Cigarette lighter bulb
DKPOLOGT
Drives: Blue GT
Post by DKPOLOGT »
Hey guys...
The bulb in the cig lighter seems to be dead. Car has done 21.700
Miles, so a bit early.
Well i just cant figure out how to remove the socket. :(
Any guides or help? I cant be the only one to encounter this issue.
Re: Cigarette lighter bulb
Well I guess you'll either have to replace it or live with a broken bulb.
For removal, VW should have a special tool for it. Otherwise, you'll have to take out the centre console (armrest, handbrake, gear lever, climatronic cover, upper center console, lower center console) to remove it.
DKPOLOGT
Drives: Blue GT
Post by DKPOLOGT »
iichel wrote:Well I guess you'll either have to replace it or live with a broken bulb.
I guess the special tool is the way forward.
Crazy how complicated it is to change such a tiny bulb.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
good question. anyway, anyone knows the size or the exact specifications for the bulb? it looks so small that i cant find it in most shops around my area
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Guys,
just to add today i used a large binder clip, take out the skinny metal springs from one binder clamp.
use silver part
Insert it in the cigarete lighter in the groove on the right and left, and then just put your key blade in the middle so the two metal pieces spread out a easily pull up. no need for force. Then remove the connector from the lighter.
To remove the right ring use a small flat head screwdriver and insert it in the clips they are at 12 and 6 o'clock. Work one clip then lift a bit, then second clip lift, then first clip etc .... no need for force.
1.2w bulb
