Brake lights and indicators not working - 03430 - Terminal 30 for Turn Signals and Brake Lights
keithcheetham
Drives: 60 plate 1.2-60 SE 6R with winter pack
Post by keithcheetham »
Have a problem on a 2010 6R 1.2SE Polo where the brake lights and indicators/hazards are not working. The following code is showing:-
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 F HW: 6R0 937 086
Component: BCM PQ25 M++4 H46 0221
Revision: BD046001 Serial number: 0343 175100287
Coding: 3DB029BF08A10000002000003D2B0DD00040410F60060000200000000000
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0912
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0912
Coding: 08BC30
1 Fault Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 116875
Re: Brake lights and indicators not working - 03430 - Terminal 30 for Turn Signals and Brake Lights
do you even sleep?
I love the stars of the night ... like these:
http://www.luzernerzeitung.ch/storage/p ... 1411628314
keithcheetham
You were correct Ciclo. While using a multi-meter across the fuse contacts from the outside (the 2 contacts accessed through the face where the rating is marked), there was continuity showing, but pushing the probes in must have been pushing the break in the fuse together, with a current draw through the lights stopping continuity. Now all I have to do is get the high level brake light out as this doesn't work while the LH/RH brake lights do work.
keithcheetham
Car has a mind of its own, 3rd brake light didn't work after replacing fuse but after a drive it started to work, although the "light out" warning light stayed on dash. Talking to daughter, who's car it is, appears that the warning light is now off. I assume that it will have re-set after a few cycles of ignition, and will scan it at the weekend to confirm no error messages are stored.
Yes, clears code faults (DTC's).
Usually with an ignition cycle it is enough for the warning light on the dashboard turn off.
You're a good father. :wink:
teo_vlm
Drives: Polo TSI 6R 2010
Post by teo_vlm »
Hello from Greece.First of all, i would like to kindly ask forgiveness for my bad english.
Just had a problem with short-circuited battery that caused many problems. Starting with flashing dashboard, not turning the motor on, brake lights and direction lights not working. After a few minutes waiting, the dashboard finally stayed lit and then brakes indicator started flashing and beeping. After starting the engine by wiring to another car, the lights insisted staying off plus i lost the electric assistance of the steering wheel. I changed the battery but the problem with the lights keeps happening.
If i understood correctly, number 43 of the fuses has to be replaced?
Thank you for your patience 8)
Battery--->Fuse SA3(110A engine vain fusebox)--->Fuse SB43 (15/20A supply for Blinkers, brake lights)--->T73b/13 BCM--->BCM---> Blinkers, Brake lights.
Do you have VCDS?
