**Engine Swap**
MarkRobson1989
**Engine Swap**
Post by MarkRobson1989 »
So I’ve got a 2003 VW Polo 1.2 E and I’m loving it so far, I only wish it had a bit more power so I’m thinking of having the engine swapped out in favour of a bigger, more powerful unit. Could anyone give me some advice on which engines would be a good fit? I’ve been looking at the AUM engines from the MK4 Golf GTI and also the 1.8T engines from the Polo GTI.
Any help would be appreciated!!
Re: **Engine Swap**
Unfortunately there tends to be a common reply on these forums to anyone posting on this topic, that reply is "forget it" save up for a Polo with a bigger engine fitted at factory. The reasons given include, difficult to insure as it will never be a GTI etc, cost of changing fuel system and piping, ECU and cableforms, brakes and suspension. It will always be a mongrel as even the basic body will be slightly different for the bigger engined cars It might sound like a great project, but for all the money will be spend, add that to what you have and you should be able to get something better that started life as a GTI etc.
This advice might sound like sour grapes, but I've been there and almost spent the money - and that was over 30 years ago, luckily for me reality cut in and I held on to the money and bought a far better/faster car, so I've no regrets on that count.
There is always Ibizas around with bigger engines for less money than a GTI Polo will cost, maybe think about that as a "halfway" car until you can afford a better VW.
Lucaio
Re: **Engine Swap**
Post by Lucaio »
RUM4MO wrote:Unfortunately there tends to be a common reply on these forums to anyone posting on this topic, that reply is "forget it" save up for a Polo with a bigger engine fitted at factory. The reasons given include, difficult to insure as it will never be a GTI etc, cost of changing fuel system and piping, ECU and cableforms, brakes and suspension. It will always be a mongrel as even the basic body will be slightly different for the bigger engined cars It might sound like a great project, but for all the money will be spend, add that to what you have and you should be able to get something better that started life as a GTI etc.
Seconded.
