I have noticed that when I turn my Base tube on the a very annoying high frequency rattling is given off on every "drop" of the base. It isn't a terribly "iced out" system with only a 600 watt peak but the boot does make a terible sound because of it. However if I take time out to tune the frequency and volume the vibrations stop. When I got my car back from the garage the dials had been fiddled with so i didn't bother to re-tune it but surely there must be a way to stop the vibrating all together.
Has anyone ever had this problem and know how it can be solved.
Ally
Boot vibrations
tornado_ally
You need to get yourself some sound deadening, top stuff like dynamat is excellent at gettin rid of rattles, you could do your whole boot with it or just a smaller area around where your bass tube is installed. its easy to install, ive just put it around my components in the front doors and it wasn't 2 difficult, should be even easier in the boot. you just heat it up with a heat gun and stick it to your panels.
tornado_ally
