did you get a hose with it and clips?
if so ull need to remove the box nearest to ur windscreen should be a rectangle shape, thts where ur throttle body is and were you clip the hose if you got one... adjust the hose round back of engine heading towards the front of the bumper and hence put the cone there where it can get some nice cold air
good luck... any more help just post up and ill try help... had my fair share of messing around with 6n's and some other similar VAG's =]
