9n airbag light on. Suggestions?
JohnMcClaane
Drives: 2002 Polo 1.4
Post by JohnMcClaane »
Hi all,
My airbag light is permanently on :(
When I took the instrument panel out to fix a connection issue, I spotted a piece of black electrical tape over the light (cheeky).
I would like to address the problem properly.
Can you please advise where should I start? What to look at first?
Is a VAG error clearing a good idea? If yes, can anyone in London help for an ice-cold pint? :wink:
I read some posts about a possible defective ring that can involve removing the steering wheel...is this true?
Any advice would be appreciated.
Many thanks!
Re: 9n airbag light on. Suggestions?
First thing is a scan with VCDS which will identify which component of the air bag system as a fault and allow you to proceed with the next steps. Once it’s scanned it’ll be much easier to resolve
