just had my head gasket changed and head skimmed, all under warranty, to try and stop overheating problems, the theory was that there was a crack in the gasket and when enough water leaked not enough to cool engine was left.
anyway, since i got it back it stalls when i start it up if it has been left for more than about 7 hours. it never had any hint of this before the gasket was changed. what happens is that it turns on, revs go up and then just fall straight down again, even if i give it some gas on the first 2 or 3 attempts it doesn't rev properly.
any ideas? i was reading about the throttle body problem people have written about but they seem to say it over revs. after i have it ticking over, by giving it lots of revs when starting it up it idles at about 900 revs which it did before the gasket change, although it never stalled before it!
what have they done?
stalls when first start :(
Don't think it's anything to do with the alarm/immobiliser.
Could be a few things. Throttle body alignment could be one of them, although I'm not entirely certain how you sort this one other than remove it, clean it and stick it back on. Could be as simple as adjusting the idle screw on the throttle body itself to give it a fraction more air/fuel at idle to stop it cutting out. Depending on how much stuff they removed when they changed the head gasket, it could be an air leak somewhere or an engine sensor went south not allowing the car to sense it's cold and needs to put more fuel in.
Does it ever stay started?????
If not it could well be something to do with the immobiliser (same prob with my polo). It would start then cut out, due to me using an aftermarket key which did not contain the chip in it the car recognises.
so perhaps something to do with key or immobiliser etc....?
If yours does start though, there is obviously something else going on....
good luck
good luck
