9n strut brace & lip spoiler
Kuru14
Post by Kuru14 »
ive heard of people buying them from seat and instaling them.. anyone have a part number and price of a front strut brace?
also does anyone know if i can get this lip spoiler anywhere else possibly cheaper?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0295935044
thanks
ryandel_9n3
Re: 9n strut brace & lip spoiler
Post by ryandel_9n3 »
you can get the "lip spoiler" on ebay cheaper.
look up seat leon cupra R parts.
or go to seat.
chewy
Post by chewy »
Strut brace part No. 6L0 071 710 and they are £55ish mate
The splitter part No. 1ML805903 iirc dont know how much
Off to check the bay :D
chewy
Post by chewy »
TDI_Burd
Post by TDI_Burd »
Seat might be cheaper for the splitter
i need to price one so will find out from seat how much
Kuru14
Post by Kuru14 »
Cheers for that chewy! got the splitter now :) just need to sort the strut brace.
polospeed
Post by polospeed »
chewy wrote:Strut brace part No. 6L0 071 710 and they are £55ish mate
Cool might give seat a ring :D
blkpolo
Post by blkpolo »
how do the splitters fit on?
Kuru14
Post by Kuru14 »
im not sure yet but should be fitting mine in the weekend so i can let u know how it goes for me..
blkpolo
Post by blkpolo »
Cheers man :wink:
Kuru14
Post by Kuru14 »
havent fitted it yet but had a good look at the bumper and it seems that ul have to cut ur own holes for the clips on the splitter to fit in.. i think i might just drill some holes and go for some nuts and bolts.. unless anyone knows of a better way to fit this in?
blkpolo
Post by blkpolo »
how hard was this to fit then? :P thinking of getting one soonish.
Kuru14
Post by Kuru14 »
sorry for not getting back forgot about this, well i have fitted it and i didnt find it too hard, if your a fairly conifdent with your diy its not going to be a problem. It just needs to be lined up properly before commiting to drillign holes.. you will need about 16 screws if your going to drill them in (whcih is what i did). You will also have to cut 2 holes in the bumper where the splitter will clip in the middle.
i realise this probably doesnt give you a good idea so il try and take some good pictures over the weekend and post them up for you as the bumper will be coming of anyway.
blkpolo
Post by blkpolo »
cheers that'd be helpful :wink:
Kuru14
Post by Kuru14 »
Ok so heres my attempt;
the spoiler itself wich needs to be trimmed at either end but i just left this till the end, after id fitted it;
in the pic u can see in the middle theres to bit sticking up these are like clips and need to be placed through a hole in the bumper. For this i masked up the area so i can make a lot of measurements and draw lines n what not till i got the spliiter bang on where i wanted it, i then cut the hole slightly smaller than needed;
it needed a bit of trimming but eventualy i got the clips through;
i then drilled through from the underside holes along the tabs on the splitter and used washers, screws and clips to secure the splitter in place;
hope this helps, defintly improves the look of bumper in my opnion, sorry for some of the pics being low quality..
heres how mine looks in the end;
