Seat swaping - Subframes
Bikerz
Post by Bikerz »
Hi
I have been offered some corsa VXR seats cheap (Recaro CS). Can I buy Polo 9N subframe kit like this http://garry.motorsportworld.co.uk/fram ... 0Subframes
Will they bolt in bolt out?
Anyone advise which are best subframes to buy? (I dont want to start welding as I did that in last car)
Ladiesman_317
Re: Seat swaping - Subframes
Post by Ladiesman_317 »
And have you planned how you will get around passing an MOT with an airbag light on?
Bikerz
Post by Bikerz »
Yes! Resistor in the connector :wink:
Eddie9n
Post by Eddie9n »
Ladiesman_317 wrote:And have you planned how you will get around passing an MOT with an airbag light on?
Actually, 9N3 Turbo has his airbag connected with his recaro cs seats. -- http://www.uk-polos.net/view ... &start=150
rover220
Post by rover220 »
7
quite easy really as its not part of the test yet
Ladiesman_317
Yeah, I've heard a few people suggest that, but surely, if you stuck a resistor in, wouldn't it just stay off? rather than coming on, then turning off?
88rsr
Post by 88rsr »
Ladiesman_317 wrote:Yeah, I've heard a few people suggest that, but surely, if you stuck a resistor in, wouldn't it just stay off? rather than coming on, then turning off?
As long as its the same resistance as the airbag wiring it tricks the control unit into thinking its perfectly normal and ascts as it should :)
Bikerz
Post by Bikerz »
Cheers guys. I will just measure resistance of current seats and then put a resistor of same value in and all airbags (bar seat) will work as normal. Recaro even do the connect and resistor in a kit to make it easy. I have a pair in my TT with recaro pole positions and a recaro resistor connector.
