How do I find out my brake disc size?
I have a 1.4 16v and need both front and back disks and pads
Thanks in advance
Brake disc size
Re: Brake disc size
256mm more than likely try measuring them either across the centre other than that go to vw with the chassis number and they will tell you
Re: Brake disc size
If your engine is 75PS - maybe a BBY engine, the front discs will be PR-1LQ which means 256mm X 22mm (vented) and the rear discs PR-1KD which means 232mm X 9mm (solid) - maybe get ATE discs from ECP fronts ATE p/n 422151 24.0122-0151.1 = ECP p/n 104 440 710, rears ATE p/n 409123 24.0109-0123.1 = ECP p/n 104 440 740 . As for pads, front, you should try to get Pagid T1163 (555 216/1) from GSF - stock ref 64330 with single wear sensor and anti-squeal fitted, for rears you should try to get Textar 2382301 (23823-172-1-5) from GSF - I don't know their stock ref number - with single wear sensor and anti-squeal fitted. These ATE, Pagid and Textar numbers should appear on the boxes of discs and pads that you are given.
