Is there any other components other than the ECU and the key as a matching pair?
I only ask as I know some makes have other immobiliser boxes like transponders etc. Rovers had a 5AS box which was a separate interface between the key and the main ECU.
Sent from my iPad using Tapatalk
ECU and key pair?
Re: ECU and key pair?
The 6n2 is the same
You'll need the immobiliser box under the dash too
6n2stan
- Drives: 6N2 GTI, Golf GTD + R32, T5.1 BiTDI DSG
Cheers Alex,
What am I looking for? Is there a part number or label so I remove the right thing?
Follow the wire from the black transponder ring around the ignition barrel
6n2stan
Cheers Alex, I shall have a poke around tonight.
