see the point in throwing money at trying to make the GTi quicker in a straight line. I already have a BMC on there, but I can't justify more cash on gaining a few extra horspower. Without turning to forced induction or nitrous it's never going to produce serious power.
You have to fit some small spacers to the wheel hubs as the calliper fowls the wheel slightly.
Nothing major though, only a few quid and will help pull the wheels out to give a sweeter look.
Just a point though, fitting bigger disc's will not make you stop any quicker.
They will just give more feel and help reduce brake fade.
The only real way to stop quicker is by buying better tyres
erm not really,Si_GTi wrote: But the G60 280mm upgrade means you can brake later and over shorter distances,
bigger discs might give you better feel
main reason for bigger discs is greater resistance to fading
get the standard 256s to even remotely start fading driving on the road is a very difficult task
and i wouldnt bother with fancy discs, definate waste of money on a road car if you ask me
To be honest, the ATE pads you can get from ECP are up to the job if you drive hard. And thats what I bought for the Ibiza today, in fact!
I ran my Cordoba track car (which had 280s) on the Brembo ones and they fell to bitsa after one tame track day. The ATEs had the same stopping power and lasted a lot longer, even a Nurburgring onslaught and the chaotic drive home!
Greenstuffs warp discs very easily, I do not recommend them.
