heating noise HELP!!!
bradley1983
When I put my heating on I hear a LOUD noise. Sounds like metal clicking. It only happens when it goes on and its a sharp noise . What is this as it has been annoying me for bloody ages
Re: heating noise HELP!!!
With the air con turned on or off? Ie Auto or Econ
bradley1983
Just by turning the heating on. Press on........ting. Every time!!!
Its Fcuking annoying!!!
I know - but if you turn it to off, and press auto does the noise come on. Then turn it to econ, turn fans to off and turn it back on
Check if the noise is present in both times
If it is, then its a fault with your blower motor inside the Auto HVAC unit which is a fiddly and time consuming fix. However- it can be diagnosed with vagcom, so if its a faulty air flap it can be narrowed down quite quickly
think you have the same problem as me turn aircon on, pres the air ciruclation button then it should get rid of the noise. What i do for mine pikey fix though
