It was ascertained that the Rear Lower Wishbone Arm, Rear Bush was gone and this was confirmed by a mechanic, as the wheel could be nuddge forwards and backwars while the car was stationeryand also on occasion there was a knock sound.
Following the above i went out and bought 2 new bushes as shown below: It was nighmare to remove the old one, but even move of a nightmare to install the new one, whic i have not done.
My question is, does anynone have any experience in replacing this bush and what tools did you use.
The following methods i have used without sucess:
Knock it in, as encasement is plastic so it cracked [dident work]
Forece it in with my hand while spining it [dident work]
DIY Clamp mechanisam, did not work, only went in 20% and got stuck. [dident work]
PLEASE HELP
