light changing?
X1_NBP
light changing?
Post by X1_NBP »
hey...quick question...how do i changme my headlamp bulp...the big lights not the small ones
:oops: :oops:
dino
Sponsor
Post by dino »
If your is petrol then you should easily be able to pull off the weather cap behind the main beam light and there is a clip holding the bulb in which can be fiddly but you just have to be patient :)
X1_NBP
Post by X1_NBP »
lol i been patient with it but it just wont budge...
carmadaaron
Post by carmadaaron »
- Take off the rubber weather cap.
- There is a plastic ring that surrounds that bulb, twist that and it will 'click'.
- Pull out bulb with the wiring out.
- Exchange bulbs
- Repeat the above in reverse.
X1_NBP
Post by X1_NBP »
thanks guys i got it
mjmills
Post by mjmills »
when i gt the bulb out with the wiring (after doing the twist unlock) the bulbs seem pretty stiff, do i just need to pull hard (am scared about breaking them)
Also how does one remove and replace the sidelight bulbs?
LowPoloCo.
Post by LowPoloCo. »
i might be wrong m8, but i think its the same.
but the sidelights are a bit trickier to get at :x
the inner most weather cap has to be removed, and then the bulb is up a bit inside it, i find the best way is to watch which bulb is fidgeting from the outside of the light casing.
hope this helps
ell
carmadaaron
sidelights are a bit harder....
what i do is bend my arm right round, so my elbow is facing the back of the car, then my fingers can give the release latches a good squeeze :lol:
mjmills
Post by mjmills »
Trying to remove the sidelights, i am presuming that the little nibbler on the top left of the lighting array is what i am after, before i break my car and the vw dealer gets to rub their hands in glee can anyone sugest how to get it out (twist, twist and pull, just pull??)
AKs_SlickPolo
Post by AKs_SlickPolo »
Yeah thats the sidelight. See those two raised tab thingys in the pic? just press them and whilst holding them, just pull and it will be out :D
carmadaaron
yes, just squeeze the tabs in the direction of the red arrows, and then pull out.
mjmills
Post by mjmills »
cheers guys, worked perfectly, although kerb side was really fiddly. Did the switch, now have philips powerblue bulbs in the car, don't look that blue though??
AKs_SlickPolo
I had those Philips Powerblue ones and in my opinion they were poo!
For a nice pure white light with a bluish tint, order yourself some pure white LED sidelight bulbs from Ultraleds :wink:
DAZZA_TDI
Post by DAZZA_TDI »
Wish mines was that easy to change the bulbs, it`s a bumper off job for me this w/k i`m afraid :cry:
Dazza
