[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 9n wheel help - UK-POLOS.NET - THE VW Polo Forum
depends on the offset, fronts will want to be 30mm or higher offset if you're lowering.
my rears would catch the arch if much wider, and they're 7.5" and lowered all the way. 8" would be ok just.
I would want to have about 40mm offset on the back with a 9" width wheel. but if you stick 205 tyres on them then they might just fit with 35mm offset!
ok the offsets....fronts are 30 and rears are 15. I could get spacers to change that though couldnt i?
...........because the rear tires r 215 and you say i wud need about 40mm offset would that mean they would stick out the arches loads?
would you not recommend putting 9's on the rear then? would look sick but if its guna cause loads of problems, duno if its worth it.......
Ah i still really want those coilies, pretty low on cash but if i can work anythin out i'll let ya no!
