My car has developed a squeaky wheel (sounds like an old spring bed every revolution) and after i had a feel round tonight i found grease smeared on the inside of the wheel.
Is this a sign of a broken CV joint?
Squeaky Wheel?
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: Squeaky Wheel?
Yes the grease is probably from a split cv boot leading to a failing cv joint.
Re: Squeaky Wheel?
agree, next question how far can i push it before the axle starts flailing around and smashing stuff? Bad question i know but i'm out in the coutryside so gonna have to drive it at least a short distance.
- joe2612
Re: Squeaky Wheel?
ideally you want to get it sorted asap? if it hasent been squeaking for long you should be fine for short distances..
