MOT Failure
Dan1587
MOT Failure
Post by Dan1587 »
Hi there, im new to this!!
Just had my car mot'd
She failed!!
Wheel bearing NSR
Brakes Binding NSR
Handbrake cables basically f**k*d!!
The handbrake cables and new shoes plus wheel cylinders, i have fitted these before, but the wheel bearings, are they a pain?
dan.
wadders
Post by wadders »
The bearings are pressed into the drums, which if you haven't got the right tools are a pain to get out. Your best bet would be to get some new drums and bearings and using a suitable size drift to press new bearings into new drums.
Dan1587
Post by Dan1587 »
wadders wrote:The bearings are pressed into the drums, which if you haven't got the right tools are a pain to get out. Your best bet would be to get some new drums and bearings and using a suitable size drift to press new bearings into new drums.
yeah i see what you mean, but im doing this in a workshop and i have a hydralic press so hopefully be able to press them out and the new ones in, ill let you know anyway as i am trying tomorrow morning at work!!
Thanks for your help!!
dan.
Petrol_Head
Post by Petrol_Head »
I HAD THE SAME!!!!
IT TOOK ME A COUPLE HOURS!!!!!!!!!!!
I used a screw driver and a hammer and tapped the bearings out... you have to be patient ... but is easy!!!... very easy!!!!
they are £12 for GFS... (GERMAN FRENCH SWEEDISH)... not the £39 the mot garage wanted to charge me!
vw-po-low
Post by vw-po-low »
The wheel bearing is a taper fit, so it will losen or tighten depending on how tight you crank the hub bolt up (both sides are right hand thread). They don't actually need to be that tight. Mine was easy to get out when checking my rear drums over.
Dan1587
Post by Dan1587 »
Petrol_Head wrote:I HAD THE SAME!!!!
I have half done her now, lets just say i am glad i caught it then, the bearing had got so hot in there i had to get a good puller in there to pull her out, any longer and i think it would have welded itself to the hub!!
But apart from that it is quite easy, like you say just tap the old bearing and carriers out of the drum!!
thanks for your help!!
dan.
