Ok, sensor plugs into the gearbox - near the back. Well my speedo stopped - so ordered a new speed sensor that screws into the box. Problem though is that the old one the bit has snaped inside the wee hole where the new pin has to go in - how do i get it out - can i unmount the whole bit the speedo screws onto from the box ??
Havn no speedo is a bit of a problem lol
Neildo
Speedo Drive
1. Speedo drive screws into gearbox
2. The part the speedo drive screws into can be taken off the gearbox - 22MM DEEP socket.
3. Once you have that bit off, pull out the yellow rod (speedo gear)
4. End of the rod will have the broken bit stuck in it - get it out - or if you cant like me then get a new one (got one at the scrappy £7)
5. Put new rod in , screw on bolt , put on speedo drive - connect plug to the drive and that should be you sorted
Neildo
Neildo
