I have a 97 MkIV and everything on the display works fine - except for the odometer, which reads: ' - - - - - - '.
My local VW mechanic is using lack of mileage display as an excuse not to give me a full guarantee of his work.
Is there anything I can do about this that won't cost me a fortune..? Thanks very much.
Odometer Fail
Re: Odometer Fail
A new set of clocks will likely fix that problem
Re: Odometer Fail
You mean replace the whole dash unit?
Re: Odometer Fail
Yes
You'll just need to make sure you get the same style of clocks and a similar mileage.
Re: Odometer Fail
I have no idea what the mileage is - the odometer display has been ' - - - - - - ' for years.
But thanks very much for the info. I'll get google on the case.
