Bixenon headlights with AFS For polo gt Tsi 2015
Re: Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur wrote: Mon Aug 20, 2018 6:50 pm
DOES THIS MEAN I HAVE TO REPEAT PROCESS
Repeat the process according to the ross-tech page, it is written in a language that you should understand perfectly.
Please, do not write in capital letters. Thank you very much.
hmthakur wrote: Mon Aug 20, 2018 7:03 pm Cicolo
Just asking you even if bcm is in factory mode, does it accept coding
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
hmthakur wrote:Everything working perfectly, their was problem in wiring. Remote adaptation done car is unlocking but not locking.
Headlight motors not working with afs
Dear I think it's not wiring error its installation problem.You had not installed wires properly.Thats a part please tell me where you had installed AFS unit and how.
Thank you.
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Remote adaptation done, it was my mistake, bcm was in factory mode. Everything is fine will have to check the afs motors. Only thing remaining is tpms receiver parameterization.
Searching for original VCP
hmthakur
Post by hmthakur »
Are their any settings for cornering lights where there switching on can be adjusted??
Like after some speed or steering angle
hmthakur
Post by hmthakur »
Is their anyway i can switch off rear fog lamp through bcm as i have isolated wire from the tail lamp socket.
hmthakur
Post by hmthakur »
While installing this tpms sensors do i have follow particular position like front right front left rear right rear left ??
No, that doesn't matter.
hmthakur wrote: Thu Aug 23, 2018 1:50 pm While installing this tpms sensors do i have follow particular position like front right front left rear right rear left ??
Recommendation (for unit):
Place in back side and a little to the right so that the unit (antenna) can differentiate the sensors due to the distance from which it receives the waves/signals.
hmthakur
Post by hmthakur »
I had installed the unit at backside near pdc unit in boot which right side. Searching for VCP to edit size of my cars tyres.
hmthakur
Post by hmthakur »
Whats the procedure for doing basic settings of bixenon headlights installed with AFS using vcds??
I am aware that i will have to adjust the headlights manually vertically
hmthakur
Post by hmthakur »
If i wire the loom as given in the below picture, will the supply be directly from battery or will be from ignition??
+30 = Battery
+15 = Ignition ON
Therefore, from battery.
To be more precise, the signal obtained from those fuses would be named "30a", that is, each time you read "30a" in a wiring diagram it means that it comes from the battery and protected by a fuse.
hmthakur
Post by hmthakur »
ciclo wrote:+30 = Battery
+15 = Ignition ON
So if I install afs module and tpms using this wiring at SB 5 or SB6 they won’t switch off with ignition??
