Interior swap - Need help with heated seats
Nlolotte
Drives: Polo 1.2 R-Line TSI 6R
Post by Nlolotte »
Hello,
I have managed to track down and purchase the elusive R Line leather interior with door cards for my car :D
This means I will be retrofitting heated seats next week after I pick them up, just in time for winter.
I was looking at the wiring diagram in ciclos post about heated seats but it makes no sense to me. I will be using the Kufatec loom. Which wire goes where :?: :?:
If someone could just draw on the diagram what to plug into where, i will be forever happy.
Re: Interior swap - Need help with heated seats
left: seats
middle: the very small terminal goes to the BCM, the loose wire goes to a blue/grew wire from one of the other buttons next to the hazards, the open loop to the chassis, the big connector to the fuse box
right: two for the heated seats buttons and one big one to the control unit
Eduard
Drives: 6C
Post by Eduard »
If you can't find the place where the control unit goes ( from the workshop manual pics ), I can help. It's really not an easy place to reach to, if you want to position it correctly, otherwise, the control unit can be placed wherever.
Also, you don't need that long of a cable ( the loose one, without a terminal , in the middle section ). It's only used for background illumination, so just remove it from the rest of the loom, shorten and keep it next to the switch connectors ( red + orange ), as you'll need to solder it to any other switch wiring aside hazards.
Nlolotte
Post by Nlolotte »
Thanks so much for your reply.
Which pin on the BCM do I need to locate and where is the BCM in a RHD car?
So the loose wire is for the red back lighting?
The ring is for ground?
And which location in the fuse box do I connect the larger pin? Do I need an additional fuse?
Alvin1001
Drives: vento
Post by Alvin1001 »
Nlolotte wrote:Thanks so much for your reply.
The bcm for rhd is located at the driver footwell, right behind the fuse box.
Sent from my SM-G950F using Tapatalk
Nlolotte
Post by Nlolotte »
Ok so I now understand one terminal goes to pin 37 on bcm on goes to fuse 36 in fuse box I now wonder where do I get power from? Is that done by daisy chaining the wire for background illumination or do I need to daisy chain of an existing red 12v wire and connect it to fuse slot 36b?
